Spark plugs for 06 GT - Mustang Evolution
Old 02-14-2012, 01:38 PM   #1
Strick9's Avatar
time to change them out! Any suggestions on plugs for a lightly modified GT (exhaust, TB)? I haven't seen many options for plugs on AM.
Strick9 is offline   Reply With Quote
Old 02-14-2012, 01:44 PM   #2
Aggiesrok's Avatar
I just ordered some E3's from Summit, but won't get them until end of week. They have the diamond cage around them.
289 - Holley 4150 570cfm; Performer intake; mild cam; MSD HEI; 302 heads; Roller Tips; Hedman Tri-Y headers; H-pipe w/Flowmaster 40's; 9 in posi 3.50; 205/50-17F; 225/50-17R.
Old 02-14-2012, 02:39 PM   #3
Re: Spark plugs for 06 GT
caution, the 05+ are known to have issues getting the plugs out (they break in half) just FYI to research that a bit and be prepared.
Old 02-14-2012, 02:43 PM   #4
jwhayne0001's Avatar
I'm a mechanic at a ford dealer and we HIGHLY advise NOT to try to tue up at home on the 05 up gt's or 3 valve f150's the plugs do break and are a pain in the @ss to remove once broken and you need a special tool
jwhayne0001 is offline   Reply With Quote
Old 02-14-2012, 02:47 PM   #5
^^ yup and its ford fault but they still charge you an obscene amount to remove them when they break EVEN if the tech's are the ones that break them
Old 02-14-2012, 02:49 PM   #6
It's not really the techs fault I beleive we charge 30 minute labor to remove and beleive me it's really that long to remove the porcelain
Old 02-14-2012, 02:58 PM   #7
Aggiesrok's Avatar
Can you buy the special tool? Is it that the porcelain falls into the head around the plug? All the more reason to use a different plug type, right?
Old 02-14-2012, 03:10 PM   #8
Sirtat's Avatar
yes you can buy the removal tool.
the cause is the aluminum heads expand when hot but the steel two piece plug does not, so carbon builds up in the void and then the head cools and that void is now full of carbon. It's not like every 4.6L spark plugs will break I have done mine and about 5 friends s197 and 1 f150 and have not had any break but it is something you have to be prepared to deal with yourself or have enough money on hand to have a shop deal with..
I've used autolite HT0's and will never again they're still a two piece design !
the only true one piece plug that I have found and will ONLY use is the BRISK brand..
IBLT IT
2005 Promar Performance forged long block
Kenne Bell 2.8L LC mammoth supercherger
and and and I DRIVE IT LIKE I STOLE IT !!!!
http://www.youtube.com/watch?v=_K_QJ...ure=plcp<br />http://www.youtube.com/watch?v=NWfvYVYlfio&feature=plcp
Sirtat is offline   Reply With Quote
Old 02-14-2012, 03:13 PM   #9
Sirtat's Avatar
here is a before and after pic to show you what could be left in the head.
IBLT IT
Old 02-14-2012, 03:17 PM   #10
Strick9's Avatar
Where do you find the brisk brand? What about ford OEM?
Old 02-14-2012, 03:24 PM   #11
Aggiesrok's Avatar
So that lower piece is thin steel that is incased in the ceramic part? What keeps it from falling into the cylinder?
Old 02-14-2012, 03:49 PM   #12
Sirtat's Avatar
go to www.briskusa.com and find a dealer near you...
Do NOT replace with stock oem two piece plug, it is the problem as well as any other two piece spark plug ie; autolite.
like I said brisk is the only one piece plug I have found..
---------- Post added at 03:49 PM ---------- Previous post was at 03:45 PM ----------
the ceramic is incased within the steel nipple.. and there is a ground strap/saddle as seen in the pic, that is what stops the porcelain from falling into you combustion cylinder if the porcelain were to crack.. hope that made some sense
IBLT IT
Old 02-14-2012, 03:56 PM   #13
yea not blaming any tech's, but I believe Ford should foot the bill since its a design issue and not related to anything the customer could have done
Old 02-14-2012, 03:59 PM   #14
Sirtat's Avatar
100% agree !!!! and I haven't been on the sh*t end of that stick !!
IBLT IT
Old 02-14-2012, 04:20 PM   #15
Aggiesrok's Avatar
What's the tool cost? The 2007's have the same problem, I take it.
Old 02-14-2012, 05:46 PM   #16
What about ngk spark plugs
Scootinbob is offline   Reply With Quote
Old 02-14-2012, 05:52 PM   #17
Ford has updated fomoco brand plugs to ease removal for the 2nd tune up its just the factory ones that are a biatch
Old 02-14-2012, 05:55 PM   #18
Sirtat's Avatar
I don't think ngk makes a plug for the 4.6 but haven't researched it but brisk all the way!! IMO
IBLT IT
Old 02-14-2012, 06:26 PM   #19
Aggiesrok's Avatar
What about E3's, they make em.
---------- Post added at 06:26 PM ---------- Previous post was at 06:16 PM ----------
So the procedure is to only loosen plug 1/8 to 1/4 turn, then put about 1/2 teaspoon of carb tune up cleaner into plug well. Wait a minimum of 15 minutes soak time. Tighten, then loosen working the plug back and forth. Eventually effort is reduced and plug can be removed.
Is this the procedure used by Ford techs or do you just try to remove carefully and if it breaks you then use the special tool?
Old 02-14-2012, 06:32 PM   #20
Sirtat's Avatar
yes that is the procedure however You want your engine to be hot... and you only new the removal tool when they break
IBLT IT
Old 02-14-2012, 06:38 PM   #21
We use a 3/8 impact it's a quick torquie snap that most of the time will result in a successful removal
Old 02-14-2012, 07:18 PM   #22
Aggiesrok's Avatar
I heard engine cold. But hot and expanded makes sense.
Old 02-14-2012, 07:34 PM   #23
And it's always the ones in the back that break lol of course the ones hardest to access
Old 02-14-2012, 08:49 PM   #24
Aggiesrok's Avatar
Just curious. I'm changing mine this weekend- maybe, sorry for the constant questions
But why doesn't your Ford shop use the procedure in the TSB?
Does that not work very well and you have better luck with the impact wrench?
I just want to avoid breaking any.
Old 02-14-2012, 09:03 PM   #25
BaSohol's Avatar
How many miles do you have? I heard the problems are with higher mileage motors
2007 Ford Mustang GT 5spd
Old 02-14-2012, 09:13 PM   #26
Aggiesrok's Avatar
91k, about the worst case.
Old 02-14-2012, 09:16 PM   #27
BaSohol's Avatar
I plan on changing mine next oil change at 44k hope all goes well, I'm going to change them in a ford dealers parking lot haha that why if it breaks I can just push it into there service department
Old 02-14-2012, 09:18 PM   #28
Sirtat's Avatar
lol, I bet they won't like that. play the game, see if you can finish before they kick you out
IBLT IT
Old 02-14-2012, 09:21 PM   #29
Aggiesrok's Avatar
That's a pretty descent idea.
Old 02-14-2012, 11:43 PM   #30
BaSohol's Avatar
Cheaper then a tow truck
Old 02-16-2012, 05:24 AM   #31
RVAStang05's Avatar
That's hilarious Whenever im installing something new that makes me nervous, I take the car down to the lot next-door to my mechanic to do it. They can't see me, but I know if something screws up, help is literally around the corner. I hope I'll never have to make use of that convenience though, because I'd be busted. It would be very obvious what I was doing....
Pype Bomb Axle-Backs, JLT CAI, SCT Tuner w/Bama tuning, BMR Strut Tower Brace, CDC Classic Chin Spoiler, Black Hood Pins, Black Shorty antenna, Tru-Billet Black Anodized GT engraved Fuel Door, Black Lemans Stripes, Black Rocker Stripes, Brushed Aluminum finish dash and vents, Stack Racing pedals, Charcoal Black Leather Interior, Gloss Black Bullitt Motorsport Wheels, Nitto 555 tires, staggered set up (9/10), 35% tint, Shaker 1000 Stereo with Kicker Upgrades, Ultra Violet footwell, license plate and dome lighting
RVAStang05 is offline   Reply With Quote
Old 02-16-2012, 07:39 AM   #32
Aggiesrok's Avatar
Brenspeed has the complete service bulletin on their website for removing the plugs and what to do if they break, it says cold engine and no power tools.
I think the Ford service uses the impact wrench because it's fast and if they break one it's more money, because they charge the customer for it. So they have no incentive to worry about breaking them.
I found a company that sells the tool kit for removal for $70.
Old 02-16-2012, 07:49 AM   #33
BaSohol's Avatar
Ya I would never ever use in impact on a spark plug , I wouldnt be surprised if one day the threads came out with the plug haha
Old 02-16-2012, 08:37 AM   #34
KATO's Avatar
WOW, This is a interesting Thread, I never knew any of this, I never planned on doing my own Tune-up, and after reading this thread, I will NEVER do my own Tune-up. Thanks for the Thread guys.
07 GT. SCT: CUSTOM TUNE by "MUSTANG SPECIALTIES". LMR: GEN2 2010 STYLE HEADLIGHTS, RAXIOM: 2010 SMOKED COYOTE TAIL LIGHTS, WHEELS: STAGGERED WHL 22X8.5F-22X10R.
Old 02-19-2012, 03:37 PM   #35
See Denlorstools.com,look for Lisle tool I think its number 6500,or something close to that. About $80,with shipping, and WELL WORTH IT! !!Works like a champ for broken plug removal
sweir69 is offline   Reply With Quote
Spark Plugs DaBomber 1979-1995 Mustang GT 19 01-31-2012 05:25 AM
used 98 mustang and new spark plugs Deadpool Pre-2005 V6 Mustang 4 11-02-2011 11:09 PM
120,000 mile spark plugs? Just_John Pre-2005 V6 Mustang 2 10-08-2011 10:43 AM
E3 Spark Plugs Diamond Fire - Spark Plug gonzo56 2005-2010 V6 Mustang 6 09-28-2011 10:45 AM
Spark Plugs may be needed jjsg09 1996-2004 Mustang GT 2 09-12-2011 06:05 AM
01:30 PM
