Roush CAI - Mustang Evolution
Old 11-07-2011, 07:48 AM   #1
Roush CAI
I just installed a Roush CAI on my 06 GT and now its not wanting to stay running. Either not enough fuel or air, or Mass air flow sensor, vaccum hose. Not sure what to do next to fix the problem.
Anyone came across this problem and find the solution
Thanks
06Stanger23 is offline   Reply With Quote
Old 11-07-2011, 08:17 AM   #2
Re: Roush CAI
make sure you hooked up everything correctly, did you install a tune with it? I am betting its required, it is on most at least.
Old 11-07-2011, 08:34 AM   #3
Re: Roush CAI
I am 99% sure everything is hooked up right. What kind of tune do i need with it. Its a 06 Roush stage 1.
Old 11-07-2011, 08:42 AM   #4
Y2E0L0L5OGWT's Avatar
Re: Roush CAI
It's not staying running because you need a tune. With the added air from the CAI, the car is running lean. You will need a tuner (such as SCT or Diablosport) with a pre-loaded tune on it that you plug into the port under the dash on the driver's side. You will have to contact a place like American Muscle (or similar) to get a tuner & preloaded tune(s). It will run you an additional $300-400 I believe.
Old 11-07-2011, 10:12 AM   #5
KATO's Avatar
Re: Roush CAI
You say it's already a Roush stage one setup? Who did the CAI Install?? Is the MAF plugged in?
07 GT. SCT: CUSTOM TUNE by "MUSTANG SPECIALTIES". LMR: GEN2 2010 STYLE HEADLIGHTS, RAXIOM: 2010 SMOKED COYOTE TAIL LIGHTS, WHEELS: STAGGERED WHL 22X8.5F-22X10R.
Old 11-07-2011, 10:33 AM   #6
Re: Roush CAI
I put on the CAI and yes the MAF is plugged in. It ran better when it was unplugged though. I might have dropped the MAF during install of the CAI but like two ft drop, not sure how breakable the MAF's are but when I unplug the MAF it runs a little better and does not die out. I plug the MAF in and it wants to die out. Roush did not say you need a tuner for the CAI but they were not really clear either. Why would they sell a CAI w/o a tuner if you need it for your application to run properly? Anyone want to sale their tuner $$$ ???. Not even sure that is the problem. Any help?
Old 11-07-2011, 11:26 AM   #7
Yes the preload tune is SF3 part # 3015 I have it
2003CobraSvt is offline   Reply With Quote
Old 11-07-2011, 11:32 AM   #8
Re: Roush CAI
How much you want for it.
Does everyone need a tuner for a CAI??
Old 11-07-2011, 11:43 AM   #9
Re: Roush CAI
For 05+ Models, yes.
It's not as simple as someone "selling" you their tune. You MUST have the handheld tuner device to load the tune ot your car's ECU. Once you've loaded the tune to your car, the handheld device will data-log your stock tune & the device will be "locked" to your car until it is reset to "stock". The following links direct you to GREAT handheld tuner products:
SCT SF3/X3 Power Flash Tuner w/ 3 Free Custom Tunes (05-10 GT) - SCT 3015||38018
DiabloSport 2005-2006 Mustang Tuner at AmericanMuscle.com - Free Shipping!
I personally prefer the SCT product better. Also, I HIGHLY recommend you call a reputable company, such as American Muscle to walk you thru any potential questions you have. Also, with AM, you get free tunes for life, that you can have updated for each performance mod you do in the future.
Old 11-07-2011, 02:48 PM   #10
frank07stanggt's Avatar
Is ur mass air meter facing the right way?
frank07stanggt is offline   Reply With Quote
Old 11-07-2011, 07:50 PM   #11
^^^agreed sounds like you may have put the maf sensor back in backwards.
FordTech is offline   Reply With Quote
Old 11-07-2011, 08:39 PM   #12
Don't panic. Put it back together and order the tuner with the tune. AM will know what to do and when it comes reinstall and add the tune. You'll need the tuner for future tunes. You'll love it
Bobby is offline   Reply With Quote
Old 11-07-2011, 08:44 PM   #13
tylerb's Avatar
you don't need a tune with roush CAI
tylerb is offline   Reply With Quote
Old 11-08-2011, 06:39 AM   #14
KATO's Avatar
Re: Roush CAI
Interesting question below from "frank07stanggt" and "FordTech", about if you put the MAF back in, in the correct position?
Old 11-08-2011, 09:18 AM   #15
Re: Roush CAI
The arrow is pointing towards the throttle body so I think its in the right position. I thought Roush didn't need a tuner. But I am still going to order one just for other mods I am wanting to do. I think its the MAF sensor from when I droped it. Any difference in any of the MAF i can order. Or just get the cheap one from auto store.
Old 11-08-2011, 09:24 AM   #16
KATO's Avatar
Re: Roush CAI
Maybe someone else can chime in on this, cause I'm lost for words on this issue. I would not think a small fall like this could damage it, but maybe you are right about that.
Old 11-09-2011, 03:59 PM   #17
S281's Avatar
Re: Roush CAI
You probably could damage it by dropping it. There's very fine wires in there, could of broke one. If you know someone with a Mustang try theirs, takes 5 minutes to change.
S281 is offline   Reply With Quote
Old 11-10-2011, 01:31 PM   #18
And if it works just keep driving as you say sorry sucka. Lol
Old 11-10-2011, 02:49 PM   #19
Eturner's Avatar
Or you can just wait for your tuner to arrive and do a diagnostic check with it...
Old 11-10-2011, 03:02 PM   #20
Beav's Avatar
Re: Roush CAI
Roush CAI (normally)do not require a tune, but you sure won't get the maximum benefit from it without one...
07 Roush 427R, Brembo 14" rotor and four piston calipers
05 GT Mustang, FRPP, FR X pipe, Hurst short throw,
American Racing Torque Thrust 10X20 wheels,
Granettelli tower brace, custom painted flat black grafix, Yellow Optima
Beav is offline   Reply With Quote
Old 11-18-2011, 09:03 AM   #21
Re: Roush CAI
So i was wondering what bolt-ons are best for horsepower.
Old 11-18-2011, 11:18 AM   #22
bullitt1075's Avatar
Send a message via Skype™ to bullitt1075
Without a tuner you won't see the full advantages of any bolt on. So I would go with a tuner first.
Proud owner of Bullitt #1075
bullitt1075 is offline   Reply With Quote
Old 11-18-2011, 12:03 PM   #23
Re: Roush CAI
So with a tuner, you have to get it programmed by AM or another company. You cant do it yourself. What does a tuner do, I know it reprograms the computer for more HP and fuel eco. Are the computers programmed down that much that you will notice that much more HP.
Old 11-18-2011, 01:41 PM   #24
The short answer is yes. Fords factory tunes are very conservative and they leave a good amount of hp on the table. Tuners come pre-set with tunes, but companies like BAMA are able to squeeze out more, and with guaranteed tunes for life you can't go wrong with BAMA.
cai
roush vs jlt/steeda godsdisciple85 2011-2014 Mustang GT 9 10-08-2011 08:08 AM
Clear bra for Roush bumper poloka 2011-2014 Mustang GT 19 09-25-2011 09:21 PM
roush cai vs jlt/steeda cai godsdisciple85 General Mustang Discussion 0 09-20-2011 09:34 AM
Fuel gauge not working after CAI install. Hellraisen 1996-2004 Mustang GT 0 09-14-2011 07:58 AM
08:03 AM
