Road noise - Mustang Evolution
Old 03-13-2012, 09:05 PM   #1
Road noise
I have had my 08 GT for a few months. Road noise seems to be a bit loud. Has anyone experienced the same and remedied it?
Blue08GT is offline   Reply With Quote
Old 03-13-2012, 09:12 PM   #2
BaSohol's Avatar
Better tires would correct a lot and if it's wind noise make sure all the seals around the doors are good
2007 Ford Mustang GT 5spd
Old 03-13-2012, 09:13 PM   #3
The Blue Dragon
GrabberBlue5.0's Avatar
Have you checked wheel bearing? Hard tires can also give you a decent amount of road noise. Is it convertible?
New quick exhaust video
AUGUST 2012 MOTM!!!!
Old 03-14-2012, 03:16 AM   #4
tc x 4's Avatar
I believe its the tires. Even if its a vert the extra noise will b minimal. Ford done thier home work on the s197 verts. Could also b in the gears , but that would b more of a whine.
Old 03-14-2012, 10:31 AM   #5
I believe the tires are most the issue. Not so bad that I want to replace them yet.
Old 03-14-2012, 01:14 PM   #6
Silversky545's Avatar
Good question... I have bad road noise as well... Do you have aftermarket suspension? Or the silver horse flush mount quarter window louvres? All those can cause more road noise.... Btw taller the tire less the road noise... And tread patterns can cause less or more noise too
Silversky545 is offline   Reply With Quote
Old 03-14-2012, 02:09 PM   #7
BaSohol's Avatar
Ya I remember I use to worry about road noise in my old track car hell you even heard the fuel pump, so I got a car with a radio!!! Problem solved
Old 03-14-2012, 07:10 PM   #8
Stock suspension and no quarter window lovers. Plan on getting a rear seat delete soon. May add some sound deadoning.
Old 03-18-2012, 07:55 PM   #9
RedGT's Avatar
If you're getting road noise there's an easy solution. You need 1. A louder stereo or 2. A louder exhaust or 3. A pro charger. Anyone of those should do the trick.
RedGT is offline   Reply With Quote
Old 03-18-2012, 11:21 PM   #10
sinister07's Avatar
Re: Road noise
Although I like red Gt's reply, from experience I can tell you that a new set of tires will probably fix your noise problem.
2003 Mach 1
sinister07 is offline   Reply With Quote
Amp back feed noise through speakers SNK3BTE04 Mustang Audio & Video 16 03-28-2012 07:49 AM
Off Road H pipe BigB227 1996-2004 Mustang GT 31 03-13-2012 10:31 AM
Noise 91LXmustangink The Bar 6 03-11-2012 05:49 AM
Rear end noise? Low tone whine. Otlaw80 1979-1995 Mustang GT 6 03-08-2012 05:33 PM
Rattling noise under car vinnygt SVT Mustang 5 02-08-2012 10:19 AM
11:27 PM
