Anyway ideas to fix muffler rattle - Mustang Evolution
Old 01-19-2012, 11:14 AM   #1
Charles.young10's Avatar
Don't want this to turn into a exhaust battle.. So I will call my exhaust X, (I love it by the way, the sound is prefect for what I want!)
But, I hear a rattle/noise/vibration every now and then from them. Any "fix" ideas to help that?
Again.. I don't want this to be a debate. just ways/ideas to fix it
Charles.young10 is offline   Reply With Quote
Old 01-19-2012, 11:25 AM   #2
Eturner's Avatar
If your pipes are not welded together the. Check and see if your clamps are tight!..
Old 01-19-2012, 11:25 AM   #3
Y2E0L0L5OGWT's Avatar
Re: Anyway ideas to fix muffler rattle
There is no simple answer to the question. The rattle is likely caused by some portion of the exhaust system, whether it be tubing, hangers, clamps or whatever rubbing against the car/suspension somewhere. It is not likely that something is rattling inside the exhaust...
The first step is to locate where the rattle is coming from, i.e. figure out where something is contacting the body. For instance, when my car warms up, I have a terrible rattle at the rear of the car because the rear driver side hanger just inside the bumper is hitting the horizontal frame rail. It is doing so because the clamp that attaches the cat-back to the cross-over pipe doesn't tighten completely, so the cat-back tube slides back about a 1/4" until the hanger hits the rear cross-member inside the bumper.
In my case, the fix will be to replace the clamp so that I can get a snug fit & remove the slack from the left tube. That being said, your exhaust itself is not likely to be the problem; as in my case, it's likely going to be something causing the exhaust to hit the body & that causes the vibration which results in your rattle...
Old 01-19-2012, 11:45 AM   #4
BaSohol's Avatar
If its all stock exhaust besides the mufflers just recheck everything from the where the mufflers connect to the tail pipe, did it always rattle or just start? And muffler X is shlt, muffler Z is the only thing I but on my car
2007 Ford Mustang GT 5spd
Old 01-19-2012, 11:46 AM   #5
Silversky545's Avatar
I have same issue... 2k rpm to 3500 rpm... Been to several shops nobody can find these source of the problem.... I've been told the axel back I have is known for having this issue... Very annoying
Silversky545 is offline   Reply With Quote
Old 01-19-2012, 12:12 PM   #6
Eturner's Avatar
When I had FlowMasters on my other car it would rattle from about 2,000-3000 rpms!... Was told that was common for that!..
Old 01-19-2012, 12:30 PM   #7
I did not bring up brand name out of respect for the guy w the original post... But yes that is what I have
Old 01-19-2012, 12:31 PM   #8
My rattle in my 06 was a exhaust hanger
aframe is offline   Reply With Quote
Old 01-19-2012, 12:45 PM   #9
Eturner's Avatar
Only reason I mentioned it was just for some "food for thought!.."
Old 01-19-2012, 12:52 PM   #10
Dion11197's Avatar
Mine rattles too. The only time mine didn't was when I had just the roush extreme cat back(mid muffler/resonator). With any kind of axelback including the stock ford ones I get the rattle or vibration. You could check into a mid muffler system or just look under the car real good and see where it's rubbing and make some room if possible.
Dion11197 is offline   Reply With Quote
Old 01-19-2012, 01:31 PM   #11
thanks for the response guys! to explain more..
I have after market axle-backs, thats it, everything else is stock.
it is "for sure" coming from the mufflers hitting the frame..
is there a piece of rubber or something of that nature I can fit in there?
Old 01-19-2012, 03:17 PM   #12
TXstang125's Avatar
I have that same problem man mine rattles when I first start it up but when I get going and it gets warmed up it quiet down but like when I fist turn it on Goethe day it's bad
TXstang125 is offline   Reply With Quote
Old 01-19-2012, 06:05 PM   #13
Dion11197's Avatar
Mines the same as far as rattles at first start then goes away!
---------- Post added at 06:04 PM ---------- Previous post was at 05:56 PM ----------
The only thing I can think that may help would be to listen from the h pipe back and try to maneuver the pipes so you don't have clearance issues.... The fun part would come if it's hitting suspension pieces.... If that's the case then you have to do it with the car on the ground so the suspension is under load and it's almost impossible to get under the car unless you have access to a walk user tunnel like they use for oil changes.
---------- Post added at 06:05 PM ---------- Previous post was at 06:04 PM ----------
That's loosen not listen.... But you can listen too, lol
Old 01-19-2012, 07:05 PM   #14
Eturner's Avatar
Can still possibly use ramps!.. So that way the suspension is still under load!..
It just might be a tight squeeze though!..
Old 01-19-2012, 08:30 PM   #15
Dion11197's Avatar
I've done it.... Still tight but doable! Just getting to the h pipe will suck!
---------- Post added at 08:30 PM ---------- Previous post was at 08:29 PM ----------
I only did it for the axel backs though.
Old 01-19-2012, 08:51 PM   #16
Eturner's Avatar
Lol. Been there done that, got the T-shirt to prove it too!!... Lol.
Old 01-19-2012, 08:53 PM   #17
Aggiesrok's Avatar
Is all of the rubber intact inside the hangers?
Old 01-19-2012, 09:18 PM   #18
Yep!
Old 01-19-2012, 10:31 PM   #19
Aggiesrok's Avatar
Have tried loosening the connection at pipe clamp a little, then twist the muffler pipe a up or down in order to get more clearance? There is a fair amount of pipe overlap to play with. I've flowmasters and they don't rattle.
Old 01-19-2012, 10:45 PM   #20
Eturner's Avatar
I've gone through two sets of Flowmasters and they both rattled!..
Old 01-20-2012, 11:14 AM   #21
BaSohol's Avatar
flowmaster mufflers produce there sound by resonating, which n turns makes tons of vibrations, and if there is something loose anywhere in the car, even 2 pennies in the cup holder your going to hear them
Old 01-20-2012, 12:30 PM   #22
Eturner's Avatar
Funny thing is that they didn't start to rattle until after about a year!.. And the same with they second set!.. It wasn't the pennies in the cup holders!.. It was the mufflers them selves!...
Old 01-20-2012, 01:37 PM   #23
Dion11197's Avatar
Lmao! With mine it's the keys in the cup holder, loose change, my rearview mirror.... Sets off the neighbors car alarm and apparently rattles near by windows!
Old 01-21-2012, 09:05 AM   #24
Aggiesrok's Avatar
Sounds like something inside the muffler is breaking loose. Especially if it's after a year or so. Mine are only 5 months old, so we'll see.
Old 01-21-2012, 09:32 AM   #25
Eturner's Avatar
That exactly what the shop told me!.. Both times!.. Lol
Old 01-21-2012, 09:42 AM   #26
Cmprather's Avatar
Region: New Mexico
I have an '06 with H exhaust and experienced a rattle with mine as well. I took it in to the shop and they told me there was a service bulletin out for it and fixed it for free. This website lists all service bulletins for most cars:
http://www-odi.nhtsa.dot.gov/tsbs/
Hope that helps.
Cmprather is offline   Reply With Quote
Old 01-21-2012, 10:58 PM   #27
Gibby's Avatar
I took my mufflers off of my 06 and had the exhaust dump after the axle. It sounded like an ol' school 5.0
Gibby is offline   Reply With Quote
Old 01-21-2012, 11:33 PM   #28
BaSohol's Avatar
Did that for a week then got pipes welded on for 120 bucks, sounds great had them use the old clamps so I can still change them
ID:	38840   Click image for larger version
Old 01-21-2012, 11:49 PM   #29
Gibby's Avatar
Post an exhaust clip!!!
Old 01-21-2012, 11:59 PM   #30
BaSohol's Avatar
Ok tomorrow morning
Old 01-22-2012, 01:01 AM   #31
irishn8's Avatar
I had a rattle in my flowmaster exhaust that became sevear last month, turned out someting came loose inside and I had to replace it.
Old 01-22-2012, 10:39 AM   #32
BaSohol's Avatar
Here's a video of the no mufflers from inside with the windows up and 1/2 throttle
Old 01-22-2012, 01:31 PM   #33
Black05gt's Avatar
Has anyone had this problem with the factory exhaust? Mine is all stock and I have a rattle in the exhaust between 2k-3,500 rpm, actually sounds like it's inside the exhaust about middle of the car, I checked under the car and nothing feels loose, just wondering if they would fix it under warranty?
Black05gt is offline   Reply With Quote
Old 01-22-2012, 05:01 PM   #34
I think I'm going to just delete the mufflers and run 4" in diameter echo tips that are about a foot long... I hate the way muffler deletes sound but it's a cheap set up till I can put some mid mufflers on...
Old 01-22-2012, 06:29 PM   #35
irishn8's Avatar
Could just go for cheepo glasspacks for now. Summit racing as them for $20 each. Just an idea.
« New cai | Homemade »
Cracked muffler/ pressure loss? Kgstang 2.3 Mustang 4 01-04-2012 10:58 PM
4.6 bottom end rebuild. Ideas please SonicBlueGT9963 1996-2004 Mustang GT 10 10-31-2011 07:12 AM
custom plate ideas king 5.0 2011-2014 Mustang GT 22 10-18-2011 04:11 AM
Need ideas for Fox stereo SleepingStang Mustang Audio & Video 44 09-30-2011 12:09 AM
05:17 AM
