Gears - Mustang Evolution
Old 03-03-2012, 10:37 PM   #1
Jayjay's Avatar
Gears
Hello, quick questions my 06 mustang gt drives like a champ. Only problem I haven't figure out if any is when I go from park to drive or neutral to drive it takes a good 2 sec for the car to drive... Should this be a concern...
I'm asking cause on other make and models I drove once its on drive it reacts on the spot not 2 sec later...
Thanks in advance for any feedback
Jayjay is offline   Reply With Quote
Old 03-03-2012, 10:51 PM   #2
BaSohol's Avatar
How many miles, and you drove other auto mustangs, you can't compare other makes and models
2007 Ford Mustang GT 5spd
Old 03-03-2012, 11:00 PM   #3
Jayjay's Avatar
This is my first mustang... It has 59,000 miles... I was wondering if it's normal or not since I never drove other mustangs. Even though I been a mustang fan since I could remember
---------- Post added 03-04-2012 at 12:00 AM ---------- Previous post was 03-03-2012 at 11:59 PM ----------
Oh it's also a automatic
Old 03-04-2012, 01:43 AM   #4
Jayjay's Avatar
Has anyone else has any input on this. Is the delay a regular thing or should I be looking at repairs.
Old 03-04-2012, 03:06 AM   #5
irishn8's Avatar
I think that's a little long, but I don't think u need need to look at repairs at the moment. If ur under warantee, have it checked, u may just need a fluid change or the fluid could be low or high for some reason. If the fluid is new and the level is correct, try an anti-slip additive and if that helps then u may need some repaires in the future. ..but then, maybe that's normal for that tranni.
Old 03-04-2012, 03:12 AM   #6
Jayjay's Avatar
Thanks a lot.. I might take it to the dealer next month to check it out... Might not be nothing br just to be in the safe side
Old 03-04-2012, 05:59 AM   #7
BaSohol's Avatar
You can't check the fluid on your mustang correct? But my old Lincoln with a 4R70W was kinda slow till I installed a shift kit, also if the fluid was low or really cold
Old 03-04-2012, 09:46 AM   #8
Aggiesrok's Avatar
Does it do it when going to reverse?
Old 03-04-2012, 03:41 PM   #9
Jayjay's Avatar
No only when putting to drive mode... I'll be checking the fluid level later this day
Old 03-04-2012, 08:38 PM   #10
Aggiesrok's Avatar
Could also be the filter is nasty. What about if you go past Drive to 1?
Old 03-04-2012, 09:53 PM   #11
RedGT's Avatar
From what I understand it's an idiot proof check. Fill it till it leaks. Wait till it stops. Done. Lol.
I would drain the fluid, it could be contaminated, or burnt, both of which could be bad signs. It also might just be low. A top up first, and if it's still slow, drain it and change the filter. Just make sure to inspect the old fluid and filter before tossing them for metal shavings, burning or chunks of stuff.
RedGT is offline   Reply With Quote
Old 03-04-2012, 10:08 PM   #12
irishn8's Avatar
Lol I know ur joking! But to clarify never over fill ur tranni.
To the o/p the reason u check for metal shavings is so u know if ur gears are grinding too much. A little bit of metal dust on the magnet on the pan is normal. Also racing the car a lot will burn and subsiquently break down the tranni fluid.
Old 03-04-2012, 10:08 PM   #13
Jayjay's Avatar
After work will check 1 and 2 gear... What fluid I'm suppose to check is it the transmission fluid . Sorry but I'm not sure
Old 03-04-2012, 11:22 PM   #14
irishn8's Avatar
Yup
---------- Post added at 10:22 PM ---------- Previous post was at 10:18 PM ----------
So, soon as u get home (coz ur engine has to be warm..well really the fuid has to be warm) cycle through all the gears then in park check the fluid level. If it looks dirty or smells burned then it DEFINATELY needs to be changed. If u got it new and never had it changed then u should change it (and the filter always).
Old 03-04-2012, 11:57 PM   #15
Jayjay's Avatar
I just got my 06 gt two months ago from the dealer. According to them they did everything, well tune up. Oil change too off fluids ect...
Ima check them out myself cause now i don't think they did. Thanks
Old 03-05-2012, 08:33 AM   #16
RedGT's Avatar
Actually I'm not joking. The tranny is designed to be idiot proof. You can't over fill it. Check it out.
Old 03-05-2012, 09:31 AM   #17
KATO's Avatar
Re: Gears
Jayjay, have someone you know, check that out/drive it around the corner, to see if they feel the same, just in case you might be a liitle too sensitive.
Old 03-05-2012, 04:06 PM   #18
Gil_T2's Avatar
Re: Gears
You guys need to read your owners books, The trans fluid must be checked COLD, if you have driven the car wait 30 min before checking fluid. All so there is NO dip stick, you check it like a manual.
BBK LT's, Catted Xpipe, Sniper tune, UDP's GT500 TB, Ford Racing CAI, CM delete, 4.10, TR6060, 1 piece DS
Gil_T2 is offline   Reply With Quote
Old 03-05-2012, 05:43 PM   #19
irishn8's Avatar
Well I just learned something new! I had no idea our tranni's were so different
What Grinds Your Gears? deadsp0t The Bar 21642 03-07-2018 10:18 AM
Rear end gears jwhayne0001 1979-1995 Mustang GT 18 03-24-2012 10:57 PM
I wanna go with gears Blackedout Pre-2005 V6 Mustang 16 03-09-2012 04:14 PM
Who has 410 gears? BaSohol 2005-2010 Mustang GT 120 03-08-2012 06:16 PM
MPG with 4.10 GEARS 06Ghost 2005-2010 Mustang GT 8 02-27-2012 02:02 PM
06:34 AM
