adding NOS to my supercharged motor - Mustang Evolution
Old 01-09-2012, 05:15 PM   #1
Sirtat's Avatar
so I have a built 4.6 engine with forged crank, H-beam rods, and blower pistons with stock heads and springs with a vortech V-2 HO putting out 15-18 psi...
I'm wanting to put a 50-75 HP kit on the car for the track.
should I be putting some better valve springs on before adding nos or anything else that would be a mandatory addition ?
thanks !!
IBLT IT
2005 Promar Performance forged long block
Kenne Bell 2.8L LC mammoth supercherger
and and and I DRIVE IT LIKE I STOLE IT !!!!
http://www.youtube.com/watch?v=_K_QJ...ure=plcp<br />http://www.youtube.com/watch?v=NWfvYVYlfio&feature=plcp
Sirtat is offline   Reply With Quote
Old 01-09-2012, 06:02 PM   #2
Re: adding NOS to my supercharged motor
Why not just put a meth kit on it.
Richtq is offline   Reply With Quote
Old 01-09-2012, 06:08 PM   #3
Sirtat's Avatar
I already have the snow performance stage 3 on it... any other suggestions ?
IBLT IT
Old 01-09-2012, 06:09 PM   #4
Titus Wadicus
svtlx's Avatar
y not just a bigger pulley???
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 01-09-2012, 06:29 PM   #5
puttin 15-18? thats a big gap..
just run a pump gas tune and race gas tune...you need to upgrade your valve springs b4 you even hit it with 18lbs or you will most like start floating after a few thousand miles..
and i say hell yes put the bottle on it...would do no less than a 75..my cobra is has a 2.3 with a 125 pill...people run blower and nitrous all the time..just make sure your on race gas and tuned for it when you do..
slow02gt is offline   Reply With Quote
Old 01-09-2012, 07:11 PM   #6
Sirtat's Avatar
I have the impeller speed maxed out just over suggested impeller speed actually which is ok, so I've maxed that out...
IBLT IT
Buying a motor.. good deal? Ponyboy66 1979-1995 Mustang GT 20 12-25-2011 04:35 PM
Motor Travis B 1979-1995 Mustang GT 4 11-16-2011 04:38 PM
Installing a supercharged 3.8 from a thunderbird SC into my 99 mustang skip318 Pre-2005 V6 Mustang 12 10-01-2011 09:03 PM
How hard is a motor swap? Topless04GT 1996-2004 Mustang GT 3 08-13-2011 09:45 AM
questions for a 98 - Driver Seat motor, Headlights, and window motor StreetJMusic Pre-2005 V6 Mustang 10 06-27-2011 03:39 PM
08:30 AM
