Steeda ultralites - Mustang Evolution
Go Back   Mustang Evolution > 1979-2014 Mustang GT > 2005-2009 Mustang GT
Closed Thread
Old 10-12-2011, 11:42 AM   #1
S197STANG's Avatar
S197STANG is unknown around these parts
Steeda ultralites
Im Thinking about getting the steeda ultralites here pretty soon but I have one question....can I run stock struts and shocks for the mean time? I know it will probably be better if I bought new ones but I was just wondering if I could? Also for this drop are camber bolts a must? Or will they be able to align with out them?
S197STANG is offline
Old 10-12-2011, 08:09 PM   #2
GTRob504's Avatar
GTRob504 is unknown around these parts
You really should consider replacing the springs ,shocks, struts and upper strut mounts all at the same time , simply because of the level of effort and that stocks shocks aren't going to give a the best ride with those springs. You will need at least camber bolts , and the toe in will have to be adjusted.
Don't forget an adjustable pan hard bar to re-center the body over the rear axle, lowering can throw it off by up to a half inch to one side.
2008 Metallic Alloy GT Convertible Premium
Show : black top| 18" bullitt polished wheels| CDC light bar and black billet replacement grilles | black/amber corner lights | GT500 rear spoiler| AH chin spoiler Go: FRPP CAI with StangHi tunes | Kooks LT's | FR500 axle back | Steeda Sport springs | Koni STR.t struts/shocks | J&M camber plates | UMI adj. panhard bar | LCA relocation brackets | GT500 LCA's | Hurst Billet shifter | 3.73 gear | FRPP axle girdle | Baer Rotors and Pads
GTRob504 is offline
Old 10-12-2011, 08:27 PM   #3
S197STANG's Avatar
Dang I didn't know it would throw it off that much with that small of a drop I figured only after 1.5 -2" drop would do that! Thanks for the insight and I'll definitely consider getting all of it. I'm confused on why the toe would be thrown off I've never had that happen on any of the vehicles I've lowered but I'll definitely make sure the alignment place give me the specs on everything they did and make sure they check that out! Thanks again
Old 10-12-2011, 10:01 PM   #4
tigercrazy718's Avatar
tigercrazy718 is unknown around these parts
Re: Steeda ultralites
it shouldnt throw it off that much. you should be fine with camber bolts for now, but it will cause some excess wear on your tires. the drop on those springs (i have them) arent that low so its really not insane. but i highly suggest you get new shocks and struts ASAP, bc they make you car a whole different beast
2008 V6
204 RWHP
If you wreck and kill yourself trying to jerk off on the way to her house I will put it all over the internet.
tigercrazy718 is offline
Closed Thread
Steeda Tri ax short shifter install..... rinfield2004 SVT Mustang 10 09-02-2011 12:40 AM
Shift knob problem with steeda tri-ax apex32 2010-2014 Mustang GT 5 06-29-2011 01:04 PM
12:26 PM
