410s installed!!!! First impressions - Mustang Evolution
Old 02-28-2012, 07:15 PM   #1
BaSohol's Avatar
Well I have 470 miles to go before I can give em hell, but I did get half throttle on them and it feels like its floored haha, it seems to be easier to drive, I got stuck in traffic and that seemed to be a PITA with my old gears but it's so easy to take off from a stop, doing 40-45 down the rode you kinda feel like you want to shift again when your already in 5th but that's because your so use to it shuddering in 5th around those speeds, avg gas mileage around town was 20.2 in traffic and I have a corrected speedo btw if that matters, can't give performance details yet but it feels like its going wanna boil the tires off the rim
Also I got the hurst installed at the same time, it's stiff and notchy and very short throws with a long lever, No noise in mine what so ever or vibrations and I didn't have the rubber pads installed between the shifter and lever, I guess it's all about how you install it
2007 Ford Mustang GT 5spd
Old 02-28-2012, 08:01 PM   #2
Stang.racr's Avatar
Yeah my 500 mile break end was about 495 miles short but it took me some getting used to on mine. A quarter inch of the gas pedal took off a lot faster than before leaving a crow hop feeling lol
having a fine car that is slow is like having a hot girlfriend that won't put out!
Stang.racr is offline   Reply With Quote
Old 02-28-2012, 08:16 PM   #3
Aggiesrok's Avatar
How hard was the shifter to install. That's on my soon list.
Old 02-28-2012, 08:31 PM   #4
BaSohol's Avatar
I just watched haha its not hard I just had the shop do it tho cause they had the driveshaft out, but it was like a 15min job with out the drive shaft it was only 300 for the gear and shifter install
Old 02-28-2012, 09:03 PM   #5
Re: 410s installed!!!! First impressions
I don't get this break in Talk???? Anytime me or frineds have done gears its get in and giv'r! Never had ANY issues.
You'll love the 4.10's when you actually decide to get on it
rk122075 is offline   Reply With Quote
Old 02-28-2012, 09:08 PM   #6
I plan to have my 4.10s installed in 3 weeks..cant wait.
How many hours did they say the install took?
Labor rates may vary by location, but good mechanics should be able to do the work in a similar amount of time.
redfire is offline   Reply With Quote
Old 02-28-2012, 09:08 PM   #7
Stang.racr's Avatar
I didnt wait. I got mine done by steen racing along with a lot of other work. I got to pick it up and watch a dyno run. They got on it for the dyno run and I got on it after the dyno run lol
Old 02-28-2012, 11:16 PM   #8
BaSohol's Avatar
Took about 3-4 hours and you can get on it just hard launches and banging gears are bad during break in, well my gears don't whine and I wanna keep it that way and it's raining for the next 3 days anyways haha
Old 02-28-2012, 11:32 PM   #9
Aggiesrok's Avatar
Since they were professionally installed and properly shimmed, probably not as big a deal for the 500. But patience is free insurance in this case.
I've got 3.55. Kinda wanting to get 3.73, but afraid it won't matter much and unsure of 4.10 since its a DD and 5 speed. I'll see how you like yours.
Old 02-29-2012, 04:57 AM   #10
GTRob504's Avatar
If the Hurst ever starts to make any noise here is what you do
Install 2 of the rubber shims
Spray the center bearing with som white lithium grease
Teflon tape the threads on the shift knob
2008 Metallic Alloy GT Convertible Premium
Show : black top| 18" bullitt polished wheels| CDC light bar and black billet replacement grilles | black/amber corner lights | GT500 rear spoiler| AH chin spoiler Go: FRPP CAI with StangHi tunes | Kooks LT's | FR500 axle back | Steeda Sport springs | Koni STR.t struts/shocks | J&M camber plates | UMI adj. panhard bar | LCA relocation brackets | GT500 LCA's | Hurst Billet shifter | 3.73 gear | FRPP axle girdle | Baer Rotors and Pads
GTRob504 is offline   Reply With Quote
Old 02-29-2012, 07:14 AM   #11
BaSohol's Avatar
Ya he locktited everything and greased every bushing, I'll see how long it last, I didn't install those 2 rubber shims either
Old 02-29-2012, 07:50 AM   #12
RedGT's Avatar
I just put a steeda Tri-Ax in mine. It's not hard, much easier if you have access to a lift, but it can be done on jacks. Just make sure you have a little locktite for the driveshaft bolts. Did it in 2 hours, with minor complications.
RedGT is offline   Reply With Quote
Old 02-29-2012, 08:06 AM   #13
BaSohol's Avatar
Hows the height on the steeda? I passed that one up cause it looked like you don't get good leverage
Old 02-29-2012, 10:49 AM   #14
RedGT's Avatar
The height is pretty good. I personally like the 2-3 shift. It's very smooth, very accurate. A bit tough to get into 1-2 and 5-R because it's natural position is center neutral. Its very stiff but for a fast shift on the 1/4 mile, it's what I need. The throw from front to back is also improved, quite a bit. Don't worry about leverage, it does it's job quite well.
Old 02-29-2012, 10:57 AM   #15
BaSohol's Avatar
I put the car thru its paces today, I didn't launch it hard tho but ya it pulled hard and stays in RPM 2-3 is easy with the hurst and second doesn't last long so that's good to be able to hit 3rd with some accuracy, I just need a monster tachometer and I'll be good, feels like your taking your eyes off the road when you glance at the RPMs
Old 02-29-2012, 01:04 PM   #16
stampde's Avatar
start practicing that 1 - 2 shift ,because when you launch hard you have to shift in about 1 sec , LOL
2011 GT Auto
Old 03-01-2012, 02:00 PM   #17
Aggiesrok's Avatar
Does the Hurst shifter come with a boot or does it use the oem boot?
Old 03-01-2012, 02:09 PM   #18
BaSohol's Avatar
Oem boot and hardware
Old 03-04-2012, 01:15 PM   #19
BaSohol's Avatar
More news on the gears, the keep next nose to nose with a new 5.0 that has an intake and tune
Old 03-04-2012, 01:32 PM   #20
Blackcat's Avatar
I have to say the guy with the 5.0 don't know how to drive if u kept that close what r ur mods again cause my car has a hard time when i had full bolt ons now it's really easy since I have my ford racing supercharger now
Blackcat is offline   Reply With Quote
Old 03-04-2012, 06:25 PM   #21
BaSohol's Avatar
I have 410s tune and intake and damn good driver mod, I jumped a half car in him when I slammed second but who know how the how 1/4 would of played out we went to about 60
---------- Post added at 07:25 PM ---------- Previous post was at 07:24 PM ----------
Are 1st run was dead even
Old 03-04-2012, 07:02 PM   #22
Blackcat's Avatar
I know guys with 5.0 and an intake and tune on there and running low 12 almost 11 in a quarter mile I bet ur a hell of a driver but u put someone with equal skills in the 5.0 he will leave you
Old 03-04-2012, 07:36 PM   #23
BaSohol's Avatar
I know there's a huge hp diff that probably would of evened out of we went a full 1/4 but 10mph-60mph it was dead even, he probably would of started walking away later and on the street 1/4 times don't count for anything my buddys very mild bolt on got stays even with this procharged 03 cobra
Aerocatch Flush Mount Hood Pins Installed! primer2tone Mustang Paint, Appearance & Detailing 16 09-25-2016 11:04 AM
First car.???! Mustangg5 General Car Discussion 147 06-03-2012 02:51 PM
Smoked L.E.D third brake light installed Project Pony Pre-2005 V6 Mustang 15 03-01-2012 02:17 PM
What to do first? Blackedout03 Pre-2005 V6 Mustang 2 02-25-2012 07:20 PM
Vibration after getting my 4.10's installed 99redgt 1996-2004 Mustang GT 7 02-25-2012 03:08 PM
12:07 PM
