2005 mustang gt door locks will unlock but not lock!?!? - Mustang Evolution
Old 10-20-2011, 10:16 PM   #1
bryanbrock's Avatar
Exclamation 2005 mustang gt door locks will unlock but not lock!?!?
who wants to play lets fix this problem!! ok need your help its a 05 mustang GT locks will unlock just fine, WILL NOT LOCK WITH TRANSMITTER or even WHEN PUSHING IN CAR LOCK SWITCH. horn does honk and theft does activate if you have all ready addressed this on your mustang I would appreciate your help. thanks Bry
bryanbrock is offline   Reply With Quote
Old 10-21-2011, 08:02 PM   #2
OmegaRedGT 2007's Avatar
Take the door switch panelapart and ensure the plugs are connected, use a line tester to see if the switch is getting power from the battery,also check the fuses.
OmegaRedGT 2007 is offline   Reply With Quote
Old 10-21-2011, 08:44 PM   #3
Blogger
99ford's Avatar
Re: 2005 mustang gt door locks will unlock but not lock!?!?
I would suggest what OmegaRed said to try. It could be the battery is getting weak or the plug came loose somehow. It might be a fuse, that is worth checking also.
EDIT: Also, have you tried replacing the Remote batteries? You may want to do that as well. Check all the connections and fuses and lines to be sure.
Old 10-23-2011, 12:27 PM   #4
bryanbrock's Avatar
batterie is in great shape, just took the door cards off and the connections check just fine. the only thing I can come up with that can possibly make sense would be that it has two seporate actuators ...one for lock function and one for unlock function. its deffinatly not the remote as it works just fine and like I said before the switch in the car will work the unlock function but not the lock function for both doors ......agin recap inside the car both door swiches are getting power and are connected properly, both will unlock the car but both will not lock the car, same with the remote every function works prefictly except the lock function the car will honk and theft does activate just the locks will not actuate ......so im thinking its some kind of overcomplicated duel cylanoid problem were one half functions the lock actuation and the other half actuates the unlock function.
Old 10-23-2011, 09:18 PM   #5
Blogger
99ford's Avatar
batterie is in great shape, just took the door cards off and the connections check just fine. the only thing I can come up with that can possibly make sense would be that it has two seporate actuators ...one for lock function and one for unlock function. its deffinatly not the remote as it works just fine and like I said before the switch in the car will work the unlock function but not the unlock function for both doors ......agin recap inside the car both door swiches are getting power and are connected properly, both will unlock the car but both will not lock the car, same with the remote every function works prefictly except the lock function the car will honk and theft does activate just the locks will not actuate ......so im thinking its some kind of overcomplicated duel cylanoid problem were one half functions the lock actuation and the other half actuates the unlock function.
Don't over complicate things. The door lock actuator is probably bad then. 05's are notorious for electrical problems. Shouldn't be too much money.
Old 10-24-2011, 06:12 AM   #6
bryanbrock's Avatar
anybody have any clue ware they are located?
Old 10-25-2011, 03:02 PM   #7
MC770's Avatar
They should be behind the door panel pretty close to directly under neath the locks if not lower
~2003 Zinc Yellow Terminator Cobra~
~482 RWHP / 487 LBS Torque~
MC770 is offline   Reply With Quote
Old 10-25-2011, 09:51 PM   #8
Blogger
99ford's Avatar
^ Yes! It seems like the most logical place for them.
Old 10-26-2011, 02:54 PM   #9
bryanbrock's Avatar
I know what you are talking about and no thats not it. maybe on an older car and yes I have had to replace one of those before on my 15yr old honda. This is ONE single unit of some sort that works the lock function for BOTH doors private message me and I will give you my phone number if you want to help trobleshoot this.
Old 10-29-2011, 11:01 PM   #10
Region: Hawaii
Check your connectors and make sure you are getting power to the panels/switches if it is getting power then the switch panels arw bad
Jacobslair is offline   Reply With Quote
2005 mustang
1969 Mustang Coupe Restoration Project yellow99 Classic Mustangs 5 10-15-2011 10:05 AM
1995 Mustang SVT Cobra Project yellow99 1979-1995 Mustang GT 0 09-03-2011 05:51 PM
1971 Mustang Fastback Project yellow99 Classic Mustangs 0 09-03-2011 05:49 PM
05:41 PM
