Speedo Off w/ SCT Tune - Mustang Evolution
Old 02-27-2012, 10:42 AM   #1
Aggiesrok's Avatar
I've updated the tuner with the latest firmware and tuner version. I entered my rearend 3.55 and my revs/mile 740 and my speedo is off about 10%. I checked it with a GPS app. The app is dead on in my wife's Explorer but off 10% in my 07 mustang GT. Any ideas?
Old 02-27-2012, 07:29 PM   #2
Aggiesrok's Avatar
Nobody got nothing?
Old 02-27-2012, 08:06 PM   #3
irishn8's Avatar
I got the same problem bro... idk wtf
Old 02-27-2012, 08:21 PM   #4
Charles.young10's Avatar
The only thing I can think of...
What tire size? That can mess things up.. I'm sure you know
Charles.young10 is offline   Reply With Quote
Old 02-27-2012, 08:23 PM   #5
irishn8's Avatar
Ya that's why we set the Revs-per-mile.
Old 02-27-2012, 08:27 PM   #6
Custom rims? You may have to calculate it yourself if it changed the standard diameter
Old 02-27-2012, 08:29 PM   #7
Aggiesrok's Avatar
Yeah I've stock rims for CS. 235/50/18 which calculates to 740 revs per mile.
Old 02-27-2012, 08:32 PM   #8
Ah! Yeah stock rims shouldn't be a problem.. Dont know then.. Sorry.. That was the only thing I could think of
Old 02-27-2012, 08:38 PM   #9
irishn8's Avatar
Nah doesn't matter, revs per mile is just how many times a given point on the outermost part of the tire makes one complete revolution in a mile.
However, now that I think about it, a tire doesn't maintain its shape completely, it always has that flat part on the ground. So its like having a slightly smaller tire...dude that's gotta be it! Right?
Old 02-27-2012, 08:51 PM   #10
So your trying to tell me a bigger diameter tire wont change that?
Here maybe this will help..
http://wiki.answers.com/Q/Will_the_s...on_larger_rims
Old 02-27-2012, 09:00 PM   #11
irishn8's Avatar
If u got a bigger diameter tire and DIDN'T set the revs per mile then ya it would effect that.
Old 02-27-2012, 09:00 PM   #12
Aggiesrok's Avatar
Even a full inch change in diameter only yields a 2 mph error.
I'm getting new tires this week, so we'll see if that has an effect.
Old 02-27-2012, 09:06 PM   #13
irishn8's Avatar
Sounds right to me, my speedo is off by about 2mph I have 275/40 17s equates to 786 rpMi
Old 02-28-2012, 08:30 AM   #14
Aggiesrok's Avatar
Re: Speedo Off w/ SCT Tune
But that doesn't solve the problem. It means that our tires would have to be over 4 inches smaller than stated in order to be off by over 5 mph at 60.
Does anyone with a Bama tune have this problem? Mine is a SCT tune.
Old 02-28-2012, 08:41 AM   #15
I know the 410 guys have problems, but 355 are/can be stock gears.. You really shouldn't have any problems
Old 02-28-2012, 09:52 AM   #16
generally sct lets you enter rotations per mile not just XX gearing right?
Old 02-28-2012, 10:26 AM   #17
Aggiesrok's Avatar
Yeah I can enter axle ratio and revs per mile. But it doesnt seem to be factored in.
Old 02-28-2012, 10:39 AM   #18
RedGT's Avatar
Try to get the builder to program the different gear ratio and tire size into the tune. They should be able to do that. Or try to change the settings again. Maybe it didn't save. Not overly helpful I know but it's better than nothing.
RedGT is offline   Reply With Quote
Old 02-28-2012, 01:59 PM   #19
Aggiesrok's Avatar
So if I fake out the speedo by putting the wrong revs/mile number for the tire size, in order to get the correct speedo reading, will this have any affect on the tune?
i.e. does the tire size factor into anything besides the speedo calc?
Old 02-29-2012, 07:54 AM   #20
RedGT's Avatar
I highly doubt it. The tune isn't something you can change on the tuner. The tune has fuel and air ratio settings, throttle response, etc. The tire size doesn't change those factors. Another dumb question, you sure you got the right revs/mile?
Old 02-29-2012, 09:41 AM   #21
Aggiesrok's Avatar
Yeah I've checked that numerous times. 235/50/18 = 740 revs per mile.
Old 02-29-2012, 10:44 AM   #22
RedGT's Avatar
News flash dude. I'm getting 763.3 revs/mile. Check out 1010tire.com and tirerack.com. I think your source of info might be the problem.
Old 02-29-2012, 11:10 AM   #23
Aggiesrok's Avatar
I get close to 740 when doing the math, but on tirerack they seem to calculate the revs while taking into consideration the flattening on the ground and not purely by math. Their calculation for my stock tire is 759 and with little tread left, it would be even higher. I'm getting 255/45/18's this Friday and I'll try the tirerack calc of 773 for those and see what happens. After all this, as tires lose inflation, your speedo would begin to give an increased reading.
Thanks for the effort, it seems to be the right answer.
Old 02-29-2012, 11:14 AM   #24
Yes it will affect your odometer as well....
Old 02-29-2012, 01:02 PM   #25
RedGT's Avatar
No problem. Glad to get you an answer.
Old 02-29-2012, 03:12 PM   #26
Aggiesrok's Avatar
More evidence that you were correct.
I went and measured my tire from the ground to the center of the rim and multiplied that by 2 to get the true rolling diameter. After using that number and calculating the revs per mile, I get 784 revs per mile instead of the 740 entered into the tuner. This computes to be almost a 5 mph higher reading on the speedometer vs. actual speed.
Therefore if you want to get the correct speed, the formula is as follows:
63,360 / (2 * ∏ * r)
(5280 * 12) inches in a mile divided by (2 * ground to center of rim * ∏) circumference of wheel = revs per mile.
Old 02-29-2012, 03:59 PM   #27
Sorry but have to point out, I told you that yesterday......
Old 02-29-2012, 05:08 PM   #28
Aggiesrok's Avatar
Sorry it didn't sink in until I heard it again and in a different way. Thanks.
Old 02-29-2012, 05:19 PM   #29
Lol, not a big deal... Doesn't help when someone post stuff, and they don't know what they are talking about..
Old 02-29-2012, 07:39 PM   #30
irishn8's Avatar
Cool so I had the right idea. Thanx for the formula, ill adjust my tuner and see what happens. Did it work for u?
Old 02-29-2012, 08:16 PM   #31
Aggiesrok's Avatar
New tires Friday, so I'm going to wait. Unless I do it tomorrow just to test.
Old 03-01-2012, 02:40 AM   #32
RVAStang05's Avatar
I'm horrible at math, but thought I'd mention.. I went from the stock wheels 17" to 18" rims to 18" rims with 245/45-18 in front ( 275 in back). I had the SCT/bama tune already on when I switched wheels.
I've used 3 different gps/speedo apps on my phone to check accuracy and my spreedo is right on.
Pype Bomb Axle-Backs, JLT CAI, SCT Tuner w/Bama tuning, BMR Strut Tower Brace, CDC Classic Chin Spoiler, Black Hood Pins, Black Shorty antenna, Tru-Billet Black Anodized GT engraved Fuel Door, Black Lemans Stripes, Black Rocker Stripes, Brushed Aluminum finish dash and vents, Stack Racing pedals, Charcoal Black Leather Interior, Gloss Black Bullitt Motorsport Wheels, Nitto 555 tires, staggered set up (9/10), 35% tint, Shaker 1000 Stereo with Kicker Upgrades, Ultra Violet footwell, license plate and dome lighting
RVAStang05 is offline   Reply With Quote
Old 03-01-2012, 12:38 PM   #33
Aggiesrok's Avatar
It worked! I had to try it before the new tires. I used the revs I calculated from measuring and it's dead on.
Old 03-01-2012, 12:52 PM   #34
irishn8's Avatar
Awesome!
what are the advantages of a tune when you have a 5 speed ? jrny99 2011-2014 Mustang GT 3 02-26-2012 08:03 PM
Time to Shine, off to the Body Guy Jeffola 2011-2014 Mustang GT 23 02-26-2012 10:23 AM
Sct tuner tbonestang AmericanMuscle 24 02-26-2012 09:33 AM
SCT tuner owners help me out! Project Pony Pre-2005 V6 Mustang 25 02-25-2012 11:45 PM
Speedo recalibrate McNassty SVT Mustang 8 02-24-2012 06:16 PM
12:15 PM
