Slight Hesitation @2800-3000 - Mustang Evolution
Old 01-30-2012, 03:21 PM   #1
Aggiesrok's Avatar
I don't think it's my imagination, but there seems to be a slight hesitation around 2800-3000. It's strange. My setup is 07 GT, CAI, SCT - 93 tune, Flowmaster 40's and Steeda LCA's and I really need new tires, but I don't think that's the problem. I've noticed it since the tune. Could it be a tune error?
Old 01-30-2012, 03:41 PM   #2
Charles.young10's Avatar
Yeah it could be, I would update your tuner, the retune the car.. Won't hurt to try.. And its free! Lol
Also clean throttle body and IAC.. You never know with those things
Charles.young10 is offline   Reply With Quote
Old 01-30-2012, 09:21 PM   #3
Sirtat's Avatar
can you feel it when you apply full throttle at 1500-2000 rpm through to say 5000 rpm? or does it just stumble when trying to cruise at 2800-3000 ?
IBLT IT
2005 Promar Performance forged long block
Kenne Bell 2.8L LC mammoth supercherger
and and and I DRIVE IT LIKE I STOLE IT !!!!
http://www.youtube.com/watch?v=_K_QJ...ure=plcp<br />http://www.youtube.com/watch?v=NWfvYVYlfio&feature=plcp
Sirtat is offline   Reply With Quote
Old 01-30-2012, 09:55 PM   #4
Aggiesrok's Avatar
It's during acceleration. When I feel it I look at the tach and it's just going past 3k. It's fine when cruising.
Old 01-30-2012, 09:57 PM   #5
Sirtat's Avatar
I had the exact same proble but I'm supercharged... the exact cause of my problem was my charge motion plates they open and close between 2800-3000 rpm so I disassembled my stock charge motion plates and put aluminum round stock and tig welded them in... My hesitation went right away... check out the steeds motion delete plates... it is what cured it for me
IBLT IT
Old 01-30-2012, 11:28 PM   #6
Aggiesrok's Avatar
That makes sense. I was planning on getting a FRPP intake in the future, which would eliminate the plates and save $200 on delete plates. Then I'll be able to replace cams and TB and actually get some HP out of them. I'd love to go SC, but that's not in the budget.
But maybe deletes are a good short term solution and gain a little HP also.
Old 01-31-2012, 04:17 AM   #7
RVAStang05's Avatar
I would think it's a little carbon build up before it would be tune error.
Pype Bomb Axle-Backs, JLT CAI, SCT Tuner w/Bama tuning, BMR Strut Tower Brace, CDC Classic Chin Spoiler, Black Hood Pins, Black Shorty antenna, Tru-Billet Black Anodized GT engraved Fuel Door, Black Lemans Stripes, Black Rocker Stripes, Brushed Aluminum finish dash and vents, Stack Racing pedals, Charcoal Black Leather Interior, Gloss Black Bullitt Motorsport Wheels, Nitto 555 tires, staggered set up (9/10), 35% tint, Shaker 1000 Stereo with Kicker Upgrades, Ultra Violet footwell, license plate and dome lighting
RVAStang05 is offline   Reply With Quote
Old 01-31-2012, 09:39 AM   #8
Re: Slight Hesitation @2800-3000
contact your tuner and get data logs in that range when it does it (if you can recreate) they can look and see whats up. They may send you something that tells you what to log also.
Old 01-31-2012, 09:50 AM   #9
Aggiesrok's Avatar
Thats a great idea. I forgot that I can datalog. I'll get the laptop out and maybe do a little cleaning.
Old 01-31-2012, 09:52 AM   #10
Sirtat's Avatar
can you data log you mass air flow voltage and your rpm ?
if so data log the two and see if you have major fluctuation beyond .0x at your problem rpm,as your rpm goes up your mass air flow voltage should do the same and not drop to a lower voltage at a higher rpm.
IBLT IT
Old 01-31-2012, 09:58 AM   #11
Aggiesrok's Avatar
I have an SCT tuner, I pretty sure that you can data log those. But I'll have to check. Thanks.
Old 01-31-2012, 11:57 AM   #12
i have an SCT you can data log, I use the livewire software and I load the settings I was sent from my tuner then just click "go" and "stop" when im done.
« Pro pic | Bully Dog »
12:11 AM
