Shifter! - Mustang Evolution
Go Back   Mustang Evolution > 1979-2014 Mustang GT > 2005-2009 Mustang GT
Closed Thread
Old 11-04-2011, 10:27 AM   #1
OutlawGT's Avatar
OutlawGT is unknown around these parts
Shifter!
I just got a shifter for my 07 gt and I'm wondering how hard is it to DIY is it worth it?
OutlawGT is offline
Old 11-04-2011, 10:45 AM   #2
Y2E0L0L5OGWT's Avatar
Y2E0L0L5OGWT is unknown around these parts
Re: Shifter!
It's not a bad install at all. I think it took me about an hour, most of which was spent trying to figure out how to get the shifter's in/out around the transmission. It's only about (4) bolts to deal with, but there isnt a lot of space to work in.
Y2E0L0L5OGWT is offline
Old 11-04-2011, 10:51 AM   #3
frank07stanggt's Avatar
frank07stanggt is unknown around these parts
Its very easy. As mentioned above it will take youlonger to get angle just right to get the old shifter out of the hole.
frank07stanggt is offline
Old 11-04-2011, 01:06 PM   #4
sinister07's Avatar
sinister07 is unknown around these parts
Probably the most rewarding mod you can make. You will love it.
2003 Mach 1
sinister07 is offline
Old 11-04-2011, 01:22 PM   #5
Terminator Owner
SpectorV is just getting started.
Re: Shifter!
I helped a friend put his in (08 GT mgw shifter) it was pretty easy, couple bolts were hard to get to, you dont HAVE to take the transmission cross brace off and lower it down but it can help. Just read the directions, if the directions are crappy then you shouldnt have purchased that shifter
SpectorV is offline
Old 11-04-2011, 02:45 PM   #6
OutlawGT's Avatar
I was told 600 by a shop and 500 from another and iv pulled motors and other things I knew it wasn't that big of a deal can you do it with out a lift like If I put it up on jack stands
OutlawGT is offline
Old 11-04-2011, 03:11 PM   #7
Blackandorange's Avatar
Blackandorange is unknown around these parts
I just finished installing mine. Used jack stands and no problems. Getting the shifter out and in is the hardest part like the others mentioned, but once it out it's easy!
---------- Post added at 04:11 PM ---------- Previous post was at 04:10 PM ----------
Save the money for something else instead of paying that much to have it installed
Blackandorange is offline
Old 11-12-2011, 11:49 AM   #8
Always broke's Avatar
Always broke is unknown around these parts
When I got my hurst shifter the directions to pull it up through the hole in the car which is a lie. I have drop it down to the ground pass the transmission.
Always broke is offline
Old 11-12-2011, 12:08 PM   #9
Well that's how you are "supposed" to do it. Drop the drive shaft andnpull it up. Buuuut how everyone does it is to wiggle till you get the perfect angle and put it in from the inside of the car.
Old 11-12-2011, 12:27 PM   #10
OutlawGT's Avatar
I dropped the tranny 3 in and dropped the shaft an just pulled it out underneath I had the car up on stands it was very easy
OutlawGT is offline
Old 11-13-2011, 01:37 PM   #11
I did not drop my drive shaft. When I read the instructions for my hurst shifter it said wiggle the new shifter into the hole. When they said put the shifter through the hole. They ment you have to go below the car and lift the new shifter into position.
Old 11-13-2011, 04:16 PM   #12
OutlawGT's Avatar
It was easier for me so I had room plus my car only has 14k so the bolts wasn't rusted shut
OutlawGT is offline
Old 11-15-2011, 03:45 PM   #13
Sirtat's Avatar
Sirtat is unknown around these parts
I just put my car on my hoist and did it from underneath... I don't know how anyone could do it from inside the car because getting at the bolts would be a B. In my opinion is the roush racing short throw shifter. IMO
IBLT IT
2005 Promar Performance forged long block
Kenne Bell 2.8L LC mammoth supercherger
and and and I DRIVE IT LIKE I STOLE IT !!!!
http://www.youtube.com/watch?v=_K_QJ...ure=plcp<br />http://www.youtube.com/watch?v=NWfvYVYlfio&feature=plcp
Sirtat is offline
Old 11-16-2011, 06:22 AM   #14
They weren't too bad at all. Just jacked the front end up, slid under and un-bolted them. But you got it done so that's all that matters.
Old 11-17-2011, 04:33 AM   #15
blackhawk 1's Avatar
blackhawk 1 is unknown around these parts
Re: Shifter!
i love my hurst shifter
blackhawk 1 is offline
Old 11-17-2011, 04:46 AM   #16
Ninjasteffers's Avatar
Ninjasteffers is unknown around these parts
+1
Ninjasteffers is offline
Old 11-17-2011, 09:43 AM   #17
OutlawGT's Avatar
Which hurst did u get? Billet pro or comp
OutlawGT is offline
Old 11-18-2011, 11:47 AM   #18
Billet plus-I'm too cheap for loctite I'm always tighting the nuts on the shifter to the car. LoL
Old 11-25-2011, 08:14 PM   #19
GTRob504's Avatar
GTRob504 is unknown around these parts
I love my Hurst billet shifter. Best mod for 200$
2008 Metallic Alloy GT Convertible Premium
Show : black top| 18" bullitt polished wheels| CDC light bar and black billet replacement grilles | black/amber corner lights | GT500 rear spoiler| AH chin spoiler Go: FRPP CAI with StangHi tunes | Kooks LT's | FR500 axle back | Steeda Sport springs | Koni STR.t struts/shocks | J&M camber plates | UMI adj. panhard bar | LCA relocation brackets | GT500 LCA's | Hurst Billet shifter | 3.73 gear | FRPP axle girdle | Baer Rotors and Pads
GTRob504 is offline
Old 11-27-2011, 09:36 PM   #20
05bluestang's Avatar
05bluestang is unknown around these parts
Re: Shifter!
I id my steeda on jack stands and ramps, no need to drop the driveshaft. Its a little bit a pain to get to the front nut but other then that no problems. Make sure you use blue tradlocker when you put it back together.
2005 Mustang GT, Pacesetter LT's with OR H-pipe, "Magna Pack" exhaust, Techco SC @ 9psi making 464whp & 449tq, steeda tri-ax shifter, 3D Carbon Eleanor Grill, Pioneer F90BT, FRPP 3.73 gears.
Get in, sit down, strap in, hold on, shut up!
05bluestang is offline
Old 11-28-2011, 05:42 AM   #21
Southern stang is unknown around these parts
I've done both my upr, and tri ax on jack stands without dropping the drive shaft. Can't wait to try an mgw haha.
2005 Redfire GT - Mac LT's/prochamber, Pypes mid muffler, FRPP hotrods, 4.10's, Steeda tri-ax, JLT CAI, Bama tuned, Nitto nt05's 333/327 dynojet A little go go juice too
Southern stang is offline
Closed Thread
T-5 shifter bushing jwhayne0001 1979-1995 Mustang GT 12 10-22-2011 10:38 AM
auto shifter cable to steering wheel. Black_Sunshine Pre-2005 V6 Mustang 4 10-02-2011 06:54 AM
2012 Mustang GT/CS with Barton Shifter Dustin2006 2010-2014 Mustang GT 27 08-29-2011 10:40 PM
Short Throw Shifter bmabbott Pre-2005 V6 Mustang 11 08-17-2011 03:03 PM
Shifter advice Qwik Four Six 1979-1995 Mustang GT 8 07-08-2011 08:58 AM
04:50 PM
