Noise - Mustang Evolution
Old 01-30-2012, 10:04 PM   #1
Tyler LaMunyon's Avatar
Region: New Mexico
Noise
When going over speed bumps or shifting a little off the right rpm causes a knocking noise in the back of the car ? What could this be and should i be worried it still drives perfect
Tyler LaMunyon is offline   Reply With Quote
Old 01-31-2012, 04:51 AM   #2
GTRob504's Avatar
How many miles do you have on the car? Did you just start to notice this?
2008 Metallic Alloy GT Convertible Premium
Show : black top| 18" bullitt polished wheels| CDC light bar and black billet replacement grilles | black/amber corner lights | GT500 rear spoiler| AH chin spoiler Go: FRPP CAI with StangHi tunes | Kooks LT's | FR500 axle back | Steeda Sport springs | Koni STR.t struts/shocks | J&M camber plates | UMI adj. panhard bar | LCA relocation brackets | GT500 LCA's | Hurst Billet shifter | 3.73 gear | FRPP axle girdle | Baer Rotors and Pads
GTRob504 is offline   Reply With Quote
Old 01-31-2012, 06:38 AM   #3
Aggiesrok's Avatar
What do you mean shift a little off? I assume you're not bottoming out. It sounds like its drive train related, since it's when you shift funny and driving over a speed bump can cause you to use the clutch differently when easing over the bump.
Old 01-31-2012, 09:02 AM   #4
JohnC.'s Avatar
Is it like a metal clanking noise when the car bounces or does it sound like something bouncing in your boot
JohnC. is offline   Reply With Quote
Old 01-31-2012, 11:32 AM   #5
Could be your drivetrain catching back up to your motor/vise versa. My buddies 4runner does it all the time as he kinda isn't the greatest at shifting it and it's a little timid and likes to be carressed lol.
But mine makes. Clunk sometimes shifting into 5th at a lower speed and rpm. Totally normal if that's the noise your hearing.
2005 Redfire GT - Mac LT's/prochamber, Pypes mid muffler, FRPP hotrods, 4.10's, Steeda tri-ax, JLT CAI, Bama tuned, Nitto nt05's 333/327 dynojet A little go go juice too
Southern stang is offline   Reply With Quote
Old 01-31-2012, 02:27 PM   #6
Region: New Mexico
5 k miles and its not metal on metal its like a knockong sound
---------- Post added at 04:27 PM ---------- Previous post was at 04:17 PM ----------
Its like something under the car knocking..
Old 01-31-2012, 03:15 PM   #7
Aggiesrok's Avatar
Re: Noise
Does it knock a couple of times and then stop? Or stop after accelerating?
Old 01-31-2012, 03:33 PM   #8
Region: New Mexico
It stops its only on bumps and when i make the car jump a lil forward to fast happens like 2 times a day sometimes never
Old 01-31-2012, 04:00 PM   #9
gqsmash's Avatar
Then get under your car and start hittin stuff to see if you can simulate a bump to make the noise
gqsmash is offline   Reply With Quote
Old 01-31-2012, 04:20 PM   #10
Region: New Mexico
Good idea but its probaly not hurting anything cuz its been doing it for awile
Old 02-01-2012, 06:35 PM   #11
GTRob504's Avatar
Since your car has low mileage , this sound is not related to normal wear. It is likely the normal play in the drive train.
Old 02-01-2012, 09:47 PM   #12
Region: New Mexico
So no worries?
Old 02-01-2012, 10:07 PM   #13
Lucy2012's Avatar
I had a knock/clunk from the rear end (auto transmission) while driving over bumps and it turned out to be rear stabilizer link. You can crawl under and give her a wiggle, there should be zero play there.
I had to go over really sharp bumps to make it happen, like the rear end had to rattle a bit. At first I thought a bit of noise was normal but after the repair it is so nice and quiet!!
Lucy2012 is offline   Reply With Quote
High pitched engine noise whine cjd_1986 2005-2010 V6 Mustang 4 01-16-2012 11:34 AM
When I put gas pedal, wind noise!! jmpark527 2005-2010 Mustang GT 28 11-23-2011 09:45 AM
Nasty noise under the hood please help! S197STANG 2005-2010 Mustang GT 18 11-05-2011 10:14 PM
Clutch noise 02 mustang gt mkw037 1996-2004 Mustang GT 5 09-05-2011 08:14 AM
04:21 AM
