Tune - Control Arms Now? - Mustang Evolution
Old 01-04-2012, 09:06 PM   #1
Aggiesrok's Avatar
Got filled up with 93 and retuned. What a huge difference. I love it. I'm close to needing tires but I think there's a traction problem. Do the lower control arms help that much?
Old 01-04-2012, 09:35 PM   #2
Silversky545's Avatar
Subframes...
Silversky545 is offline   Reply With Quote
Old 01-04-2012, 11:43 PM   #3
Aggiesrok's Avatar
Originally Posted by Silversky545
Subframes...
Helluva lot more involved than control arms. Is the difference that much in performance?
Old 01-04-2012, 11:46 PM   #4
Slightly lol... And subframes are not that difficult.... U can bolt em up or weld or both... I would say could not take more than 3 hours w a lift and proper tools...
Old 01-04-2012, 11:50 PM   #5
Aggiesrok's Avatar
Thanks, sounds good!
Old 01-05-2012, 04:44 AM   #6
JimC's Avatar
Re: Tune - Control Arms Now?
Lower control arms will net you more than the sub frames. Unlike the Fox body Mustangs, the S197 is already pretty stiff. The LCA uses very soft bushings and is a flexible stamped metal so to get better traction, better bushings and control arms work great. Take a look at the hotpart.com poly ball control arms. Much stiffer and with their poly ball construction it doesn't hurt cornering ability.
JimC is offline   Reply With Quote
Old 01-05-2012, 06:36 AM   #7
Aggiesrok's Avatar
So you think LCA and then lowering springs would be a good combo. I'm not racing it, it's a DD, that I just want to get the most out of.
Old 01-05-2012, 06:49 AM   #8
JimC's Avatar
The LCA and springs would be a good option for you. Sub frame connectors won't get what you are looking for - if you did those you would still need the LCA change.
Old 01-05-2012, 07:17 AM   #9
MavyMav's Avatar
+1 on LCAs and springs. The LCAs will get rid of you wheelhop and the springs will keep downforce on your rear axle. That is best for DDs. If you really want to get crazy (like me ...hehehe), get the subframes and drag shocks. Then you will takeoff real hard with the right tires and traction. And an adjustable UCA when racing.
MavyMav is offline   Reply With Quote
Old 01-05-2012, 08:08 AM   #10
Loc: Austin,TX
LCA for the win as stated above. These cars are already pretty stiff.
Old 01-05-2012, 08:53 AM   #11
Aggiesrok's Avatar
Thanks you guys are awesome. I had a 67 back in college and newer mustangs are much more finicky. Im afraid to cause myself more trouble than help. I appreciate the feedback.
Old 01-05-2012, 09:35 AM   #12
I think y'all are wrong... And I roughy he was already lowered.. But whatever... What do I know...I'm only John force
Old 01-05-2012, 10:03 AM   #13
Durnstang's Avatar
Yes a nice set of adjustable upper and lower arms is the way I'd go. Then just ask a pro on what to set your pinion angle at.
Durnstang is offline   Reply With Quote
Old 01-05-2012, 07:19 PM   #14
JimC's Avatar
Well 'John' I've been racing this 2006 convertible for 5 years now, along with a group of friends also with the S197. Only one guy has put the sub frames on and his car is no stiffer than the rest of ours at the track; appears that all he did was add weight. Several of the guys have enough power to lift both front wheels and others with just the driver side front coming up so if the car was twisting we'd see it.
The S197 is very different from the fox body cars and the new edge. It is a stiffer frame to begin with. The wheel hop problem is not the frame, it is the 3 point rear end with the soft bushings and the flexible stock stamped control arms. They move and the rear end will not hook. Put the LCA's on the car and you can plant the rear tires. The rear end is built to mask the NVH that you get from driving and to soften the ride.
Old 01-05-2012, 08:24 PM   #15
Aggiesrok's Avatar
Thanks JimC for great info. The explanation makes sense and it's from real experiences. I'll go LCA and then later lowering springs. thanks again.
Old 01-05-2012, 09:43 PM   #16
Lol... I accept defeat, I thought these cars were same as fox body's... That's all I've ever had
Old 01-08-2012, 11:30 AM   #17
Dion11197's Avatar
LMAO!! Good to see someone who can deal with criticism and own up.... you wont see that everywhere on the forums! Hahaha!
Dion11197 is offline   Reply With Quote
Old 01-08-2012, 12:28 PM   #18
Yea I try not to b a e-thug I don't know a whole lot about how a car works or how to improve a problem... I just know what I've done, seen, or heard...so if I had xyz problem and was fixed by x on my car or a friends car i will post my opinion... So for future reference don't listen to me
I do however have a good friend who built supersnakes... Now he knows his stuff!! So if y'all have some questions you want me to ask him I'll do so
(installed my k springs and did the alignment in a hour!!)
Old 01-08-2012, 01:13 PM   #19
Dion11197's Avatar
Hahaha!
It's always good to have friends..... and honestly... I don't think I've ever met better people then in the mustang crowds!
Control arms 04machazblue 1979-1995 Mustang GT 7 12-23-2011 01:54 PM
Upper and lower control arms CodyNelson 1996-2004 Mustang GT 25 12-16-2011 04:02 PM
Control arms Travis B 1979-1995 Mustang GT 16 12-07-2011 05:57 PM
Bbk u/l control arms Jesse Bach General Mustang Discussion 0 11-08-2011 06:23 PM
Eibach... or other lower control arms M3to5.0 2011-2014 Mustang GT 8 10-13-2011 06:11 AM
11:46 PM
