ELECTRONIC TRANS. - Mustang Evolution
Old 12-07-2011, 06:05 AM   #1
KATO's Avatar
ELECTRONIC TRANS.
I have two questions to be answered in 2 or 3 parts, something I'v wondered for awhile: 1) TCS (traction control system), with this button on Off, what is state of the car in? the performance? the miledge? 2) OVERDRIVE button OFF, what is the state of the car? what is the performance? what is the miledge? I usually have these buttons Off, but when I get ready to Move or Open it up I usually turn them Off. Let me know what all of you think.
Old 12-07-2011, 10:25 AM   #2
Y2E0L0L5OGWT's Avatar
Re: ELECTRONIC TRANS.
1. Traction Control (TCS): Essentially an electronic module that determines wheel slip/spin. As a tire loses traction, TCS essentially reduces power to that wheel until it regains traction. It has no effect on MPG's. TCS is essentially a safety feature inteded to "idiot proof" the car; however, for anyone that does any type of racing or has track experience, TCS can be dangerous as you generally want more throttle to control the car rather than less. If you ever watch racing on tv, you'll notice that 99.9% of the time drivers give more gas when the car goes into a slide rather than letting off. However, most of the general public doesn't understand, nor do they care, about car control, so TSC is intended to protect them from themselves.
2. Overdrive (OD), it's essentially an extra gear on the transmission. At highway speeds, it reduces the gearing of the car to improve efficiency. A 5-spd OD tranny is a lot like a 6-spd non-OD tranny. If you're cruising down the highway with OD off in 5th gear, you're probably turning more RPM's than necessary which in turn decreases your MPG.
Old 12-08-2011, 05:25 AM   #3
KATO's Avatar
Thanks for that reply "Y2EOL5OGWT", you are the only one that did reply back to me, the definitions you use to explain that, I kinda thought so myself but was not sure if there was some sort of trick way to use those at your benn. Thanks again.
Hose by trans. ?? Taxman 1979-1995 Mustang GT 2 12-03-2011 07:06 PM
Auto trans tune StangSims39 1996-2004 Mustang GT 5 11-12-2011 02:47 PM
trans mount rix71gt 1996-2004 Mustang GT 8 09-17-2011 03:02 PM
Trans Downshift Jolt crkmonzo 1979-1995 Mustang GT 3 08-16-2011 08:35 PM
06:20 AM
