4.6 to 5.0 - Mustang Evolution
Old 03-05-2012, 11:45 AM   #1
MustangCaracas's Avatar
4.6 to 5.0
Hi there!
Im feeling curious about this topic!
How do i change change my engine from 4.6 to 5.0? What do i need? Costs?
MustangCaracas is offline   Reply With Quote
Old 03-05-2012, 12:19 PM   #2
Blackcat's Avatar
First new engine wiring harness alot of money alot lol a bunch of stuff it can be done but I would rather wait and get a used 5.0 and it would be cheaper
Blackcat is offline   Reply With Quote
Old 03-05-2012, 12:25 PM   #3
Titus Wadicus
svtlx's Avatar
Re: 4.6 to 5.0
i have a 96 3.8 i just swapped to 5.0 if u use a 4.6 car u will need to swap the k-member.
ive done several....are you gonna go efi or carbed?
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 03-05-2012, 12:40 PM   #4
Thats the issue! Here in Venezuela, the latest Stang is 08'
So i would like to do some work on it.
Just bought to him Steeda's CAI, Tri Ax, 4.10 gear, and some suspension and brakes stuff but i want more power. I dont know if camshafts, heads, UDP, etc
Want im sure is that ill get a KENNE BELL for Christmas hahaha
---------- Post added at 03:10 PM ---------- Previous post was at 03:09 PM ----------
Efi
Old 03-05-2012, 12:43 PM   #5
Titus Wadicus
svtlx's Avatar
Re: 4.6 to 5.0
sooo more imporatantly... wut year car are we talkn bout swapn since now we have modular 5 liters, i have to ask.
Old 03-05-2012, 12:49 PM   #6
2007 stock GT 3V
Old 03-05-2012, 12:53 PM   #7
Titus Wadicus
svtlx's Avatar
Re: 4.6 to 5.0
ok.... scratch wut i just said. it doesnt apply to ur application. anyway, as much as those motors cost... u r better off just stroking your 4.6 to a 5.0. instead of tryn to buy a coyote powerplant. i think it will be cheaper and you will find more resources and tech for the project...imo
Old 03-05-2012, 01:06 PM   #8
Thats exactly what i want! Stroking! But how is that work? What do i need to buy?
Old 03-05-2012, 01:20 PM   #9
Titus Wadicus
svtlx's Avatar
Re: 4.6 to 5.0
ill b honest...ima pushrod guy, so im a lil bit outa my element here. companies like scat come to mind.. and there are sum others. you are taken on an expensive project. i think the kits for a mod motor start around 2300.. just depends on wut kinda power u wanna make. personaly, i would throw a blower on it and call it a day. but dont quote me on that. someone here that is 4.6 smart should chime in any second now..lol.
Old 03-05-2012, 01:28 PM   #10
Blackcat's Avatar
If ur just stroking it to 5.0 then it will be alot cheaper and very worth it if u want big numbers the dealership that my friend owns forged mine and everything and I have a ford supercharger on mine and it was worth all u have to do is shop around and see how much it will cost to do it everyone is different in how the do things so u might can find a good deal
Old 03-05-2012, 01:56 PM   #11
Dion11197's Avatar
It would be far cheaper to strike the 4.6! Lol! I agree with the others.... You can check out some companies...... Blow by racing, coast high performance, there are others out there. I think modular power house might have some stuff for you as well. I think you'll be looking at 3k plus depending on the stroke, forged and what compression you want.
Dion11197 is offline   Reply With Quote
Old 03-05-2012, 02:06 PM   #12
Titus Wadicus
svtlx's Avatar
Re: 4.6 to 5.0
+1^
91 5.0 Mostly Stock JayKranz 1979-1995 Mustang GT 252 03-18-2012 08:27 PM
Injustice to a Mustang GT. Mustang_Madness 1996-2004 Mustang GT 52 03-09-2012 07:29 AM
Modified my Race Red '11 5.0 GT Brembo M3hunter 2011-2014 Mustang GT 32 03-06-2012 05:11 AM
Aode to a c-4 FordRacer_51 1979-1995 Mustang GT 7 03-04-2012 10:42 PM
Your favorite place to drive in your city Davey4.0 2005-2010 V6 Mustang 8 03-04-2012 07:10 PM
02:11 AM
