Weird idle - Mustang Evolution
Old 03-08-2012, 02:42 PM   #1
eouellette18's Avatar
Weird idle
When I'm at idle, the car bounces between 800 and then down to 500 rpms. It almost soinds like the car is going to stall and then catches itself? Could this be result of bad/ old gas because it sat in garage over winter and i had to remove the battery to recharge it. I would start it up every other week during the winter and let it idle for a bit and never noticed it. There was a period of about a month of me never starting it when the battery died. About a week after I put the battery back in is when I took the car out and I noticed it started to idle weird.
eouellette18 is offline   Reply With Quote
Old 03-08-2012, 03:23 PM   #2
BaSohol's Avatar
I'd drive it awhile and see if it goes away, sitting awhile with a dead battery can make it have to relearn the idle I believe
2007 Ford Mustang GT 5spd
Old 03-08-2012, 03:51 PM   #3
RVAStang05's Avatar
Your car needs to relearn the idle, since the battery was disconnected, Do a search in the forums. If you can't find it I'm pretty sure the process is to get in the car with it in park- do a cold start, and let the car sit and idle til it gets to regular temperature. Then cut the AC on and let it idle for another 15 min, then cut AC off and drive for about an hour.
That's close anyway- but search "relearning idle" I'm pretty sure that's your problem
Chris Rose at AM knows everything there is to know about this, so you could always PM him too.
Pype Bomb Axle-Backs, JLT CAI, SCT Tuner w/Bama tuning, BMR Strut Tower Brace, CDC Classic Chin Spoiler, Black Hood Pins, Black Shorty antenna, Tru-Billet Black Anodized GT engraved Fuel Door, Black Lemans Stripes, Black Rocker Stripes, Brushed Aluminum finish dash and vents, Stack Racing pedals, Charcoal Black Leather Interior, Gloss Black Bullitt Motorsport Wheels, Nitto 555 tires, staggered set up (9/10), 35% tint, Shaker 1000 Stereo with Kicker Upgrades, Ultra Violet footwell, license plate and dome lighting
RVAStang05 is offline   Reply With Quote
Old 03-08-2012, 07:45 PM   #4
Thanks for the help. I've noticed that when I'm completely stopped, like at a light it seems to be fine, but when I'm slowing down and I push the clutch in to put it in neutral it goes down to around 500 rpm and bounces in between 500 and 800 rpms until I come to a complete stop.
Old 04-23-2012, 07:18 PM   #5
Pola25's Avatar
This is happening to my 08 stang and its manual as well. Any luck with the relearning idle?
Pola25 is offline   Reply With Quote
Old 05-02-2012, 09:08 PM   #6
Re: Weird idle
This will happen when the battery is disconnected, or you load a new tune etc. Every time I have made a change this happens. Takes a few days and corrects itself. I've tried the AC bit, drive this many miles, blah blah blah, it will fix itself in a week or less depending on how much driving you do.
RAWR is offline   Reply With Quote
Old 05-09-2012, 10:38 PM   #7
janorton05's Avatar
Clean your throttle body. The reason the car has to relearn the idle is because over time the throttle body gets a build up on it. Your car is automatically adjusting for this add time goes on but when the battery is disconnected it loses the information needed to control the idle. You clean the throttle body with a 7 dollar can of tb cleaner and all will run smooth.
A group for Muscle Car enthusiasts.
https://www.facebook.com/3fCauto
Az group for Modern Muscle enthusiasts. Monthly meets, cruises and more!!
https://www.facebook.com/AzModRod?ref=hl
janorton05 is offline   Reply With Quote
Old 05-10-2012, 08:04 AM   #8
Silversky545's Avatar
Could b mass air flow if u cleaned ur filter recently ...
Silversky545 is offline   Reply With Quote
rough idle NickAP12589 2011-2014 V6 Mustang 20 04-07-2014 11:11 AM
Engine shaking at idle and driving stangin Pre-2005 V6 Mustang 18 03-22-2012 02:46 PM
High idle Taxman 1979-1995 Mustang GT 3 03-03-2012 05:46 PM
Idle help! Mustang_Madness 1996-2004 Mustang GT 6 03-02-2012 07:38 AM
Rough idle normal? ColeJohnson 1996-2004 Mustang GT 18 02-20-2012 03:12 PM
10:42 PM
