CAI install issue - Mustang Evolution
Old 03-09-2012, 06:46 PM   #1
SayNo2Pugs's Avatar
CAI install issue
So I put in a K&N FIPK CAI and when I was tightening one of the valve cover screws it snapped. I think I might have a fix but will likely be a week or so.... How serious is it and or anyone else ever done this? Oh part of the screw is still in the block
SayNo2Pugs is offline   Reply With Quote
Old 03-09-2012, 07:12 PM   #2
BaSohol's Avatar
Why does it have anything to do with the valve cover? Sorry I'm not familiar with the k&n brand post a pic if you can
---------- Post added at 08:12 PM ---------- Previous post was at 08:11 PM ----------
Might cause an oil leak at the worst and it's probably nothing to panic about but fix it soon
2007 Ford Mustang GT 5spd
Old 03-09-2012, 07:28 PM   #3
SayNo2Pugs's Avatar
There is a brace that supports the tube and it uses the bolts in the valve cover I'll post a pic tomorrow when it's day light ... Thanks for the response
Old 03-09-2012, 07:49 PM   #4
BaSohol's Avatar
Ok, but it's more then likely an easy fix, just time consuming, I'll tell you what you should do when I see the problem
Old 03-10-2012, 05:51 AM   #5
Labrat's Avatar
Re: CAI install issue
Yes, if all you did was twist the head off it should be fairly easy fix. Just take your time and I would think you wouldn't have any problems unless you know Murphy..lol!!
Labrat is offline   Reply With Quote
Old 03-10-2012, 05:54 AM   #6
SayNo2Pugs's Avatar
I am going to try to use an easy out... Having somebody who knows what that is and what they are doing to help me out
Old 03-10-2012, 06:15 AM   #7
WillysYJ's Avatar
Good idea. It depends on where it broke. Did the head break off? Or did the shaft break down in the hole?
WillysYJ is offline   Reply With Quote
Old 03-10-2012, 06:30 AM   #8
Labrat's Avatar
If you can get to it and drill the hole in the bolt to use the easyout you shouldn't have any problems....like I said before, take your time and you shouldn't have any issues.
Old 03-10-2012, 01:01 PM   #9
SayNo2Pugs's Avatar
Yeah I torqued it to much while putting it back in so half of it is in the block and well the other half is useless I'll post after I do it. When it happened i think my heart stopped beating for a few seconds...
cai
Any suggestions on CAI! 08MustanGT 2005-2010 Mustang GT 55 03-16-2012 06:33 PM
CAI BlackHorse1911 2011-2014 V6 Mustang 11 03-14-2012 05:48 AM
Post brake pad install help silvr002001 1996-2004 Mustang GT 7 03-12-2012 06:26 PM
Cai issues Brits06mustang 2005-2010 Mustang GT 10 03-10-2012 05:55 AM
CAI BlackHorse1911 2011-2014 V6 Mustang 3 03-09-2012 08:15 PM
10:42 AM
