How much would a bottom end cost to be built.? - Mustang Evolution
Old 12-01-2011, 10:13 PM   #1
08GTsleeper's Avatar
See I got a m90 roush supercharger hot rod cams kook longtube headers roush x-pipe and roush extreme catback exaust. I'm pushing 530 HP and 430 wrhp. I don't want to push anymore especially since the bottom end won't hold up till its built.
08GTsleeper is offline   Reply With Quote
Old 12-01-2011, 10:23 PM   #2
DaBluedude's Avatar
Parts alone will run you a minimum of 1500 ish for a decent kit. You could run that well over 5k if you decide to go overboard tho...
2003 Mach 1
Old 12-01-2011, 10:26 PM   #3
Maybe around 3k. I will look into it.
Old 12-02-2011, 07:44 AM   #4
Re: How much would a bottom end cost to be built.?
all depends on how much power you want it to handle...rotating assmeblies run about 1500 or so depending where you get it... i have some scat h beam rods with arp bolts laying around along with some brand new in the box standard bore custom cp pistons and rings(about stock compression)...or look into a dss racing short block...good shortblock to handle 1000rwhp is about 3500..
slow02gt is offline   Reply With Quote
Old 12-05-2011, 12:34 PM   #5
Sirtat's Avatar
This is the long lock engine I purchased from PROMAR Engines that came with an unlimited mileage warranty and I'm currently running 18psi
>>> Factory 05 mustang 3v core
>>> Icon Forged 3V pistons 8.9:1 CR
>>> Hastings File Fit Stainless Steel Rings
>>> Clevite H series Bearings
>>> FeLPro Gaskets
>>> Scat 4340 Forged H Beam rods with ARP 2000 Bolts
>>> Eagle 4340 Forged 8 Bolt Crankshaft
>>> New Ford VVT Gears
>>> 3 angle valve job
>>> Balanced Rotating assembly
>>> Melling HV Oil Pump
>>> Cloyes Complete Timing Set
>>> New Melling Lifters
>>> New OE TTY Head Bolts
Total was $5700
IBLT IT
2005 Promar Performance forged long block
Kenne Bell 2.8L LC mammoth supercherger
and and and I DRIVE IT LIKE I STOLE IT !!!!
http://www.youtube.com/watch?v=_K_QJ...ure=plcp<br />http://www.youtube.com/watch?v=NWfvYVYlfio&feature=plcp
Sirtat is offline   Reply With Quote
rear end said, "F&$k it!" rinfield2004 SVT Mustang 8 11-18-2011 12:30 PM
4.6 bottom end rebuild. Ideas please SonicBlueGT9963 1996-2004 Mustang GT 10 10-31-2011 07:12 AM
95 8.8 5Lug Rear End into 87 5.0 Fox mcdonaldnick 1979-1995 Mustang GT 2 10-12-2011 06:03 PM
Best top end combo? Whiterocknotch 1979-1995 Mustang GT 5 07-26-2011 10:23 AM
11:23 AM
