Starting issues - Mustang Evolution
Old 08-05-2011, 11:56 AM   #1
GunMetalBullet's Avatar
Starting issues
I have an 07 GT. Drove my car home from work. Ate lunch, came out 30 mins later and the car wouldnt start. Everything electrically worked, battery was good. But nothing turned over no clicks no nothing. Any suggestions? Thanks
GunMetalBullet is offline   Reply With Quote
Old 08-05-2011, 10:41 PM   #2
bradh2414's Avatar
Check the battery cables. Make sure they're tight and clean. Could be a bad connection and the battery would still be charged
bradh2414 is offline   Reply With Quote
Old 08-05-2011, 11:00 PM   #3
gregtommy's Avatar
Send a message via AIM to gregtommy Send a message via Skype™ to gregtommy
Re: Starting issues
u may want to check your connections to your starter what I am thinking right now is possibly a starter issue or an ignition issue. Starters usually give tell tale signs when they are going bad with odd noises when you turn them over and their brushes tend to be more vocal but if you didn't have anything like that before it would most likely be an ignition issue do check your connections to your battery first like brad recommended because it could do everything but start your car because it can't draw the cranking amps it needs to turn the starter over
gregtommy is offline   Reply With Quote
Old 08-06-2011, 09:10 AM   #4
bradh2414's Avatar
Do your lights turn on but the car still wont start? Then it's the starter. If nothing check battery cables
Old 08-06-2011, 10:42 AM   #5
Thanks for the I got it to start!
Old 08-06-2011, 10:45 AM   #6
bradh2414's Avatar
What was wrong?
Old 08-06-2011, 10:24 PM   #7
gregtommy's Avatar
Re: Starting issues
yeah i am curious for the resolution as well get back to us
Window Issues - Motor or Regulator StreetJMusic Pre-2005 V6 Mustang 2 08-21-2011 12:38 PM
Different Starting Problems milkrun49 2011-2014 Mustang GT 3 07-15-2011 02:19 PM
Starting Issues bradh2414 Pre-2005 V6 Mustang 25 07-14-2011 08:43 PM
Starting my hunt for my next mustang! sonic04edge General Mustang Discussion 16 07-12-2011 07:03 PM
01 Mustang V6 having issues Mustanglife Pre-2005 V6 Mustang 29 06-25-2011 10:33 AM
10:02 PM
