Centrifugal charger vs turbocharged vs supercharged - Mustang Evolution
Old 02-23-2012, 09:33 PM   #1
MustangCaracas's Avatar
Wich one is better and why?
Want to use it daily and get some action sometimes.
MustangCaracas is offline   Reply With Quote
Old 02-23-2012, 09:38 PM   #2
Charles.young10's Avatar
Your not going to like this, but I wouldn't add anything like that to your daily driver.. To many horror stories for me..
Charles.young10 is offline   Reply With Quote
Old 02-23-2012, 09:39 PM   #3
BaSohol's Avatar
Turbo is the best for daily driving, your not always in the boost like a supercharger
2007 Ford Mustang GT 5spd
Old 02-23-2012, 11:40 PM   #4
Sirtat's Avatar
horror stories !?!? that's your problem you listen to too many "stories" lol
and I bet there is 10x more supercharged daily drivers then there are turbo charges daily drivers...
I drive mine daily at 16 psi and im not always in boost !! only when throttle is more then say 50% depressed
I've never had a higher HP car with turbos so I can not judge them, I have however had 3 different mustangs with supercharges and have nothing but good to say about them !!
just my .02
IBLT IT
2005 Promar Performance forged long block
Kenne Bell 2.8L LC mammoth supercherger
and and and I DRIVE IT LIKE I STOLE IT !!!!
http://www.youtube.com/watch?v=_K_QJ...ure=plcp<br />http://www.youtube.com/watch?v=NWfvYVYlfio&feature=plcp
Sirtat is offline   Reply With Quote
Old 02-24-2012, 04:53 AM   #5
just my .02
Wich one you have installed now?
In response, wich one is faster? TC or SC?
Old 02-24-2012, 09:33 AM   #6
sinister07's Avatar
Re: Centrifugal charger vs turbocharged vs supercharged
I put a Paxton Centrifugal Novi 2200 supercharger on my son's '06. He drives it a lot, probably not daily, but a lot. He has had absolutely no problems with the set-up. The nice thing about a centrifugal is that you don't get into the boost until about 3000 RPMs so around town the car is docile as a kitten. Plant your right foot, it turns into a real animal. At 10 pounds of boost it dyno'ed 480HP to the wheels. The only problem I have with turbos is the heat under the hood. Unless you get the STS kit that puts the turbos under the rear bumper.
2003 Mach 1
sinister07 is offline   Reply With Quote
Old 02-24-2012, 10:39 AM   #7
Stang.racr's Avatar
I've had a daily driven supercharged car and never had a problem. I love turbos but but everybody that I know has to many problems with their cars. Granted they are super fast and it's free horse power to a extent, but to each their own
having a fine car that is slow is like having a hot girlfriend that won't put out!
Stang.racr is offline   Reply With Quote
Old 02-24-2012, 10:49 AM   #8
My DD is a SC cobra and if you drive it "normal" you barely use the boost and at times zero boost. The fact of the matter is that SC are instant power compared to TC which I dislike. Granted they make great power but I'd go SC for a DD but that my 2cents
SNK3BTE04 is offline   Reply With Quote
Old 02-24-2012, 11:55 AM   #9
Thanks a lot!
And do i need many mods in the engine in order to have 8+ psi boost? Like 10-12 psi
Old 02-24-2012, 12:24 PM   #10
S197Miller's Avatar
Thanks a lot!
It would be safer.
S197Miller is offline   Reply With Quote
Old 02-24-2012, 01:04 PM   #11
sinister07's Avatar
As long as you keep the power level below 500 rwhp, and you don't drive like a crazy guy, the stock internals should be ok. That being said, if you have the cash, get the forged rotating assembly. And then drive any way you want!
2003 Mach 1
Old 02-24-2012, 01:06 PM   #12
I hope your seeing ALL of those "as long as".... "if"..... "safer".... in all of those post..
Old 02-24-2012, 01:54 PM   #13
there is no correct answer, its all about what you want out of the car in order to determine the application that best fits your needs.
Old 02-24-2012, 02:02 PM   #14
Dion11197's Avatar
To add some more, lol.... I had a DD that had a centrifugal SC. Some may be confused or confusing. A roots or twin screw SC will make instant boost off idle (KB, whipple, eaten)... That's how it's designed, a centrifugal (Paxton, vortec, procharger) have to "spool up" to make boost and are similar to a turbo in design and operation... Just one is driven off the exhaust (turbo) and one is belt driven (centrifugal).
Personally for a DD I would go either SC'd route.... Depending on what your goals are and what your driving style is. Plus if you already have exhaust work done the turbo kit ends up being more expensive in the long run. If you want boost and power down low in the rpm's go roots or twin screw... You want more top end power and better "stock like" drivability around town.... Go centrifugal. Both can make the same peak HP, but the power just comes on at different points..... That's my .02 or maybe .05
---------- Post added at 02:02 PM ---------- Previous post was at 02:01 PM ----------
+1
Dion11197 is offline   Reply With Quote
Old 02-24-2012, 02:38 PM   #15
sinister07's Avatar
Exactly as Spector said- you have to determine what you want out of the car, and take into consideration how you intend to drive it. Then make your purchases accordingly.
2003 Mach 1
Old 02-24-2012, 03:05 PM   #16
Sirtat's Avatar
+2
currently I'm running a vortech v-2s making 16.5 psi @5800 rpm on my 2005 mustang gt as a daily driver all day everyday where ever I go I take my stang & I love it and wouldn't be able to own another mustang that wasn't supercharged, however after seeing first hand, the capabilities of the kenne bell roots type blower makes me want to sell my vortech and get a kenne bell... with that being said, if you do decide to get a supercharger seriously consider the kenne bell or just so you know I might be selling mine sooner then later
IBLT IT
Old 02-24-2012, 03:47 PM   #17
root blowers and twin screw (different blower types but both are positive displacement blowers) make great low end power and are more fun for daily drivers, centrifugal make more top end power, and turbos are better all around for power per psi due to they are not taking power to make power. They are generally just more expensive and require more stuff to install it.
Old 02-24-2012, 09:22 PM   #18
Im watching the kenne bell Stage 1 and it is 501-639RWHP. So, you said that bellow 500 everything stock will be ok. There in kenne bell says that it works good on a stock engine. What would you recommend?
Old 02-24-2012, 09:46 PM   #19
GMSPNKR's Avatar
Ok bro I have a 05 gt convertable and i installed whipple 500hp kit on it and the engine was stock. lt was a dd and i was pushing tha **** out of the car and i had no problem with it. I had a good tune. I drove it like that for 15k miles. Than i wanted more hp so i built my own forged motor and saved a lot of money by doing myself. If u wanna go FI than go for it but supercharged stang is already fast for dd. make sure u get a good dyno tune
GMSPNKR is offline   Reply With Quote
Old 02-25-2012, 05:40 AM   #20
And wich one of these would be the best?
Old 02-25-2012, 07:52 AM   #21
Dion11197's Avatar
Definitely go with a self lubricated unit..... That way you won't have to tap a hole in your oil pan, so of down the road you choose to switch it out for a twin screw or take the blower off to sell it you won't have issues of buying a new oil pan. I've heard good things about the 2200 kits also.
---------- Post added at 07:52 AM ---------- Previous post was at 07:50 AM ----------
Also I would recommend investing In the intercooled kit.
Old 02-25-2012, 12:43 PM   #22
And what about vortech and kenne bell? Wich one would you recommend me
Old 02-25-2012, 01:19 PM   #23
GMSPNKR's Avatar
I would say go with kenne bell. Easy to install, reliable, and powerful
Old 02-25-2012, 01:32 PM   #24
Sirtat's Avatar
buy a kenne bell!! or buy my vortech v2 so I can buy the kenne bell !!
kenne bell for the win !! lol
IBLT IT
Old 02-25-2012, 02:17 PM   #25
wyostang08's Avatar
Region: Wyoming
What's everybody s view on the Roush m90?
wyostang08 is offline   Reply With Quote
Old 02-25-2012, 02:28 PM   #26
Sirtat's Avatar
it's not a kenne bell !! and that is all that matters
IBLT IT
Old 02-25-2012, 06:29 PM   #27
And wich one do you recommend to me? But stage 1 kit. There are too many
Old 02-25-2012, 08:35 PM   #28
wyostang08's Avatar
Region: Wyoming
Ouch lol I was looking at kenne bell and Whipple too
Old 02-25-2012, 09:27 PM   #29
Stang.racr's Avatar
They are good they just lack the size as some of the bigger blowers. They are mostly overlooked cause of their price being almost the same as whipple and kb
Old 02-25-2012, 09:55 PM   #30
wyostang08's Avatar
Region: Wyoming
I'm just scared of blowing up my stock motor lol
Old 02-26-2012, 08:09 AM   #31
I'm running a m90 at 9psi and 441 hp at the wheels but I will soon be going up to 12 or 13 psi the reason I went with the m90 over anything was I got the polished one for like a thousand below msrp.
Big Johnson is offline   Reply With Quote
Old 02-26-2012, 09:41 AM   #32
Hey guys!
If i buy any kit (KB or Paxton) will i loose my steeda CAI? I mean theres a CAI that i wont use right? Mine or kit's
Old 02-26-2012, 01:09 PM   #33
GMSPNKR's Avatar
Yeah you'll get a new air intake with a supercharger
Old 02-26-2012, 01:15 PM   #34
And may i use steeda's?
Old 02-26-2012, 01:19 PM   #35
Probably not. Most of the blowers come with a cai made specifically for that application so idk y you would want to
nos vs meth 2Greeny7 Pre-2005 V6 Mustang 16 02-23-2012 06:54 AM
Mustang vs Mustang vinnygt The Bar 4 02-19-2012 10:15 AM
HCI vs HI cgarray17 1979-1995 Mustang GT 1 02-18-2012 09:28 PM
supercharged GT spark plugs? ? victory181 1996-2004 Mustang GT 3 02-15-2012 06:50 PM
1999 Gt vs 2010 3.5L Altima Coupe FORDGT14 1996-2004 Mustang GT 44 02-13-2012 03:11 PM
10:22 AM
