Nasty noise under the hood please help! - Mustang Evolution
Old 10-02-2011, 05:25 PM   #1
S197STANG's Avatar
Hey guys I've never posted anything before so bare with me. My name is David by the way n Im new to this but I need some major advice and I know you guys have a ton more experience than me anyways I have a 2008 Mustang GT and about 2 months ago I put axel back exhaust and last month i put an SCT SF3 programmer and JLT intake. I've been having a bad rattling noise I figured it was heat shields took them off wrapped them and noise is still there I have ruled out the full exhaust from the manifolds back and everything on the engine seems tight nothing loose... The rattling only comes when I put the car on a load! In fifth give it gas and it's super loud around 2 1/2 to 3 grand after that u can't hear it it's weird. The car doesn't get ran hard it's my daily driver! It keeps getting worse when I first heard it it was real light but now I I get on it, it's heard! I could be wrong but could it b bad gas making the valves float or maybe the butterfly on the throttle body making the noise? Please let me know if any of you guys have had this problem. My next step is to take it to ford! Oh and my car only Has 19,000 miles so it has me puzzled.
S197STANG is offline   Reply With Quote
Old 10-02-2011, 06:55 PM   #2
Boblisa3's Avatar
I had the same problem the hanger for the exhaust was rubbing metal to metal had to adj the mufflers.
Boblisa3 is offline   Reply With Quote
Old 10-02-2011, 08:38 PM   #3
S197STANG's Avatar
Hmm never thought to check the hangers only the exhaust piping I'll be sure to check that out tomorrow. thanks for the reply!!
Old 10-02-2011, 08:45 PM   #4
Re: Nasty noise under the hood please help!
(stress) load in fifth gear. sure it's not your motor bogging w/the trans.
jk_aktion is offline   Reply With Quote
Old 10-02-2011, 08:45 PM   #5
Artaz's Avatar
Check the parking brake cable it can come loose and make a rattle noise under a load as well
Artaz is offline   Reply With Quote
Old 10-02-2011, 08:54 PM   #6
S197STANG's Avatar
No I'm positive it's not stress like that I can have it in 3rd and 4th also and around the same RPM's it does the same exact thing. It Sounds nasty that's for sure almost like a bolt rattling..ill definitely take everything in to consideration though that's for sure. I'm going to ford tomorrow hopefully and c what they tell me thanks for you guys response
---------- Post added at 09:54 PM ---------- Previous post was at 09:52 PM ----------
Ok thanks artaz I'll definitely do that, gotta rule out everything at this point you know
Old 10-12-2011, 03:28 PM   #7
frank07stanggt's Avatar
Did u remove your cats? If so its trumpeting. I read that if you throw some resonators on it will take care of it.
frank07stanggt is offline   Reply With Quote
Old 10-12-2011, 09:16 PM   #8
David Cope's Avatar
Mine does the same but at lower rpm's in my case it turned out to be the cats vibrating the bottom of the car. Only started after I put my axel backs on
David Cope is offline   Reply With Quote
Old 10-12-2011, 09:22 PM   #9
S197STANG's Avatar
I figured it was that too but mine was all good took heat shields off and wrapped them with exhaust tape to stop the high pitch ping but that wasn't it for me. It turned out to be just bad gas and my engine sounded like straight crap. Can't ever trust gas stations!! I ended up Putting 93 octane and a octane booster been three fuel ups already back to using 87 for my street tune and everything's great!! So watchout for crappy gas!!
Old 10-27-2011, 06:58 AM   #10
bryanbrock's Avatar
05 mustang hear with the SAME problem!!!
bryanbrock is offline   Reply With Quote
Old 11-05-2011, 10:34 AM   #11
gqsmash's Avatar
and they get you with the high gas price and you get crappy gas!!!! isnt that some BS!!!!
gqsmash is offline   Reply With Quote
Old 11-05-2011, 10:59 AM   #12
deadsp0t's Avatar
When running some tunes you need to be using premium fuel, that 'pinging' is detonation and WILL destroy your engine! If you went back to 87 be very careful as it may come back!
That's unimpressive
Old 11-05-2011, 11:04 AM   #13
tylerb's Avatar
or tune your car to 87
tylerb is offline   Reply With Quote
Old 11-05-2011, 11:07 AM   #14
deadsp0t's Avatar
Yes, cause you are playing with fire.
That's unimpressive
Old 11-05-2011, 10:00 PM   #15
S197STANG's Avatar
Its Never came back my car is tuned for 87 but I never run 87...I'm aware of premature detonation and believe me when I say I'm anal about my car if I hear anything Im checking it out lol... As of right now it has not returned and it's been a couple of months!! So I'm set on it being bad gas! Thanks for you input though!!
Old 11-05-2011, 10:02 PM   #16
deadsp0t's Avatar
The thread is five days old. *confused*
That's unimpressive
Old 11-05-2011, 10:07 PM   #17
S197STANG's Avatar
It was posted October 5 or something so my bad it's only been a month but it seems so much longer I drive 100 miles round trip a day so I've been through a lot of fuel ups since then. But it hasn't returned so I'm figuring that's what it was.
Old 11-05-2011, 10:11 PM   #18
deadsp0t's Avatar
Lol I read it wrong, thought was in Nov! Hahaha glad you got straightened out!
That's unimpressive
Old 11-05-2011, 10:14 PM   #19
S197STANG's Avatar
Lol no problem and thanks for giving some input it's always greatly appreciated!!
New hood installation gregtommy General Car Discussion 10 09-18-2011 07:52 PM
Weird noise? galindojr24 2005-2010 Mustang GT 9 09-14-2011 09:27 PM
Clutch noise 02 mustang gt mkw037 1996-2004 Mustang GT 5 09-05-2011 08:14 AM
Noise help! Dnraiders 1996-2004 Mustang GT 3 08-23-2011 07:15 AM
Noise going into gears bradh2414 Pre-2005 V6 Mustang 5 07-20-2011 03:46 AM
04:24 PM
