Brakes! - Mustang Evolution
Old 02-19-2012, 06:34 AM   #1
MustangCaracas's Avatar
Brakes!
Hi there again!!
Im wondering wich Brake kit do I need. Rear or front??
This info may help you for helping me haha I just bought for my baby 4.10 gear, Tri Ax Short Shifrter, Steeda's CAI and SCT tuner.
And wich Brand?
I Know Brembo is the best but, SSBC are such good as Brembo? Wich other brands?
MustangCaracas is offline   Reply With Quote
Old 02-19-2012, 07:14 AM   #2
GTRob504's Avatar
Check out Baer and Willwood as well.
2008 Metallic Alloy GT Convertible Premium
Show : black top| 18" bullitt polished wheels| CDC light bar and black billet replacement grilles | black/amber corner lights | GT500 rear spoiler| AH chin spoiler Go: FRPP CAI with StangHi tunes | Kooks LT's | FR500 axle back | Steeda Sport springs | Koni STR.t struts/shocks | J&M camber plates | UMI adj. panhard bar | LCA relocation brackets | GT500 LCA's | Hurst Billet shifter | 3.73 gear | FRPP axle girdle | Baer Rotors and Pads
GTRob504 is offline   Reply With Quote
Old 02-19-2012, 07:17 AM   #3
Thanks!
But rear or front???
Old 02-19-2012, 08:06 AM   #4
Either do all the way around you can get willwoods kit for about 3 grand or do just front
Big Johnson is offline   Reply With Quote
Old 02-19-2012, 09:27 AM   #5
GTRob504's Avatar
Unless you are racing or have 20 inch rims, big brakes won't serve much more than just a cosmetic upgrade. There are plenty of nice stock size after market rotors that will function and look better than the stock ones. Spending 1.5 to 3 k might be better spent on some HP mods. If I were going to upgrade my wheels and brakes I would look into Baer or Brembo front and rears.
Old 02-19-2012, 09:36 AM   #6
Ok!
I have 18" wheels but im always running!
Old 02-19-2012, 09:43 AM   #7
GTRob504's Avatar
I know there are only a handful of 18" wheels that can accommodate a big brake kit. There are some threads out there of guys who are installing the 13" inch rotors from 2012 5.0 onto 05-09 GT with just having to swap out the caliper bracket. Our stock front rotors are 12.44".
Old 02-19-2012, 09:46 AM   #8
deadsp0t's Avatar
Also consider the fronts do 75% of the work.
That's unimpressive
Old 02-23-2012, 09:40 PM   #9
Hi there!!
Just bought DBA rotors (rear and front) with hawk ceramic pads
Old 02-25-2012, 09:34 AM   #10
Labrat's Avatar
Re: Brakes!
I did both front and rear, but do front first. I have SSBC, their tech help is superb. Research wheel fitment as well. Most companies will have a template that you can download and cut out to make measurements.
Labrat is offline   Reply With Quote
Old 02-25-2012, 10:39 AM   #11
Thats awesome! What you think about dba rotors
Old 02-25-2012, 10:45 AM   #12
Labrat's Avatar
Re: Brakes!
Don't know much about DBA, but the SSBC's come with slotted rotors. From the research that I've done....cross drilled rotors if not done right can lead to cracking. That's mostly from not putting a champher or deburring the hole.
Old 02-25-2012, 10:48 AM   #13
Sure! And that might suck!
I watched them in AmericanMuscle and made a research and they seemed to be very cool
Old 02-25-2012, 10:52 AM   #14
Labrat's Avatar
Re: Brakes!
I just looked at the DBA's at AM and they look to have a champher on them. Kinda of pricey but you get what you pay for....so I would think that they are probably a pretty good product and you won't have any probs with AM if you need help or returns.
Old 02-25-2012, 12:41 PM   #15
Ill let you know when i get mine installed!
The recomendations are pretty good
Old 02-29-2012, 08:22 AM   #16
Scott2's Avatar
Re: Brakes!
I went with Baer Pro Plus 6P, 6 Piston Calipers, 14” 2 Piece Slotted & Drilled Rotors on the front:
and OEM size Baer slotted and drilled rotors in the rear:
Old 02-29-2012, 09:44 AM   #17
Labrat's Avatar
Re: Brakes!
That's a sweet set also...!!
brakes squeaking help!!!!!! really annoying austinknoll Pre-2005 V6 Mustang 11 02-16-2012 09:31 PM
Brakes Vacuum Question MC770 1979-1995 Mustang GT 8 02-15-2012 11:11 AM
Better brakes Albo22 1996-2004 Mustang GT 3 02-11-2012 06:53 AM
Brakes Lets gallop General Mustang Discussion 13 02-05-2012 01:19 AM
brakes Mustang_Daddy 2005-2010 Mustang GT 14 01-29-2012 12:06 PM
07:13 PM
