Whats all needed to lower my stang ? - Mustang Evolution
Old 03-13-2012, 09:51 PM   #1
F4m0usfr34k's Avatar
Alright guys looking at lowering my stang got any suggestions ? What's all needed to lower the car? Do I just have to purchase the springs ?
*f4m0usfr34k*
F4m0usfr34k is offline   Reply With Quote
Old 03-13-2012, 09:55 PM   #2
Silversky545's Avatar
If you are close or over 50k I'd suggest getting new shocks n struts if nit ride will b rough, depending on drop (over 1 1/2 ") your rear end will be out of alignment so you will need a adj Pan hard bar, then no matter what you will need camber bolts... But if money is no issue go with caster camber plates because the cam bolts will easily allow for bumps to make your alignment get out if wack...
I just dropped mine... And slowly got everything else later
Silversky545 is offline   Reply With Quote
Old 03-16-2012, 09:56 PM   #3
I dropped mine 1.5" with the ford k springs and my back end was fine. Anything more and you will want an adjustable panhard bar.
---------- Post added at 08:56 PM ---------- Previous post was at 08:52 PM ----------
I got the frpp fr3 kit from ford racing. It has shocks, struts, springs, swaybars, and a strut tower brace. I got a killer deal on mine but many others will recommend other setups.
Bbak91 is offline   Reply With Quote
Old 03-16-2012, 11:36 PM   #4
I would love to have that set up
Old 03-17-2012, 12:05 AM   #5
What's the average cost for that setup ?
*f4m0usfr34k*
Old 03-17-2012, 12:35 AM   #6
It goes for like $1400 to $1500. It doesn't just lower the car though. It also greatly improves handling. You can definitely lower it for less than that, but my stang rides like its on rails.
How to clean this? austinknoll Pre-2005 V6 Mustang 17 03-16-2012 12:39 AM
New muffler or all new exhaust? DaYanks4Ev Pre-2005 V6 Mustang 23 03-14-2012 07:56 PM
Update to my mods! Las0mbra Pre-2005 V6 Mustang 18 03-14-2012 02:40 PM
Starting to come together, got a little cruising in today. Otlaw80 1979-1995 Mustang GT 5 03-14-2012 09:20 AM
To lower or not to lower .... SNK3BTE04 SVT Mustang 2 03-13-2012 08:46 PM
10:46 AM
