brakes - Mustang Evolution
Old 01-25-2012, 11:53 PM   #1
brakes
Idk if anyone else drives there Nobel steeds in the winter but I do n it seems when it gets realy cold about 20° or colder my rear breaks lock up but any warmer n I don't have an issue wht could cause this cuz I just put new pads on n im frying them thanks to all who replys
Mustang_Daddy is offline   Reply With Quote
Old 01-26-2012, 12:02 AM   #2
BaSohol's Avatar
What do you mean locks up? Like when you break it locks up and skids?
2007 Ford Mustang GT 5spd
Old 01-26-2012, 12:05 AM   #3
Well not completely locked up to were it keeps the tires from rotating but I can feel it n smell the pads burning n its only the rear
---------- Post added at 07:05 AM ---------- Previous post was at 07:04 AM ----------
N its constantly no just when I brake I mean all the time
Old 01-26-2012, 03:01 AM   #4
BDSA1NT's Avatar
The only problem I have had with mine is the parking break sticking when engaged for long periods o time and it being stiff when pulling it up to engage when it's cold. Don't know if that helps but there you go.
BDSA1NT is offline   Reply With Quote
Old 01-26-2012, 10:40 AM   #5
This used to happen on my 07
Big Johnson is offline   Reply With Quote
Old 01-29-2012, 02:51 AM   #6
I have no idea but I notice the ebrake engages a Lil higher when this happens but its only when its really cold other wise It dont happen n mine is also a 2007
Old 01-29-2012, 08:30 AM   #7
BaSohol's Avatar
Re: brakes
this happened to me yesterday, rained then temps dropped, i lowered the ebrake but it was all loose, like i can pull it back up with no effort, but after 5 feet it unfroze
Old 01-29-2012, 09:34 AM   #8
RedGT's Avatar
Here's what happens. The LCA design I'm the 05-09 S197s allow the ebrake cable to pass through the middle of the LCA to secure it in place. However, with the up and down motion of the rear axle, the cable gets worn through by the LCA. Enter water, sub zero temps and voila. Frozen brakes. Easy solution: wrap some hose around the ebrake cable or get new LCAs. J&M makes an awesome set that can't be beat.
RedGT is offline   Reply With Quote
Old 01-29-2012, 09:46 AM   #9
BaSohol's Avatar
Re: brakes
Ill investigate this idea, sounds possible, thanks
Old 01-29-2012, 10:08 AM   #10
Gil_T2's Avatar
Re: brakes
OP says it is not E-brake problem.
OP how many miles on car, also when you replaced the pads how did you retrack the caliper piston? Did you resurface the rotors?
BBK LT's, Catted Xpipe, Sniper tune, UDP's GT500 TB, Ford Racing CAI, CM delete, 4.10, TR6060, 1 piece DS
Gil_T2 is offline   Reply With Quote
Old 01-29-2012, 10:50 AM   #11
Aggiesrok's Avatar
I just replaced my LCA's. The e-brake cable jacket had a lot of wear, with less than 90k miles.
Old 01-29-2012, 11:03 AM   #12
RedGT's Avatar
Re: brakes
I had approx. 35K miles on mine, and the sheath was worn through. Had it replaced under warranty, but by 50K miles they were starting to wear again.
Old 01-29-2012, 11:15 AM   #13
I changed them at about 37k I bought the tool tht twists the piston back in n yes I had my rotors cut n it did this before I changed them
Old 01-29-2012, 11:42 AM   #14
Gil_T2's Avatar
Re: brakes
I do not know the year of your car, but if it is 07 or older it could be a bad caliper. Get a clear length of hose that fits on the bleeder. Loosen the bleeder and let the fluid run into the hose. If there are little black/brown particles in it , replace the caliper. If a car sits alot, the brake fluid absorbs moisture, that will make its way to the calipers and cause corrosion. When you re-track the piston to install the new pads the piston will stick on those spots when cold or hot.
---------- Post added at 01:42 PM ---------- Previous post was at 01:36 PM ----------
Get some rubber insulated hose clamps, attach them to the LCA and they will not wear, 1 per side
Old 01-29-2012, 12:06 PM   #15
RedGT's Avatar
I know. I posted the idea about 5 replies up.
Thinking of Brakes jjsg09 1996-2004 Mustang GT 18 01-26-2012 10:36 AM
disc brakes jacob.a.gasparp 1979-1995 Mustang GT 4 01-24-2012 05:11 PM
Brakes avengnd 2011-2014 Mustang GT 10 12-27-2011 09:46 PM
New Brakes Timm04 Pre-2005 V6 Mustang 6 09-22-2011 01:28 PM
conversion disc brakes? 1faststang Classic Mustangs 15 08-11-2011 01:30 AM
03:04 PM
