GT500 rear spoiler install - Mustang Evolution
Old 03-16-2012, 07:03 AM   #1
Turtlestang39's Avatar
This is my first time writing one of these. This is a great website btw.
I just bought a GT500 rear spoiler for my 06 GT which previously had no spoiler at all. Since there has to be some drilling involved should I take it to a shop or is it easy enough to do it myself?
Turtlestang39 is offline   Reply With Quote
Old 03-16-2012, 07:46 AM   #2
KATO's Avatar
Re: GT500 rear spoiler install
I'd let a shop do it. I have No experience with doing body work, but I'd rather avoid any mistakes on my part, so I'd let a professional do that work.
Old 03-16-2012, 08:06 AM   #3
Thanks. Any idea on how much would it cost?
Old 03-16-2012, 08:18 AM   #4
KATO's Avatar
No, but it's not a expensive job, should only be a couple hundred. But if that includes prep and paint, then a couple Hundred more. But shouldn't be too much.
Old 03-16-2012, 10:08 AM   #5
A couple of hundreds just for the install? The spoiler is already paid and pre-painted.
Old 03-16-2012, 10:13 AM   #6
BaSohol's Avatar
Before you do anything see if any local mustangs wanna trade trunks!!!!!!! No spoiler trunk lids are very desirable
---------- Post added at 11:13 AM ---------- Previous post was at 11:13 AM ----------
Free and easy!!!!! You could probably even make money hhaha
2007 Ford Mustang GT 5spd
Old 03-16-2012, 12:09 PM   #7
I'll ask around or if you know of anybody on the Miami area let me know... Thanks for the help guys we'll see how it comes out...
Old 03-16-2012, 01:17 PM   #8
I also bought a pair of raxiom smoked tail ights...are those easy to install?
Old 03-16-2012, 09:46 PM   #9
Is it a plug and play system? If it is it should only take you like 30 to 40 mins.
Bbak91 is offline   Reply With Quote
Old 03-16-2012, 11:20 PM   #10
Las0mbra's Avatar
It should be as easy as swapping the lights out... Seriously, basically twist and remove all lights after the housing is removed from the car and put them in the new housings.
Old 03-17-2012, 07:00 PM   #11
WillysYJ's Avatar
Very easy. Open your trunk. Remove the retaining clips for the trim. Pull back carpet. Remove nuts (10mm I believe). Pull light housing slightly. Twist and pull lightbulb inserts. Swap lights and rewind... Again, VERY easy.
WillysYJ is offline   Reply With Quote
Old 04-11-2012, 12:14 PM   #12
Thanks! I finally got some time to install the smoked tail lights and the decklid panel.
Old 04-11-2012, 12:19 PM   #13
they make little things you can use to mark the holes with and then you simply drill/bolt on but those little plastic things might be hard to find. A shop can put it on for you probably but I would just make sure they dont screw anything up etc. You can check the underside to see if there are markings for the holes from the factory that were just never drilled as well.
Old 04-13-2012, 08:45 AM   #14
NightMare07's Avatar
I have a gt500 spoiler on my 07gt. It had a spoiler before but the gt500 only reused two of four existing holes. I had to drill two myself. The spoiler came prepainted and A shop quoted me two hours of shop time at $45 an hour here in Texas. So it just depends if it's worth it to you or if you feel comfortable doing it.
NightMare07 is offline   Reply With Quote
Old 04-13-2012, 09:16 AM   #15
WillysYJ's Avatar
Nightmare, what did you do with the other two holes that the new one didn't reuse? I'm thinking about doing the same. I know a guy who owns a body shop but just curious what you did.
Old 04-13-2012, 10:47 AM   #16
I got some plastic interior caps from like autozone or oreileys or somewhere for a buck or two. And from there you can choose to either 3M tape em or use like a silicone sealant to make sure there's no leaks. Then I just put the spoiler over them. They have a couple that are looked painted black which I used or there are flat black ones too. My car is black so it worked perfect but they will be under cover anyways.
Old 04-13-2012, 05:36 PM   #17
WillysYJ's Avatar
Sweet. I was thinking about going the same spoiler and didn't know the holes would cover. Now I know to add it to my list!
Old 04-13-2012, 06:22 PM   #18
If you look at pics of my car you can check out mine, they aren't amazing but I took em real quick after the install.
Old 04-13-2012, 07:27 PM   #19
WillysYJ's Avatar
Just looked at your rear end (no homo), where did you find a deck lid cover that covered the fear badge?
Old 04-13-2012, 07:32 PM   #20
It didn't cover it. I had to remove it. Then the deck lid covered the holes and cleaned up the keyhole. I got it on a local forum here in town from a guy on there.
Old 04-13-2012, 07:53 PM   #21
WillysYJ's Avatar
Yeah thats what I meant. I like that look. I'm still delaying on what I want to do to my rear. Already had a painter spray tinted clear coat on my lenses.
Rear speakers arnt working Dylanbest Mustang Audio & Video 3 01-17-2014 01:48 PM
2013 GT500- Price? iwannacobra5 Shelby Mustang 30 03-28-2012 09:52 PM
New noise from the rear 2002VertGT 1996-2004 Mustang GT 7 03-16-2012 08:17 PM
2010 GT Rear view mirror camera jrny99 2011-2014 Mustang GT 2 03-15-2012 12:24 AM
FRP sensor install help.... MiGT01 1996-2004 Mustang GT 3 03-14-2012 09:16 PM
02:19 PM
