TR-3650 transmission upgrade? - Mustang Evolution
Old 12-06-2011, 10:51 AM   #1
CZYFAST's Avatar
Well I am just wondering if anyone would know about upgrading the TR-3650 or just going with the TKO 500? I have been looking into all this and I would like to get the TKO 600 but it's a 26 spline input and my current clutch is a 10 spline Exedy mach 600 so I would like to keep the current setup but I need a stronger transmission so I'm just wondering if upgrading the 3650 for 1,100 dollars or spending the money for the TKO 500 for 2,100 dollars? The big thing is I would like to be at least in the 550 and 600 hp so I need a transmission that will hold up to that abuse? Any info or insight would be much appreciated!
IN SALEEN WE TRUST!!!
CZYFAST is offline   Reply With Quote
Old 12-06-2011, 11:05 AM   #2
351mustanggt's Avatar
the tko 600 takes up to 600 ftlbs of torque and unless your build of 500 hp was built for more torque than hp the tko should be good for it
351mustanggt is offline   Reply With Quote
Old 12-06-2011, 11:15 AM   #3
CZYFAST's Avatar
Ok but the TKO 600 is a 26 spline and I don't really have the money for that trans. And a new clutch kit since my clutch kit has less then 8,000 miles so can you upgrade to tko 500 to handle more torque
Old 12-06-2011, 11:19 AM   #4
the tko 500 will hold 500 ftlbs
Old 12-06-2011, 11:22 AM   #5
CZYFAST's Avatar
Is their an upgrade for it to handle more or would the 600 be my only option or can you upgrade the 3650 with better syncros and shift forks?
Old 12-06-2011, 02:40 PM   #6
Gil_T2's Avatar
Re: TR-3650 transmission upgrade?
The upgrade always includes the 26 spline
BBK LT's, Catted Xpipe, Sniper tune, UDP's GT500 TB, Ford Racing CAI, CM delete, 4.10, TR6060, 1 piece DS
Gil_T2 is offline   Reply With Quote
Old 12-06-2011, 02:49 PM   #7
CZYFAST's Avatar
So if I upgrade the 3650 or the TKO 500 it comes with the 26? I know you can upgrade the 3650 and keep the 10 spline but just wondering about the torque max would be?
Old 12-06-2011, 02:55 PM   #8
Gil_T2's Avatar
10 spline can't take it, if you search you will find those shafts shear off. I have seen them break on cars with bolt-ons and slicks
Old 12-06-2011, 03:16 PM   #9
CZYFAST's Avatar
Alright well that's a lot to think about and will give something to look into thank you!
Old 12-06-2011, 04:44 PM   #10
Gil_T2's Avatar
just install a tr6060
Old 12-06-2011, 04:50 PM   #11
oh nice ive never seen the tr6060 should make a good mpg car also
Old 12-06-2011, 05:10 PM   #12
93slowstang's Avatar
The tr6060 is a beefed up t56.
Old 12-06-2011, 05:16 PM   #13
is it the same as the t56 magnum?
Old 12-06-2011, 05:32 PM   #14
Pretty much, they changed a few internals but not the gears. The t56 is supposed to handle 450 lbs tq and the tr6060 is supposed to handle 600.
Old 12-06-2011, 07:43 PM   #15
CZYFAST's Avatar
So if you upgrade the TR3650 with the package does the max torque it can handle go up because I've tried researching as much as I can and guys have said they upgraded the TR3650 and have been running 550 to 600 ft/lbs and not having a problem so just wondering if it would be worth doing the upgrade so I can keep everything the same and not change my clutch kit to the 26 spline if I don't have to yet?
Old 12-06-2011, 08:10 PM   #16
Gil_T2's Avatar
Call the companys that do the upgrade and ask !
Old 12-06-2011, 08:52 PM   #17
CZYFAST's Avatar
^ +1
Old 12-15-2011, 08:34 PM   #18
nathannp's Avatar
Go to promotion performance they build the strongest Transmissions out there. I have a gt and it has the t3650 in it and I upgraded the clutch input shaft and the line from the master cylinder. My car works perfect I race every other weekend and I launch my car at 5800rpm cut 1.61" times and on a full slick so upgrade it
nathannp is offline   Reply With Quote
Old 12-16-2011, 08:30 AM   #19
CZYFAST's Avatar
Thanks ill look into that! That's refreshing to know you can upgrade it
Old 12-16-2011, 08:46 AM   #20
deadsp0t's Avatar
D&D performance or G-Force.
That's unimpressive
Old 12-16-2011, 11:15 AM   #21
nathannp's Avatar
I went with the ram Powergrip hd 26 spline shaft high flow line and my car is better then new it's 390 for the shaft
ID:	36017   Click image for larger version
Old 12-16-2011, 11:22 AM   #22
DaBluedude's Avatar
Tr is the transaxle boxes for the vette..
U want the viper/shelby spec tremec boxes ?t6061? Dunno what numbers were up to but yeah I would def say OP should find a 6 speed built for big power rather than a mild upgrade tko500...
2003 Mach 1
Old 12-20-2011, 04:27 PM   #23
Gil_T2's Avatar
They are all called tr6060's main case is all the same except for the viper that has extra fittings for fluid pump. different mid-plates for vette, CTX's integrated bell housing for ford, chevy. These are basically beefed up T-56's Easy swap into s197, need only 26 spline clutch, cross member, shifter,
Auto to 5 speed swap 2002Gt 1996-2004 Mustang GT 81 06-16-2014 04:28 AM
6 spd. transmission in Mustang GT made in China Mercedez L. 2011-2014 Mustang GT 24 01-11-2012 08:49 PM
Choosing a tranny? Hawk General Mustang Discussion 0 10-08-2011 07:41 PM
transmission oil change!!!!! secomejia 1996-2004 Mustang GT 9 10-04-2011 08:07 AM
Transmission problem carlgator 1979-1995 Mustang GT 1 08-14-2011 09:52 PM
02:59 AM
