Lowering car - Mustang Evolution
Old 02-01-2012, 09:22 AM   #1
JohnC.'s Avatar
Lowering car
Do u need to change your stock suspension before lowering the car or do anything else before lowering it
JohnC. is offline   Reply With Quote
Old 02-01-2012, 09:35 AM   #2
S197Miller's Avatar
Depends on how much you lower your car. If you drop it too much your alignment will be out of whack. If that's the case then you have to buy an adjustable pan hard bar for the rear. And caster camber plates for the front. But if your only doing a minor drop,say an inch, I would still buy an adjustable pan hard just because the really are not that expensive. CC plates, decent ones, will cost more than your lowering springs.
S197Miller is offline   Reply With Quote
Old 02-01-2012, 09:47 AM   #3
sinister07's Avatar
Re: Lowering car
It all depends on how much you lower the car. If you go just a little, say 1" or so, nothing really needs to be changed. Any farther than that, you will need either camber bolts or caster/camber plates. Out back you will also need to address the Panhard bar.
I used the Summit Racing spring set on my black Mustang. I also used the camber bolts and a Competition Products adjustable Panhard bar. The whole job took two hours to do, and the results were spectacular.
Summit Racing SUM-720101 - Summit Racing Lowering Spring Kits - Overview - SummitRacing.com
Eibach 5.81260K - Eibach Alignment Kits - Overview - SummitRacing.com
UMI Performance 1039-B - UMI Performance Single Adjustable Panhard Bars - Overview - SummitRacing.com
2003 Mach 1
sinister07 is offline   Reply With Quote
Old 02-01-2012, 10:16 AM   #4
Silversky545's Avatar
Why is everyone so gun ho about spending a ton of money!?!?
Just lowered my car with the FRPP k springs (1 1/2" drop all the way around) and picked up ehibach camber bolts to get the alignment done.... Extremely easy and I did not need a adj pan hard bar... I will say I plan on picking one up just in case I need it in the future and I am also looking into new shocks n struts for better handling and comfort over harsh bumps... I think it also depends on how many miles are on the car... I have 50k so all my stuff is good...
Silversky545 is offline   Reply With Quote
Old 02-01-2012, 11:10 AM   #5
Don't listen to these people
K springs
Camber bolts off AM
And a alignment
Done....
Unless you have high miles then everything they said is correct
Old 02-01-2012, 11:30 AM   #6
S197Miller's Avatar
K springs
Camber bolts off AM
And a alignment
Done....
I never said it was expensive or even hard to do. The only thing I said was that CC plates arnt cheap. And that you only need them if you do a big drop. Lol
Old 02-01-2012, 11:42 AM   #7
I know... I typed up a really long detailed response on my lowering experience ... But my stupid phucking piece if poo iPhone kicked me out of the app ... So I just kept it short and sweet... Cc plates are not always needed... But I for one am getting them later along w full Suspension set up from steeda... I plan to road race... So I guess we need to know what this guys goals are first and foremost
Old 02-01-2012, 11:45 AM   #8
S197Miller's Avatar
+1 on what he plans to do
Old 02-01-2012, 12:37 PM   #9
Cobrarunnin9s's Avatar
Re: Lowering car
If you want to do it right, you will need springs, revalved struts and shocks to match your new spring rates, caster/camber plates or cam bolts and your adjustable panhard bar. Then after you drive it for about a week get the alignment done.
Cobrarunnin9s is offline   Reply With Quote
Old 02-01-2012, 01:56 PM   #10
sinister07's Avatar
Re: Lowering car
I just posted links to the CHEAPEST parts in the Summit catalog.....I tried to go cheap and not get a panhard bar. The rearend was moved over about 3/8" and caused all kinds of tire rubbing.
2003 Mach 1
Old 02-01-2012, 03:35 PM   #11
Aggiesrok's Avatar
Re: Lowering car
S197 Mustang Suspension Upgrades - 5.0 Mustang & Super Fords Magazine
Try this link, it's pretty interesting.
How To: Plasti Dip Your Car (In Depth, 6 pages worth of Microsoft Word) Topless04GT Mustang Paint, Appearance & Detailing 318 05-17-2017 12:40 PM
Horrible stangs we've all seen em Dgibson Pictures and Videos 225 05-15-2012 09:29 PM
2005 Mustang GT 350 Tribute Car (Mineral Grey Lovers) 2K05GT Pictures and Videos 8 02-01-2012 04:43 AM
I need suggestions on lowering my car dailey 2011-2014 Mustang GT 47 09-05-2011 07:52 PM
Lowering springs 89white GT 1979-1995 Mustang GT 13 08-31-2011 09:32 AM
09:56 PM
