Transmission noisy! - Mustang Evolution
Old 02-16-2012, 06:29 PM   #1
MustangCaracas's Avatar
Transmission noisy!
Hi guys!
Each time I go from neutral to any gear i feel like if the transmissions moving! The same happens but noisier whem i turn slowly.
MustangCaracas is offline   Reply With Quote
Old 02-16-2012, 06:33 PM   #2
BaSohol's Avatar
How many miles?
2007 Ford Mustang GT 5spd
Old 02-16-2012, 06:38 PM   #3
55.000km, like 34.000 milles
Old 02-16-2012, 07:07 PM   #4
BaSohol's Avatar
And can you describe the noise
---------- Post added at 08:07 PM ---------- Previous post was at 08:03 PM ----------
And as long as the cars moving the trans is moving and if I shift slow I feel the gears spinning especially when it's cold
Old 02-16-2012, 07:09 PM   #5
Sure!
When im turning slow, sounds like if something shakes very fast!
And when i change from neutral to any gear, sounds like if it moves forward and backwards and hits something
Old 02-16-2012, 07:25 PM   #6
BaSohol's Avatar
Oh haha ya sounds like your either letting out the clutch to fast or not giving it enough gas
Old 02-16-2012, 07:43 PM   #7
Not really! I know the gas stuff sound but aint like that because when i drive through rough surfaces, sounds too! I think that something went broke but where can i find some pieces of there?
Old 02-16-2012, 07:56 PM   #8
BaSohol's Avatar
Ya I can't really help you with seeing the car in person, but get under and check for anything loose
Old 02-16-2012, 08:29 PM   #9
The problem is that im in caracas and the knowledge of mustangs and this specific menchanic aint great..
Old 02-16-2012, 08:36 PM   #10
Aggiesrok's Avatar
You should be able to check some stuff yourself. When you're turning push in the clutch and see if the noise stops. Check you're drive shaft for bad u joints. If you punch while going 5 mph and in 1st gear, does the clutch slip?
Did you buy it new and is it completely stock?
Old 02-16-2012, 08:40 PM   #11
BaSohol's Avatar
I heard to check the clutch keep it in fifth and cruise at a low speed and the punch it, cause that puts more load on the clutch
Old 02-16-2012, 08:43 PM   #12
Aggiesrok's Avatar
Sounds good, he just needs to try some stuff and narrow it down a little. How much is gas in Venezuela?
Old 02-16-2012, 08:49 PM   #13
When the car is stopped and i put 1st, theres a punch in the back. And when im turning slow, the punch is faster. In this case, im holding the clutch. The noise comes from the back. And the clutch never slips
The gas here is less than 1$ per gal.
I put gas to my baby and my most expensive tank was 5 Bolivares that is less than 1$.
Old 02-16-2012, 08:54 PM   #14
Aggiesrok's Avatar
Jealous of the $1 gas. When you say punch, you mean knock, right? Is it worse turning right or left?
Old 02-17-2012, 03:33 AM   #15
It is worst in both directions. The most lf the times when im turning right but to the other side sounds too
Old 02-17-2012, 06:31 AM   #16
Aggiesrok's Avatar
Sounds like its in the rear end. Did you buy it new? Someone may have changed out the rear end gears and didn't shim them properly or just did a bad install.
Old 02-17-2012, 06:38 AM   #17
I bought it used like a year ago. But the sound started when i changed my clutch like 7months ago.
Old 02-17-2012, 07:01 AM   #18
Aggiesrok's Avatar
You should have said that to begin with.
Why did you need a new clutch with such low miles?
Old 02-17-2012, 07:09 AM   #19
Sorry!
I was parking in reverse my car and it fell into a whole and i put first gear and tried to go out. Doing that i ****ed the clutch
Old 02-17-2012, 07:45 AM   #20
Aggiesrok's Avatar
Sorry!
You may have more damage from that. You fixed the clutch, but there may be some rear end or axle damage. You're probably going to look in the rear end and check gears, axles, bearings. If you're going to swap for bigger gears anyway, that's a good time to check it all out.
Old 02-17-2012, 08:54 AM   #21
Re: Transmission noisy!
So, should i buy this?
Rear End Installation and Bearing Kit (8.8in) R8.8RMK - Free Shipping!
---------- Post added at 11:24 AM ---------- Previous post was at 11:23 AM ----------
Old 02-17-2012, 09:03 AM   #22
BaSohol's Avatar
Sorry!
Haha here's some info that helps in the beginning haha describe more, did anything thing come in contact with the drivetrain?
Old 02-17-2012, 09:05 AM   #23
Yes! The floor hahah
Old 02-17-2012, 09:10 AM   #24
BaSohol's Avatar
Eww did the driveshaft ever come in contact with anything? I would assume that you some how damaged the gears but who knows
Old 02-17-2012, 09:16 AM   #25
KATO's Avatar
I'm agreeing with "Agiesrok", I think you got a little more damage, than you originaly thought. Sucks that you are in a place where there is not a Handfull of help all around like here in the States. Good luck with fixing that. And make sure, that when you tell other Mechanis about the problems, that you tell them also about the "whole" you got stuck in.
Old 02-17-2012, 10:15 AM   #26
http://www.americanmuscle.com/rearendrebuild.html
Old 02-17-2012, 10:54 AM   #27
BaSohol's Avatar
I don't recommend buying anything till you know what's broken
Does everyone like there mt82 transmission GE3G 2011-2014 Mustang GT 66 03-29-2016 09:13 AM
Tremec TR-3650 Transmission Gear Ratios DarkHorse 1996-2004 Mustang GT 33 06-27-2013 02:13 PM
Clicking near transmission MTilly 2005-2010 V6 Mustang 4 02-07-2012 03:29 PM
Ford racing manual transmission cooler air scoop gt 2011-2012 avengnd 2011-2014 Mustang GT 3 02-03-2012 09:30 PM
4.6 manul transmission Cervantes107 1996-2004 Mustang GT 5 02-01-2012 01:26 PM
04:33 AM
