'08 OEM HID to RAXIOM headlight help - Mustang Evolution
Old 12-26-2011, 01:48 PM   #1
I bought my wife a set of Raxiom Projector headlights and Halo Fogs for her vert GT. I'm having a couple of issues.
One: I'd like to find a way to run a "key on" 12-volt hot so I can have the accent lighting (halos on the fogs and headlights and the LEDs on the headlights) run as daytime running lights. Is that advisable, and if so, what's the best place to get said power from?
Two: When attempting to hook up the headlights, I quickly realized the harness doesn't hook up to the new headlights. After doing some research, I'm thinking I may have to buy a whole new wiring harness. Any ideas where I might find this harness, how much it would run and what verbiage I'd search for? I can't find what I'm looking for anywhere.
I really like the new lights. But, is this going to be a bigger pain in the a$$ than it's worth?
Seabass is offline   Reply With Quote
Old 12-26-2011, 11:28 PM   #2
OmegaRedGT 2007's Avatar
The only place to get 12v key-on power is your radio wire harness..if you do alice into
It SOLDER it also make your mod on the harness not the hard wires.its also a good idea to branch of extras for future upgrades.
OmegaRedGT 2007 is offline   Reply With Quote
Old 12-27-2011, 04:02 AM   #3
Re: '08 OEM HID to RAXIOM headlight help
Do you know if the fuse will be able to handle the lights?
Old 12-27-2011, 10:55 AM   #4
Aggiesrok's Avatar
Be real careful about overloading a circuit. Someone will then tell you to put a bigger fuse, don't do it, you can unintentionally cause lots of electrical problems on other places. Check the load requirements of the lights first.
Old 12-27-2011, 10:18 PM   #5
It will if you add a heavy duty relay.
Old 12-28-2011, 08:13 AM   #6
Any ideas on the harness? Can I just change the pig tails to the ones that will fit the lights or do I have to have a whole new wiring harness? I'm curious about this relay for the HID lights. How will that affect the projector lights? I'm no electrical genius. I'm not even sure what the relay is for, nor am I familiar with the HID concept or how they work.
I'm at a loss. I called AM and they had nothing for me.
Old 12-29-2011, 08:58 PM   #7
A relay restricts voltage so you dont blow a fuse.
HID Fog Light Kit For 99-04 Brent Mustang Parts for Sale and Wanted 1 11-20-2011 03:29 PM
Need Advice. Mustang Headlight Fogged Up. AllanBane 1996-2004 Mustang GT 3 10-17-2011 06:37 PM
HID in Raxiom Headlights?? Droski22 General Car Discussion 13 09-29-2011 08:14 PM
Factory OEM wheels gtstyles2 2011-2014 Mustang GT 6 07-18-2011 10:07 AM
06:18 AM
