Windows won't roll down - Mustang Evolution
Old 07-21-2011, 09:37 PM   #1
PunisherS197's Avatar
Send a message via Skype™ to PunisherS197
My windows will not roll down but they do the 1/4" drop and rise when you open/close the door...I've checked all fuses and all seems to be fine, I've disconnected the battery to "reset" and still nothing I've also done what the factory manual says about holding the with for 5secs and still nothing...please help!!
PunisherS197 is offline   Reply With Quote
Old 07-22-2011, 05:07 PM   #2
Do you have problem with both powerwindows or just one? And no button/switch react to handling or ignition?
cternow is offline   Reply With Quote
Old 07-22-2011, 05:11 PM   #3
Both Windows and negative to any button config...they do the 1/4" drop and rise though when you shut or open the doors
Old 07-23-2011, 01:40 AM   #4
I think the windows are connected to a relay for the automatic roll up/down. Have you checked them? 1/4 down/up is another deal.... It's probably nothing wrong with the buttons. I heard one dude that had the same problem. He solved it by closing the door real hard! But I think that was motor problem.
Old 07-23-2011, 09:30 AM   #5
Where are they located
Old 07-23-2011, 01:41 PM   #6
To be honest, I dont know. Probably with the other fuses under the hood or at your knees under the steeringwheel. It should be markt on the cap inside. Or remove the doorside and force it to move by direct connecting it to a powercable. Carefully...
Old 07-23-2011, 01:43 PM   #7
Gotcha i will try it boss thanks
Old 07-23-2011, 03:40 PM   #8
Just so you know, the Mustang electrical system is very sensitive for overloading. It's easy to burn or disrupt el-boxes. All lights for example, is guided by one hole CPU-box. We in Sweden have to know these trix because standard light-system is illegal here! Or parts of it... But windows should be on a different circuit. Relay is cheaper and can take more beating, if you know what I mean...
Old 07-26-2011, 04:09 PM   #9
Did you solve the problem?
Old 07-26-2011, 04:31 PM   #10
Yes I did it was the accessory delay in the passenger kick panel that was blown but didn't look it lol
saleen roll bar install..... rinfield2004 Mustang Paint, Appearance & Detailing 5 07-13-2011 02:28 PM
how much to get windows tinted? znpzmustang Mustang Paint, Appearance & Detailing 42 07-10-2011 12:11 PM
04:34 AM
