Mustang 2007 Modifications. - Mustang Evolution
Old 02-15-2012, 06:07 AM   #1
MustangCaracas's Avatar
Hi there!
Im needig some help with my 2007 stang modifications.
Its virgen. Stock
Wich throtle body fits better? BBK 62mm, BBK 65mm or Ford Racing 62mm?
Throttle Body spacer recommended?
Im about to buy Steeda's Ultimate Induction Power Pak.
Need some help guys!
Thanks!
MustangCaracas is offline   Reply With Quote
Old 02-15-2012, 06:10 AM   #2
By the way, this is my baby!
ID:	40740   Click image for larger version
Old 02-15-2012, 06:40 AM   #3
Charles.young10's Avatar
Originally Posted by MustangCaracas
Hi there!
Its virgen. Stock
Thanks!
Before you do a throttle body, get a CAI and tuner.. That will give up the most hp gain for the buck
Charles.young10 is offline   Reply With Quote
Old 02-15-2012, 07:01 AM   #4
That's the steeda's stuff that i mentioned.
So, wich throtle body would you recomend me?
Old 02-15-2012, 07:13 AM   #5
Sorry didn't see that, I just read stock and then throttle body, and went straight to reply, lol
What is the goal of your car? Throttle body doesn't really do a whole lot on litely modded cars
Old 02-15-2012, 07:18 AM   #6
Dont worry
I want to increase rwhp and acceleration. Im not interested in top speed.
A friend on mine told me that just by chaging the throtle body, the car will gain a lot of hp and rwhp
Old 02-15-2012, 07:25 AM   #7
Dont worry
Well, not calling your friend a liar, but it might help "slightly" in acceleration, but you won't noticed any HP gain..
I would go with some long tube headers/full exhaust after the CAI
You will notice that..
Old 02-15-2012, 07:51 AM   #8
Scott2's Avatar
Re: Mustang 2007 Modifications.
The Ford Racing 62mm is a simple bolt on. Tuning is recommended but I have no issues with mine and I have not had the car tuned since installation. I did disconnect the battery and went through the procedure to relearn the idle. I would not expect much of a power increase on a naturally aspirated car but they look great.
No adapter/spacer is required but I did replace the OEM studs with stainless steel cap screws.
Old 02-15-2012, 07:55 AM   #9
So, the throtle body aint hepful.
And the throtle body spacer? Is cheaper. Does it make the same function?
And what about underdrive pulleys?
I just want to increase rwhp but using few stuff
---------- Post added at 10:25 AM ---------- Previous post was at 10:22 AM ----------
What if I get the ford racing 62mm with tune. The change would be remarcable?
Or spacer with OEM TB
Old 02-15-2012, 08:00 AM   #10
KATO's Avatar
Originally Posted by MustangCaracas View Post
Hi there!
Its virgen. Stock
Thanks!
I agree with "Charles.young10", you do not need a Throttle Body, and it will not do what you expect/what your friend said is not accurate, it'll just be you waisting your money on that and on a Spacer. Even though I use a Steeda component, I do not know what is included with that Power Pak you mentioned, but I'm pretty sure it's probably good enough for you. Also Gears is a good add-on change. Underdrive Pulleys, I do not use because of the loss in inside Power, and I have a Amp and Subwoofer, so I avoided those.
Old 02-15-2012, 08:55 AM   #11
Ok thanks!
And about the gear.
Wich is best 4.10 or 3.(i dont remember)
Old 02-15-2012, 09:01 AM   #12
KATO's Avatar
Ok thanks!
And about the gear.
Either or, the 3.73s are good, and the 3.90s if you can find them are good, I have 4.10, they are Kick@$$, but on HWY I did lose some MPGs.
Old 02-15-2012, 09:23 AM   #13
I would like to get 4.10
Just read that the acceleration is brutal but the top speed gets decreased
I have no problem with that
Old 02-15-2012, 09:28 AM   #14
KATO's Avatar
That is True, it is crazy brutal, and as for Top speed, you won't notice that. But learn how to use them carefully, so you don't run into the back of someone in front of you. And to take it easy so you are not buying new Rear tires evry other Month.
Old 02-15-2012, 09:43 AM   #15
Hahaha no way! I just bought them!
So, im gonna buy the 4.10 gear and Steeda's pak wich comes with CAI and tuner.
If i change the CAI's elbow, the difference
Will be important??
Old 02-15-2012, 02:08 PM   #16
06Ghost's Avatar
I put the jlt3 ant sct tuner from Latemodal restoration with a custom tune from blow by and made 291 rwhp today and my car is an auto put it on the dyno today got the cai and tuner for $554 I think pm me for info if interested
06Ghost is offline   Reply With Quote
Old 02-15-2012, 03:41 PM   #17
Aggiesrok's Avatar
Will be important??
It depends, if the new elbow changes the CFM, then your tune will not match the CAI and you'll either be too lean or too rich depending on the change. The tune is based on the exact CFM allowed by the particular CAI.
Old 02-15-2012, 07:27 PM   #18
But Steeda has a kit wich offers the whole CAI with tune and a carbon fiber bigger elbow.
Does the tuner may have the tune for the new CFM??
You can see it here
http://www.steeda.com/store/steeda-p...d-mustang.html
I bought this
http://www.steeda.com/store/steeda-u...d-mustang.html
http://www.steeda.com/store/ford-rac...d-mustang.html
(4.10)
Old 02-15-2012, 08:26 PM   #19
You can see it here
I bought this
(4.10)
In short yes, it will (well, it better, lol) have the tune you need.
Good choice with steeda. Great product. JLT is the better bang for your buck, BUT steeda DOES push out "slightly" I mean "SLIGHTLY" more HP then JLT
Next up is long tube headers and full exhaust!
Old 02-15-2012, 08:43 PM   #20
Sure!
I've always loved STEEDA. Since my old fusion.
And wich exhaust is better?? Axle back o cat back? Keep steeda? Or should i use borla, magnaflow, etc.
Ive heard that axle back and cat back are almost the same about hp gain but axle back is cheaper
---------- Post added at 11:13 PM ---------- Previous post was at 11:12 PM ----------
And wich is the difference between ceramic and normal headers??
Use bbk??
Old 02-15-2012, 10:02 PM   #21
sinister07's Avatar
I can personally attest to throttle body spacers being a waste of money- I bought an AIX brand spacer on E-bay. I dyno tested, before and after- the result was nada, zilch, zero. It was 295HP before and 295HP after.
As far as exhaust is concerned, long tubes will make power- axle backs make cool sound. Pick one that sounds good to you- we could all argue ALL day about our preferences. YouTube and MustangExhaust.com have clips of different setups, and pick one you like.
Ceramic headers have been coated to protect the finish and control heat.
2003 Mach 1
sinister07 is offline   Reply With Quote
Old 02-16-2012, 03:45 AM   #22
Thanks bro!
And short shifters really works?
Old 02-16-2012, 07:07 AM   #23
sinister07's Avatar
A good shifter is the FIRST mod I would do. I've had the Hurst, which is good, but the ones from Barton, Pro 5.0 and Steeda are are good, too. Top it off with a custom knob from GrabberPony and you've done well.
GrabberPony.com (Powered by CubeCart)
2003 Mach 1
Old 02-16-2012, 08:59 AM   #24
S197Miller's Avatar
I have the Hurst. It's good, but I've noticed that going into gear takes a little more force than stock. I guess due to less leverage of the throw?
S197Miller is offline   Reply With Quote
Old 02-16-2012, 09:37 AM   #25
And wich one should i choose from Steeda?
Sport throw short shifter?
Tri-Ax short throw?
Old 02-16-2012, 10:10 AM   #26
Tri-Ax short throw?
I would recommend MGW
Brenspeed Detroit Rocker cams, FRPP 4.10s, Steeda UDP, CMDP
Steeda CAI, Kooks LT headers with catted H pipe, SCT X3 tuned by Brenspeed,
Steeda Tri-Ax short, Corsa Axle Back.Ford Racing shocks and struts lowering spring, rear sway bar.Roush front end and rear wings
Rainson is offline   Reply With Quote
Old 02-16-2012, 10:32 AM   #27
sinister07's Avatar
+1 on the MGW. Quality product.
2003 Mach 1
Old 02-16-2012, 11:29 AM   #28
You already have started with steeda CAI, I would stick with them.. I personally like the tri-ax better then the sport
Old 02-16-2012, 06:26 PM   #29
Well!
I just bought the tri ax shifter with the 4.10 gear.
That in addition with the CAI and the sct tuner would increase slightly my ponnys rwhp?
Old 02-16-2012, 09:36 PM   #30
Well!
You are going to see/feel a HUGE difference!
Old 02-17-2012, 03:34 AM   #31
Awesome!
Ill let you know boys
Old 02-19-2012, 08:32 AM   #32
Hi guys!
Remember that we discussed BBK's Throtle body efficence? Well, just read that it increases 10 - 15 RWHP.
If i have Steeda's CAI and SCT tuner, my rwhp will be increased to 35 - 40, or im wrong?
Also got Tri ax Short Shifter and 4.10 gear.
Old 02-19-2012, 10:37 PM   #33
sinister07's Avatar
The biggest change you will see is the "seat of the pants" feel of the car. A good tune will adjust the throttle response, and the the car will feel so much more fun. Add the gears, and the the precise shifting of the Tri-Ax, and the Mustang will feel like a totally different machine. Good job, please keep us posted on your progress.
2003 Mach 1
Old 02-20-2012, 04:58 AM   #34
Thanks!
Of course ill be in touch!
So the new throtle body is not worth it
Old 02-20-2012, 06:09 AM   #35
Im thinking of get some new brake kits
---------- Post added at 08:39 AM ---------- Previous post was at 08:27 AM ----------
With front kit would be enough?? I heard that they have they do 75% of the job
Useful Mustang Information - READ THIS FIRST! Trojan Horse 1979-1995 Mustang GT 24 11-19-2012 09:54 PM
New mustang owner V6 powered New Member Introductions & Greetings 29 02-21-2012 05:02 PM
Mustang Lover Joyce New Member Introductions & Greetings 9 02-17-2012 12:18 PM
Looking for a mustang Flo joe 1979-1995 Mustang GT 6 02-15-2012 01:22 PM
My First :: 2004 Ford Mustang V6 40th Anniversary Jetsnix Member Garages 0 02-14-2012 05:07 PM
09:42 AM
