06 Throttle Body Problem - Mustang Evolution
Old 10-30-2007, 01:12 PM   #1
Snake 42's Avatar
Okay, it's my turn to say that I screwed up. I removed and disassembled the throttle body from my stang because it appeared (to me at least) that the throttle blades were not opening all the way. After finding no intertnal adjustments I reassembled and reinstalled the throttle body and all the engine would do is start and idle. There was no throttle control so I rechecked the throttle body and the drive motor and gear appear to be ok as they rotate like they should but when I reinstall the TB the same problem exists.
Any advice anyone?
Snake 42
Snake 42 is offline   Reply With Quote
Old 11-02-2007, 01:03 PM   #2
Re: 06 Throttle Body Problem
I had the same problem. Drove me Crazy for like an hour. The problem is the return spring in the DBW Motor is wound too tight. Remove dust cap and take out one turn on tensioner. that will solve the problem. whatever you do dont overtighten it will ruin the spring. You will have to buy a new throttle body, the spring is not sold seperately. TB is $395.00.
redrydr77 is offline   Reply With Quote
Old 11-02-2007, 01:55 PM   #3
Snake 42's Avatar
Thanks for the advice and it was indeed the spring. I have it corrected now and would like to tell everyone that I really appreciate the help.
Snake 42
Should i get a throttle body? blackonblack Pre-2005 V6 Mustang 21 12-07-2009 07:21 AM
throttle body sonicpony Pre-2005 V6 Mustang 2 09-09-2007 12:23 AM
70 or 75 mm throttle body????? greg_g70 1996-2004 Mustang GT 9 12-20-2004 09:58 AM
throttle body Murph00 Pre-2005 V6 Mustang 5 11-26-2004 11:43 PM
Throttle problem reply asap mustangmike524 Pre-2005 V6 Mustang 4 11-17-2004 10:31 PM
11:16 PM
