Cai issues - Mustang Evolution
Old 03-08-2012, 07:44 PM   #1
Brits06mustang's Avatar
Cai issues
I just bought a C&L cai with predator tuner. I installed their 87 pump gas street tune for I only have exhaust and the cai. I was test driving after installing and at the end of the drive the check engine light came on. My question is what could it possibly be for. I don't have a scanner to figure ot what he code is for. I was wondering if the car is safe to drive. It does not run rough or anything. Could the o2 sensor be reading faulty because of the tune or is there a problem with the old Maf sensor being in the new cai. Please help. Thanks.
Brits06mustang is offline   Reply With Quote
Old 03-08-2012, 08:04 PM   #2
BaSohol's Avatar
I'd get the code read at autozone and I assume it's something like the maf since you just messed with it
2007 Ford Mustang GT 5spd
Old 03-08-2012, 08:30 PM   #3
I had a dumb moment and remembered the tuner could run diagnostics and found that bank 1 and 2 were running lean. I cleared the codes and test drove again. No codes came up. Confusion is really setting in.
Old 03-08-2012, 09:03 PM   #4
Silversky545's Avatar
It can take 30 miles for code to come up again... Did u screw in the maf facing the right way?
Silversky545 is offline   Reply With Quote
Old 03-08-2012, 09:14 PM   #5
Yea flow is heading towards the throttle body. Also the holes for the screws only lined up one way. I will keep an eye out for the code. Also checked all connections and everything is good.
Old 03-08-2012, 10:04 PM   #6
Ur tuner should read codes
Old 03-09-2012, 05:07 AM   #7
GTRob504's Avatar
If you are running lean then it is likely that air is entering the engine at some point after the MAF. The most common error in installing a CAI is not seating the inlet to the bottom side of the throttle body. Since it is kind of a blind spot. Make sure it is snapped over at the bottom edge correctly.
2008 Metallic Alloy GT Convertible Premium
Show : black top| 18" bullitt polished wheels| CDC light bar and black billet replacement grilles | black/amber corner lights | GT500 rear spoiler| AH chin spoiler Go: FRPP CAI with StangHi tunes | Kooks LT's | FR500 axle back | Steeda Sport springs | Koni STR.t struts/shocks | J&M camber plates | UMI adj. panhard bar | LCA relocation brackets | GT500 LCA's | Hurst Billet shifter | 3.73 gear | FRPP axle girdle | Baer Rotors and Pads
GTRob504 is offline   Reply With Quote
Old 03-09-2012, 09:00 AM   #8
KATO's Avatar
Re: Cai issues
Why in the World are you running on a 87 Octane Tune? MOve it to 93 or 91, don't be cheap, your car will love you more in the long run. After all, it is a Mustang.
Old 03-09-2012, 10:18 AM   #9
Jlt cai
Off Rd x
93r tune
Bbk tb
26mpg
U will get better mpg w higher octane... Motor is more efficient
Old 03-09-2012, 02:30 PM   #10
frank07stanggt's Avatar
If you have the Diablo predator you can pull the codes yourself. Just go into the diagnostics section. When you find the code look it up online.
frank07stanggt is offline   Reply With Quote
Old 03-10-2012, 05:55 AM   #11
Labrat's Avatar
Re: Cai issues
Yes, I too would tune for at least 91 octane....Ford recommends that we run premium in our cars....at least that what the sticker says on my car when I got it and I ordered mine new!
Labrat is offline   Reply With Quote
cai
Any suggestions on CAI! 08MustanGT 2005-2010 Mustang GT 55 03-16-2012 06:33 PM
CAI BlackHorse1911 2011-2014 V6 Mustang 11 03-14-2012 05:48 AM
Electrical issues GrabberBlue5.0 2011-2014 Mustang GT 7 03-10-2012 08:41 AM
CAI BlackHorse1911 2011-2014 V6 Mustang 3 03-09-2012 08:15 PM
Cai 98mustang11 Pre-2005 V6 Mustang 7 03-05-2012 11:49 PM
11:53 PM
