Automatic launch - Mustang Evolution
Old 09-20-2011, 08:26 PM   #1
GTstang07's Avatar
Automatic launch
What is the best way to launch an auto and get the best jump? It's an 07 GT
GTstang07 is offline   Reply With Quote
Old 09-20-2011, 09:47 PM   #2
dimo's Avatar
Region: South Dakota
Re: Automatic launch
I've never tried on an auto, but I'd say hold the brake down with one foot and, using the other foot, set your revs where you want (give or take 2000-3000ish). Then let off the brake, and hammer the gas the rest of the way. If you let off the gas briefly, and then stomp on it again you can get your car to shift where/when you want I've heard
Grabber orange is NOT yellow!!!
dimo is offline   Reply With Quote
Old 09-20-2011, 10:07 PM   #3
When the car is about to shift then release the gas then floor it as it's shifting
16218 is offline   Reply With Quote
Old 09-20-2011, 10:59 PM   #4
MonteCitan's Avatar
Why would you lift off the throttle in an automatic?
Depending on setup of the car, powerbrake to bring up the converter..
Stock I'd say go to ~1400rpm, up to 1800.. wouldn't go much higher than that, my high stall converter in the regal I ran up to 2400 RPM
when the light goes green, let off the brake as quick as possible (car will lurch ahead with your current load..) then roll into the gas, depending on traction, you can either punch it immediately after, or count to 3 as you floor it (start at 1, roll pedal down, end at WOT at 3..) then hold it down and aim the car where it needs to go
with sticky tires, just floor it after
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 09-21-2011, 04:47 AM   #5
GTstang07's Avatar
I was just wondering since when I do give it full throttle I lose a lot of traction and kind of glide you know
Old 09-21-2011, 05:12 AM   #6
STall it up to about where tires are ready to break through the brakes. On the second to last yellow light release the brake and go full throttle. (delay cause auto why leaving on second to last yellow. Results in near perfect RT)
If you are not running drag radials then leave off idle or start at 1000rpms. Starting at 1000rpms if you break the tires lose and don't hook work way down in rpms. If hook work way up.
Old 09-21-2011, 06:16 AM   #7
KATO's Avatar
Interesting, but confusing, all the comments seem to differ, can someone be a litle more specific, mine is a 07 GT Auto with gears changed to 4.10, CAI and SCT tuner, what specs in the above comments do I use???
Old 09-21-2011, 06:27 AM   #8
GTstang07's Avatar
Ha I know there like all different
Old 09-21-2011, 06:46 AM   #9
I said what I did for my G8 auto with 489whp. Worked perfect every time. I cut .0XX lights.
Old 09-21-2011, 11:14 AM   #10
05bluestang's Avatar
MSD Launch control.........
http://www.msdignition.com/uploadedF...9606.pdf?n=566
Consistant launches every time..........
2005 Mustang GT, Pacesetter LT's with OR H-pipe, "Magna Pack" exhaust, Techco SC @ 9psi making 464whp & 449tq, steeda tri-ax shifter, 3D Carbon Eleanor Grill, Pioneer F90BT, FRPP 3.73 gears.
Get in, sit down, strap in, hold on, shut up!
05bluestang is offline   Reply With Quote
Old 09-21-2011, 11:20 AM   #11
all you can do it put it in drive, hold the brake and get on the gas until right before the tires start to spin. Let off and go.
Old 09-21-2011, 11:22 AM   #12
+111111111111111111111111111111
Oh also get a stall.
Old 09-22-2011, 05:47 AM   #13
KATO's Avatar
Thanks "SpectorV", that was simple and straight to the point, not all that Technical mumbo jumbo, like earlier. Always have appreciated your comments.
Old 09-24-2011, 03:00 AM   #14
MonteCitan's Avatar
The delay is because of the brain to foot interaction, if the auto is on that limiter you mentioned where the tires are about to break loose, there won't be a delay with the car - plus if you floor it at that point, the tires are just going to go up in smoke.. not recommended for best launch.. nor recommended unless you have a trans brake or aftermarket converter, no need to rev an auto car that high in D on the brake
---------- Post added at 04:00 AM ---------- Previous post was at 03:58 AM ----------
Are you sure on this?? I've drag raced automatic cars TONS (10 years now) and ALWAYS did better launching to the point the car has traction when OFF the brake, which is what happens once you lift your foot off the brake and start to go.. You want to get the car up on the converter so it doesn't flash/torque spike when you get on it, then go for it.. And in my experience, that is NOT when the car is about to start doing a burnout when you're sitting on the brakes..
Old 11-20-2014, 11:01 AM   #15
i have a v6 2014 auto, i have the shifter buttons so i leave it in first and hold the handbrake as high as it can go, while holding the button still, then keep my revs at like 2000, and when the light goes green i slam the throttle in and put the handbrake down first. works for me!
-Nicky Sheena Sixxer
xsixxerx is offline   Reply With Quote
Old 11-26-2014, 04:11 AM   #16
Or you could buy a manual
Sent from my SM-N900T using Mustang Evolution mobile app
HtownRoush is offline   Reply With Quote
Old 11-26-2014, 07:33 AM   #17
And be slower at the 1/4.
Old 11-26-2014, 08:13 AM   #18
+1
Old 11-26-2014, 10:39 AM   #19
Cbird's Avatar
Region: Iowa
+1
Cbird is offline   Reply With Quote
Old 11-26-2014, 02:02 PM   #20
Here we go again... At least it lets us know who has been to a track lol.
Sent from my VS980 4G using Mustang Evolution mobile app
Old 11-26-2014, 02:13 PM   #21
natestang07's Avatar
Why would anyone want a manual for a track? Why risk missing a shift? It is like driving around with a nail in your tire hoping it doesn't go flat lol
05 Gt Premium Performance White, flowmaster outlaws, Jlt Series 3, Bama 91r tune
Old 11-26-2014, 02:14 PM   #22
That is probably one of the worst ways you can launch a RWD car.........
Old 11-26-2014, 02:16 PM   #23
Auto for drag
Manual for corners
Old 11-26-2014, 08:43 PM   #24
Aggiesrok's Avatar
So if auto is so great and better, why do you need help. When it turns green...floor it
Chevy runs deep, don't step in Chevy.
Old 11-27-2014, 12:00 AM   #25
Not quite, especially if you have an aftermarket converter.
Old 11-27-2014, 12:04 AM   #26
Fabman's Avatar
My best launches are from just a little above idle....I am pretty consistently low 1.4's.
Tuned by AED
*694 RWHP/677 RWTQ* 10.22@136mph
Currently Assaulting California's Roadcourses
Fabman is offline   Reply With Quote
Old 11-27-2014, 12:09 AM   #27
Aggiesrok's Avatar
It was a smart *** comment.
Old 11-27-2014, 12:12 AM   #28
32GT32's Avatar
Try this got an automatic also well had turn traction off Rev to 1500k leave the car on drive and just go you should get a perfect launch if you spin leave traction on
32GT32 is offline   Reply With Quote
Old 11-27-2014, 12:35 AM   #29
Fabman's Avatar
^^^^What he said^^^^
Tuned by AED
Old 11-27-2014, 12:37 AM   #30
32GT32's Avatar
God that's ridiculous! you ran that in a 4.6 3v!!?
Old 11-27-2014, 12:39 AM   #31
Fabman's Avatar
Yup....at 4000 pounds.
Tuned by AED
Old 11-27-2014, 12:40 AM   #32
32GT32's Avatar
That's awesome what's done to it?
Old 11-27-2014, 12:45 AM   #33
Fabman's Avatar
281 stroked to a 302, stage 3 heads and cams, 1 3/4" long tubes, 3' exhaust, 2.6 KB @ 20 psi, all the good stay together stuff, electric water pump, lethal fuel system, e85, 410's tru track, TCI trans, PI converter....stuff like that.
Tuned by AED
Old 11-27-2014, 12:46 AM   #34
Fabman's Avatar
Tuned by AED
Old 11-27-2014, 12:47 AM   #35
32GT32's Avatar
281 stroked to a 302, stage 3 heads and cams, 1 3/4" long tubes, 3' exhaust, 2.6 KB @ 20 psi, all the good stay together stuff, electric water pump, lethal fuel system, e85, 410's tru track....stuff like that.
Nice I just blew the motor on my 3v don't know what I should do like what route to go I posted a thread but no one ever replied
automatic Windows S197Miller 2005-2010 Mustang GT 2 07-27-2011 05:03 PM
98 mustang gt stock automatic 98RedGT 1996-2004 Mustang GT 4 07-24-2011 11:01 PM
05:57 PM
