trans oil - Mustang Evolution
Old 12-31-2011, 07:29 AM   #1
Always broke's Avatar
trans oil
What is the best transmission oil. I have a 2007 mustang gt. It has a 5 speed.
Always broke is offline   Reply With Quote
Old 12-31-2011, 07:46 AM   #2
Eturner's Avatar
In my opinion Royal Purple is the best!..
Old 12-31-2011, 09:09 AM   #3
BaSohol's Avatar
Is it hard to change the trans fluid on a 5spd? Ive done it plenty times to my auto and each time was a nightmare since there's no drain plug on the 4R70w. What type of Royal Purple do the 5spds take? Trans fluid or gear oil? I just bought my stang and would like to change all the fluids
2007 Ford Mustang GT 5spd
Old 12-31-2011, 12:20 PM   #4
Eturner's Avatar
Sorry I can't really answer those questions!.. I've got an auto!.. Surprised no one with a stick has chimed in yet!.. You should get a Chiltons or Hayns manual if you haven't do so yet!..
Old 12-31-2011, 12:27 PM   #5
ColeJohnson's Avatar
I'll be changing mine soon. The way I plan on it is dropping the tranny case and pouring the fluids out then putting it back together. Then I'll take the shifter lever off and pouring the fluid in that way. It's the only way I figure to change the 5spd tranny oil. In my old Tahoe there was a tube in the engine compartment youcould fill up.. Lol
2016 Comp Orange GT (current)
Old 12-31-2011, 01:06 PM   #6
There is a drain plug and a fill plug on the left side of the tranny if I'm not mistaken. You could use a clear tubing and route it t trough the shifter opening .... Good luck
Rdm70 is offline   Reply With Quote
Old 12-31-2011, 03:17 PM   #7
BaSohol's Avatar
I'll look it up on all data and post it up
Old 12-31-2011, 03:58 PM   #8
DaBluedude's Avatar
There is a fill and drain plug. Easy enough to get at. After draining, Leave the fill plug open and pour ATF trans fluid in the trans when you have the shifter off. When it overflows, its full. Clean up, replace top fill plug, install new short shifter (hehe) and ur done. Total time, about an hour.
2003 Mach 1
Old 12-31-2011, 06:29 PM   #9
Pennzoil synchromesh is rebottled GM fluid which is what tremec reccomends. Did mine at 50k. Got quieter, shifts a little smoother and wasn't much hassle. Just don't tell your baby your putting something with a relationship to GM in her
2005 Redfire GT - Mac LT's/prochamber, Pypes mid muffler, FRPP hotrods, 4.10's, Steeda tri-ax, JLT CAI, Bama tuned, Nitto nt05's 333/327 dynojet A little go go juice too
Southern stang is offline   Reply With Quote
Old 12-31-2011, 06:29 PM   #10
The 2005-current has a remote shifter setup so the shifter does not go down into the trans. You will need to fill it with a hose.
FordTech is offline   Reply With Quote
Old 12-31-2011, 07:11 PM   #11
DaBluedude's Avatar
+++ forgot we were dealing with a s197.
2003 Mach 1
Old 12-31-2011, 07:20 PM   #12
Wow all this help is great thanks to you all. Have a Happy New Year.
Old 01-01-2012, 08:05 PM   #13
Re: trans oil
It took me less than 45 minutes using this method:
MustangForums.com - View Single Post - A How To: changing manual transmission fluid
Tremec recommends Mobile 1 Synthetic ATF as an upgrade to OEM. I use Royal Purple Syncromax and personally have good things to say about smoother shifts and cooler temps. Tremec does not recommend RP but only because they have not done long term tests.
Just level out the car on equal height jack stands and have at it.
2006 GT Redfire 5 Spd Manual. Saleen S/C. Custom Diablo tune by Adam @ ST Motorsports, San Bernardino, CA.
Redfire281 is offline   Reply With Quote
Old 01-02-2012, 05:35 PM   #14
Thanks for all your help..... that post was exactly what I needed.
Old 01-09-2012, 01:44 PM   #15
Just called pennzoil they said they do not recommend their syncromesh fluid for the 5 speed.
Old 01-09-2012, 03:06 PM   #16
Charles.young10's Avatar
It's royal purple and it's not even close... By far the best..
Charles.young10 is offline   Reply With Quote
Old 01-16-2012, 04:15 PM   #17
I used Mobil 1 Synthetic ATF. I had a shop help me out. A lift was very cool thing to have. When I called tremic they suggested the Mobil 1.
How to: 4.2L V6 Mustang Engine Swap Danger Dude Pre-2005 V6 Mustang 85 11-14-2015 07:51 PM
Oil pressure issues Klinton 1979-1995 Mustang GT 6 09-11-2011 01:52 PM
Off Topic Question - Oil Weight illestdomer2005 Pre-2005 V6 Mustang 7 09-09-2011 09:26 AM
Trans Downshift Jolt crkmonzo 1979-1995 Mustang GT 3 08-16-2011 08:35 PM
88 fox oil leak 04TRV6 1979-1995 Mustang GT 4 07-05-2011 01:17 PM
11:03 PM
