the save for the turbo - Mustang Evolution
Old 07-17-2011, 12:37 AM   #1
I'm beginning to save up for a hellion turbocharger kit anyone with this have anything to say? also i realize i have to buy injecters and a fuel pump if i'm correct. should i wait and save for these when i buy the kit or buy them before hand. Any other modifications i should get before the turbo to work more efficient? here are my mods steeda CAI, tuner, comp mutha thumper cams, borla XR-1 longtube headers, off road x pipe, borla catback stingers, and some ford racing 4.10 gears on the way
Murdered_Stang is offline   Reply With Quote
Old 07-17-2011, 06:55 AM   #2
Titus Wadicus
svtlx's Avatar
Re: the save for the turbo
it all sounded good till you got to the 4.10 gears. is it gonna be a race car or a street car? if its gonna be a street car, that 4.10 may be a bit more gear than you need with a turbo.
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 07-17-2011, 07:34 PM   #3
dont install the 4.10s keep the gears that are in the rear end..4.10s are to steep keep the 3.55s in if those are the ones you have now...for fuel look for the gt500 dual pump setup.. i will have 1 for sale in a few weeks prob out of a friends car... you get to recoupe some cash when you sale your longtube,midpipe,and CAI..also do you have the steeda delete plates? if not get them because they do help..when you get the turbo kit go ahead and get the billet wheel precision 67mm so when you do a built motor you can turbo it up till your ready for more power...the 67mm can make 700+ on race gas....im a dealer for hellion so when your ready for the turbo kit shoot me a text 409-651-2839(mike)
slow02gt is offline   Reply With Quote
Old 07-17-2011, 08:23 PM   #4
I got my turbo from on 3 performance I got the whole turbo kit injectors maf air fuel rails fuel pump and oil filter relocate kit I also upgraded my turbo to a t67 with ceramic ball bearings it was 2,800
Z06 eater is offline   Reply With Quote
Old 07-17-2011, 10:50 PM   #5
For the whole kit? That's plug and play pretty much?
2005 Redfire GT - Mac LT's/prochamber, Pypes mid muffler, FRPP hotrods, 4.10's, Steeda tri-ax, JLT CAI, Bama tuned, Nitto nt05's 333/327 dynojet A little go go juice too
Southern stang is offline   Reply With Quote
Old 07-18-2011, 08:58 PM   #6
Yes sir everything except the y pipe but ima weld that myself if u get it through them it's an extra 159
Old 07-19-2011, 07:28 AM   #7
they seem to have a great kit, expect 7-8k invested when you are done~ maybe more depending on if you install most of it yourself, and if you need a K member etc~ but the end result is good power... but you cant really push it above 450-475~ so that wont be very much psi lol but a good level for a street car or until you build the motor to take the abuse.
Turbo DrSalt22 2005-2010 V6 Mustang 7 07-17-2011 12:21 PM
Turbo and tranny Z06 eater 1979-1995 Mustang GT 5 07-12-2011 09:10 PM
Turbo question! 93stang306 1979-1995 Mustang GT 14 07-10-2011 02:44 PM
01:35 AM
