Need more power - Mustang Evolution
Old 07-24-2011, 09:46 AM   #1
zombiesl4sher's Avatar
Need more power
HI guys,
How much RWHP can you safely run through a standard Auto trans...
ball park figures???
I run 420HP but a CAI and pulley change plus new tune will see maybe 460-470 HP,just wondered if the standard Auto will cope.
any thoughts appreciated.
Stu.
zombiesl4sher is offline   Reply With Quote
Old 07-24-2011, 12:03 PM   #2
Titus Wadicus
svtlx's Avatar
Re: Need more power
too my knowledge your good to up to 500... but i dont know how much past that.
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 07-24-2011, 02:16 PM   #3
Thanks,
500 would be fine!!!!
Old 07-24-2011, 09:46 PM   #4
Send a message via Skype™ to DarkMatterRacin
Re: Need more power
500 is pushin it if its a daily driver. Ive seen your model auto trans hold more than that, and also blow with less than that. It honestly depends upon how hard you plan on beatin it, and how much its been driven or beaten up already.
2003 Oxford White Mach 1
T-56, H&R Lowered, Crushin fully built race cars in autocross allllll day longgg
DarkMatterRacin is offline   Reply With Quote
Old 07-24-2011, 10:11 PM   #5
CutterWolf's Avatar
Re: Need more power
I put down 500 RWHP on my auto trans with out issue but I don't beat the crap out of it either. The auto trans on our cars can hold up to 700 crank HP
CutterWolf is offline   Reply With Quote
Old 07-25-2011, 11:15 PM   #6
kickerofdoom's Avatar
The auto trans gets no respect but can hold more power then a 5 speed. The one problem is don't abuse and it will take care of you
Old 07-25-2011, 11:52 PM   #7
Thanks for the info guys,
Car isn't a DD and I'm not gonna be abusing it.... All the time!!!
Will get the mods done and see how it goes.
Old 07-28-2011, 03:39 PM   #8
If we're still talking about Mustang GT -05, they say here in Sweden that you shouldn't pass 400 HP. I think it sounds like bull****. A Mustang is a real piece of work! But what do you think? And if you tune it with a SCT flash device or likewise, to make it shift faster, good or bad for transmission or clutch? Please, share with me...
cternow is offline   Reply With Quote
Old 07-29-2011, 04:19 AM   #9
dimo's Avatar
Region: South Dakota
You'll blow the rods out of the bottom end (if it's still stock) before your tranny goes. 475-500 and up, and you're playing with fire depending on how you drive it
Grabber orange is NOT yellow!!!
dimo is offline   Reply With Quote
Old 07-29-2011, 07:36 AM   #10
Re: Need more power
Originally Posted by zombiesl4sher View Post
HI guys,
Stu.
are you saying you have 420hp with cai/pulley/tune? if so that is not accurate, not sure exactly how you are saying that though.
With pulley, intake, tune, exhaust~ you should be between 280rwhp-300rwhp in the auto... maybe 290 (depends on many factors and dyno setup and how aggressive the tune is)... or about 350-360hp at the flywheel~ something around there.
But as said your motor is usually good to 450-500rwhp (tune is VERY important here on the stock motor with a power adder)
Old 07-29-2011, 08:40 AM   #11
What do you think of the fast shifting? It feels like it shift in 0,3 sec or something. Every shift is like a kick in the back... And I don't race my car, simply a kickdown from time to time. In have never "burnt rubber" and such things. Am I a good driver then?
Old 07-29-2011, 08:46 AM   #12
Billet 62mm Throttle Body
Is this something you should have? Or is it just overrated?
Old 07-29-2011, 09:07 AM   #13
dimo's Avatar
I was more referring to if your car is boosted, how often it sees high rpm and high boost conditions. If you're only running like 8lbs and don't consistently run it to the limiter, you SHOULD be good to go
Old 07-29-2011, 09:35 AM   #14
KATO's Avatar
Re: Need more power
SpectorV is accurate in his statement here. For this amount of stuff, the HP numbers are not "Threw the roof".
Old 08-04-2011, 01:27 PM   #15
05bluestang's Avatar
Re: Need more power
Safe limit on the 4.6 is 500rwhp. Having said that I know people that blew them up with 420rwhp and also know some the run well over 500rwhp for years. It really all depends on how good your tuner is and how you drive it. If you have a lead foot and can't control yourself everytime you leave a red light or if you road race with she may go boom a lot sooner.
I was running 465rwhp for well over two years and just put long tubes on which gave me at least another 30rwhp, we'll see how she lasts.............
The weak point in our engines are the rods, they can't handle the torque.
my 0.02c HTH
---------- Post added at 03:27 PM ---------- Previous post was at 03:22 PM ----------
I looked at his sig, he has a Roush 420RE, so he's making 420flywheel HP
2005 Mustang GT, Pacesetter LT's with OR H-pipe, "Magna Pack" exhaust, Techco SC @ 9psi making 464whp & 449tq, steeda tri-ax shifter, 3D Carbon Eleanor Grill, Pioneer F90BT, FRPP 3.73 gears.
Get in, sit down, strap in, hold on, shut up!
05bluestang is offline   Reply With Quote
Old 08-06-2011, 02:29 PM   #16
my 0.02c HTH
What is rods? What do you meen?
Old 08-06-2011, 09:18 PM   #17
dimo's Avatar
The rods are what the pistons are attached to, which basically makes up the bottom end of the motor. If you're planning on going huge hp, go Aluminator rather than rebuilding the bottom end. That's what I'd do anyway
how to fix power loss? austinknoll General Mustang Discussion 8 07-26-2011 10:49 PM
Replacing Power Window Motor StreetJMusic Pre-2005 V6 Mustang 1 07-12-2011 02:45 PM
Voiding the Power train warranty dailey 2011-2014 Mustang GT 5 07-10-2011 02:31 PM
power $1000? is it possible? mhobbs 1996-2004 Mustang GT 3 07-01-2011 02:16 PM
Ford Racing Power Pack MALS Marine 2005-2010 V6 Mustang 7 06-30-2011 09:07 PM
06:48 AM
