Nitrous Question - Mustang Evolution
Old 12-07-2011, 03:27 PM   #1
OmegaRedGT 2007's Avatar
Nitrous Question
Today while on the highway i ran my nitrous and a flame shot out the side of the hood at driversude hinge...the bottle was full 1000psi ,i punched at 3300 rmp,has anyone had or seen this.
OmegaRedGT 2007 is offline   Reply With Quote
Old 12-07-2011, 03:34 PM   #2
Blackcat's Avatar
All I know is it's not good lol what mods do u have
Blackcat is offline   Reply With Quote
Old 12-07-2011, 03:39 PM   #3
Cai, pulleys, 62mm TB, zero degree plugs,4.10s, Diablo tune,Zex 100shot
Old 12-07-2011, 03:52 PM   #4
Blackcat's Avatar
Have u ever sprayed it before or ur first time
Old 12-07-2011, 04:06 PM   #5
This is about my 6th 10lb bottle.
Old 12-07-2011, 04:26 PM   #6
Blackcat's Avatar
Idk then maybe it finally wore out something and it finally gave out did u check under the hood did anything look off was there any black marks from the fire or anything
Old 12-07-2011, 04:27 PM   #7
It didnt leave anymarks and it still works
Old 12-07-2011, 04:31 PM   #8
Blackcat's Avatar
Well if u haven't had any problems and nothing is wrong no idle changes nothing at all has changed then idk but I know spray will eventually wear down ur engine and it will blow something or fry ur rings if not careful
Old 12-08-2011, 02:35 PM   #9
stampde's Avatar
Re: Nitrous Question
did you over rev the engine ?
I've over reved engines before and it'll sometimes cause a Nitrous backfire
sometimes it can damage things , like carb's or throttle bodies ,sometimes it does no harm ..............
2011 GT Auto
Old 12-08-2011, 03:29 PM   #10
What do you mean by over rev? I floored it once i got to the minimum rpm.
Old 01-02-2012, 08:24 PM   #11
08 Bullitt's Avatar
I may be wrong, but I think "over reving" would be to hit the rev limiter with nitrous. Here is a quote from American Muscle website.
If you engage nitrous too high or low you can cause serious engine damage. Nitrous below 2500 RPM can cause detonation, or hitting your rev limiter with nitrous can result in dangeous intake system backfires.
Do you think this is what happened to you?
08 Bullitt is offline   Reply With Quote
Old 01-02-2012, 08:51 PM   #12
Yes!!! Thanks dude
Old 01-02-2012, 09:13 PM   #13
08 Bullitt's Avatar
It's a pleasure!
---------- Post added at 11:13 PM ---------- Previous post was at 11:05 PM ----------
BTW, I would recommend a ZEX Mustang Traction Control Window Switch ZEX-82085 - Free Shipping! to avoid this kind of situation to happen again.
All in all, it seems like a great device.
Here is what you can read about it on American Muscle website:
Increase Nitrous Control. Get the control you need over you Mustang's nitrous system for faster times and improved system safety. With features such as skip shift and the ability to set activation and deactivation RPM, the ZEX traction control window gives you ultimate flexibility. You can easily set the RPM range your system activates in at both the upper and lower limits with this powerful electronic module.
Faster Times. A huge advantage when running on street tires or in low-traction situations, the ZEX traction control switch lets you control what gear nitrous begins to spray in. This can dramatically improve your 60 foot and quarter mile times by allowing you to hit the juice once your tires have traction.
Protect Your Engine. Having a ZEX traction control switch adds an important level of safety to your nitrous system. If you engage nitrous too high or low you can cause serious engine damage. Nitrous below 2500 RPM can cause detonation, or hitting your rev limiter with nitrous can result in dangeous intake system backfires. A ZEX traction control system lets you avoid triggering nitrous too high or too low on your tach.
Application. The ZEX traction control system is compatible with all nitrous kits on the market today.
nitrous
Exhaust question Codysmustang 1996-2004 Mustang GT 14 11-21-2011 09:11 PM
Kenne bell 2.6L question Ahmed ali khan 1996-2004 Mustang GT 4 11-14-2011 12:54 PM
Nitrous Question OmegaRedGT 2007 2005-2010 Mustang GT 35 10-14-2011 09:49 PM
Nitrous and a tuner explicitrock Pre-2005 V6 Mustang 2 07-29-2011 09:01 AM
nitrous question Black99Snake SVT Mustang 4 07-12-2011 09:42 AM
» Members Mustangs
Baby
Tommyboi
Bonni
drusmith
Add your Mustang
05:16 PM
