CAI tune to stock? - Mustang Evolution
Old 01-16-2012, 01:43 PM   #1
Aggiesrok's Avatar
CAI tune to stock?
Ok, so a CAI requiring a tune is better than one that is a stock only replacement. Makes sense since the tune required CAI's increase flow so much that it would cause a lean situation.
Ok, so when you tune your car you get a copy of the stock tune. Everyone states that you need to return you tune to stock before taking it in for service. Makes sense, the dealer is working with known parameters.
Now the Question: If you have a tune required CAI, how do you return it to stock for service? Is this necessary to return to stock tune or is it a stupid question?
Old 01-16-2012, 02:15 PM   #2
BaSohol's Avatar
You put your stock intake back on
2007 Ford Mustang GT 5spd
Old 01-16-2012, 02:35 PM   #3
MiGT01's Avatar
Re: CAI tune to stock?
I thought a CAI tune wouldnt mess with the warranty? Or did I read that thread wrong..
01 Black Beauty GT
Eibach pro kit,Tokico shocks/struts,BBK CAI,75mm TB/ Plenum,4.10 FRPP gears,BBK o/r X pipe,Magnaflow Catback,SCT Tuner running 91 Tune,Bama Tunes for Life Member,RAM HD Clutch,BM shifter with MGW "GT" knob,AM smoked Headlights/Sylvania zXe bulbs,VHT smoked tails/3rd brake,Redtop Optima,Mach 1 grille delete,Mach 1 chin spoiler,BULLITT Pedals,20% tint all round,4.6 High Performance Badges
MiGT01 is offline   Reply With Quote
Old 01-16-2012, 02:38 PM   #4
Eturner's Avatar
You don't have to return your tune to stock to get it serviced!.. When you get your car serviced all they are doing is basically check for trouble codes!..
Old 01-16-2012, 03:06 PM   #5
BaSohol's Avatar
If you take it in for something serious, that's warranty, best to put everything back to stock
---------- Post added at 04:06 PM ---------- Previous post was at 04:04 PM ----------
Also of ur paying for it out of pocket who cares, leave it
Old 01-16-2012, 03:22 PM   #6
Aggiesrok's Avatar
I asked a service tech about if Ford installed a Ford CAI (which requires tune). He said it affects only the intake and what it may damage, but not the whole engine warranty. Pretty screwy. I guess it could only affect the TB on intake manifold somehow.
Old 01-16-2012, 03:35 PM   #7
GTRob504's Avatar
The stock tune is copied from your control unit to the tuner the first time you use the tuner. It is stored there in the tuner. You can copy this stock tune to a file on your PC if you want to.
If you are going to take your var to the dealer to do any warranty service on the engine then , you mifht as well return it to stock about 100 miles before hand. Sometimes if you go to the dealer and talk with the the service manager you might be able to work out how he wants the car when you bring it in.
---------- Post added at 10:35 PM ---------- Previous post was at 10:32 PM ----------
Ps if you do return to sctock, then you must also put the original air intake back on
2008 Metallic Alloy GT Convertible Premium
Show : black top| 18" bullitt polished wheels| CDC light bar and black billet replacement grilles | black/amber corner lights | GT500 rear spoiler| AH chin spoiler Go: FRPP CAI with StangHi tunes | Kooks LT's | FR500 axle back | Steeda Sport springs | Koni STR.t struts/shocks | J&M camber plates | UMI adj. panhard bar | LCA relocation brackets | GT500 LCA's | Hurst Billet shifter | 3.73 gear | FRPP axle girdle | Baer Rotors and Pads
GTRob504 is offline   Reply With Quote
Old 01-16-2012, 04:22 PM   #8
Eturner's Avatar
Funny thing about all this is that the car records everything!.. It's not going to matter if you return it to stock or not!..
Old 01-16-2012, 04:39 PM   #9
Dion11197's Avatar
+1
They can still see that the tunes have been tampered with in their files.
Dion11197 is offline   Reply With Quote
cai
CAI Tune? Aggiesrok 2005-2010 Mustang GT 28 01-05-2012 05:48 PM
Another cai and tune ? Stang.racr 2005-2010 Mustang GT 10 01-01-2012 07:49 PM
Cai and tune bigsmitty24 2011-2014 Mustang GT 41 10-11-2011 09:08 PM
JLT CAI with Tune Help!! phobik 2011-2014 Mustang GT 7 10-04-2011 07:37 PM
06:20 AM
