Good Vibrations!? - Mustang Evolution
Old 11-12-2011, 05:54 AM   #1
Wolfsbain76's Avatar
Good Vibrations!?
Hey guys,
I'm starting to notice even more, that while stopped or at a red light, that the car does this vibrating on and off every few seconds, and it's getting really annoying. The only way to get the car to stop is by putting it in Neutral. Anybody know what this could be, and, does it mean that something is wrong? No Engine light or any other light is on. Thanks!
2007 Mustang GT
Wolfsbain76 is offline   Reply With Quote
Old 11-12-2011, 11:18 AM   #2
Could either be your motor mounts or exhaust hangers hitting One of the brackets. Check those out first and let us know!
2005 Redfire GT - Mac LT's/prochamber, Pypes mid muffler, FRPP hotrods, 4.10's, Steeda tri-ax, JLT CAI, Bama tuned, Nitto nt05's 333/327 dynojet A little go go juice too
Southern stang is offline   Reply With Quote
Old 11-13-2011, 03:08 PM   #3
Re: Good Vibrations!?
Will check and report back, Thanks!
2007 Mustang GT
Old 11-13-2011, 03:15 PM   #4
Camo1967Mustang's Avatar
It could also b ur rpms
My baby does tht sometimes when her rpms drop
Adrian
2001 Mustang
--AM CAI, BBK Headers, Dual exhaust, Billet grille, hood and side scoops, Sequential tail lights,
AM Headlight covers, Fog lights, Chin spoiler, H&R Lowering Springs, KYB Shocks and Struts
January 2012 StangAlley ROTM
Camo1967Mustang is offline   Reply With Quote
Old 11-13-2011, 03:49 PM   #5
jmpark527's Avatar
Did you hear some vibrating sound from backside?
Today I heard something vibrate at the rear side...
I can't find the vibrating spot and also it vibrates not specific time... like starting or high rpm or low rpm...
jmpark527 is offline   Reply With Quote
Old 11-13-2011, 04:36 PM   #6
Could it be your exhaust tips up against your bumper somehow? I had to get mine fixed.
Old 11-13-2011, 05:42 PM   #7
jmpark527's Avatar
I checked but it seems no problem with that...
A week ago i changed exhaust to stock one. I thought it might be that problem but i cant find any fault..
Old 11-25-2011, 09:46 AM   #8
This! At low RPM's. And when I started it the other day, it almost stalled out. But mostly at low RPM's. I have no clue to what to look for, could it be:
1. Motor Oil...in my mind it may have something to do with the motor oil. I have regular oil changes—could the oil be a winter-capable oil? Low temperatures do amazing things to your car's engine oil, altering its viscosity and making it harder to serve its purpose.
2. Did the SCT Tuner do something that the computer/engine didn't like?
3. O2 sensor, clogged fuel lines, vacuum leak, intake leak?
4. cylinders not firing?
I'm not a mechanic and have no clue what to look at under the hood. Please, any help would be great.
2007 Mustang GT
Old 11-25-2011, 10:29 AM   #9
BlueOval77's Avatar
My first guess would be the motor mount(s) as well. Is there any hesitation in acceleration when you step on the gas? It's not your oil. You can do a compression test on your cylinders to see if any are bad - a bad cylinder will cause your idle speed to fluctuate.
BlueOval77 is offline   Reply With Quote
Old 11-25-2011, 10:53 AM   #10
Thanks for your input. There is no hesitation in acceleration. Motor mounts are also good. Perhaps an injector cleaner...I've read that it should be done after every oil change, and that Ford recommends Chevron Techron. How do you do a compression test?...Guess I'll just Google it! lol.
2007 Mustang GT
Old 11-25-2011, 11:01 AM   #11
BlueOval77's Avatar
Buy a compression gauge from your local auto parts store and grab a buddy to help you test. Remove your spark plugs and screw in the gauge in each plug hole. When it's in, have your pal crank the motor for a few seconds and record the reading on the gauge. Do this for all 8 cylinders and then compare the results to whatever the manual states is normal for your engine. Google's always good and I bet there's something on you tube as well if you're still unsure; but it's really a very easy process.
Good morning! GoldenPonyBoy 2005-2010 V6 Mustang 18 11-12-2011 06:37 AM
Whats a good price tbonestang 1979-1995 Mustang GT 3 10-21-2011 02:20 PM
Good looking 18s? TommyTsunami88 General Car Discussion 4 09-13-2011 04:45 AM
Good shop pranks derekb_ The Bar 10 08-31-2011 11:22 AM
fast blinker - lights all good sattwood General Mustang Discussion 2 07-04-2011 08:01 PM
07:53 PM
