Clutch - Mustang Evolution
Old 03-18-2012, 10:41 PM   #1
nathannp's Avatar
Clutch
Have a 08 s197 stock block no power adders. The problem I am experiencing is the clutch is allowing the car to roll even though the clutch is all the way in.
I launch the car over 5,000 rpm in doing so the clutch pedal will push against me and let the car roll like the clutch is not pushing all the way..
I run the ram power grip hd.
If you have a question about the car or the set up ask please...
nathannp is offline   Reply With Quote
Old 03-18-2012, 10:58 PM   #2
DaBluedude's Avatar
Clutch adjustment required.
2003 Mach 1
Old 03-18-2012, 11:09 PM   #3
Gil_T2's Avatar
Re: Clutch
Did you just put it in ? did you install the shim under the TB?.
BTW Dabluedude there isn't a clutch adj on the 05 up models.
BBK LT's, Catted Xpipe, Sniper tune, UDP's GT500 TB, Ford Racing CAI, CM delete, 4.10, TR6060, 1 piece DS
Gil_T2 is offline   Reply With Quote
Old 03-19-2012, 05:23 AM   #4
DaBluedude's Avatar
Not even aftermarket??
2003 Mach 1
Old 03-19-2012, 06:39 AM   #5
nathannp's Avatar
The car does have the shim that ram provided that goes under the slave. Not a new clutch I have had it since October I just got done building the Trans again but it did it to me last weekend I built the Trans over the week go out the next weekend have the same issue
Old 03-19-2012, 09:28 AM   #6
Gil_T2's Avatar
Re: Clutch
You measure for preload, and if needed place a shim under the TB
---------- Post added at 11:28 AM ---------- Previous post was at 11:21 AM ----------
Get a vacuum pump and vacuum the master cyc to make sure all the air is out of the sys. Only other thing i can think of is a piece of clutch material could have broken off and folded over and doubled up.
Old 03-19-2012, 11:15 AM   #7
nathannp's Avatar
Man I own a shop and I can't figure out what you referring to when you say TB. I am going to take the line out and not let it drain ( it is also not the factory line) then reinstall the line and use the vacuum the system down to bleed it I will let you know what the results are. We think it has air in it but I am not sure
Old 03-19-2012, 12:25 PM   #8
Gil_T2's Avatar
Re: Clutch
Throwout bearing/ slave cyc
Old 03-19-2012, 12:32 PM   #9
nathannp's Avatar
Duh lol brain fart it has a brand new oem it's a week old I don't know what the preload is though
Old 03-19-2012, 12:38 PM   #10
Gil_T2's Avatar
Re: Clutch
Ram has a pdf, work sheet to figure preload on their web site. All so vacuum bleeding works the best, pull 15" of vac let stand for 5 minuets.
Old 03-19-2012, 02:48 PM   #11
nathannp's Avatar
Ok cool it cost me the race yesterday.. Thanks for the info. I hate talking on the forms 90% of people are smart asses on here I will post what we find
Old 03-19-2012, 05:09 PM   #12
tc x 4's Avatar
Not true, most ppl on here are very helpful. Try paying for the knowledge you can learn on here.
Old 03-19-2012, 07:42 PM   #13
nathannp's Avatar
Wasn't trying to offend anybody just saying I work on cars for a living and a lot of the people that get on here don't know what's going on.. Can you find good info yes absolutely.. But kids do get on here and contaminate the site sometimes
Old 03-19-2012, 08:19 PM   #14
DaBluedude's Avatar
Seriously man? ur gonna hop on my nuts for offering a solution for the wrong generation of car? that's cute... I'm pretty disappointed in your criticism... Non constructive and unnecessary good luck with your clutch repair.
2003 Mach 1
Old 03-20-2012, 09:36 PM   #15
nathannp's Avatar
Bleed the clutch? Nothing got better does the exact same thing I don't get it I am going to call ram in the am and see what they say I will post what they say
Old 03-21-2012, 10:46 AM   #16
RedGT's Avatar
I think I remember reading something about an adjustment for the ram TB, so I would think that would be the issue. I don't know how to do the adjustment though, but I'm pretty sure there is one.
RedGT is offline   Reply With Quote
Old 03-21-2012, 11:00 AM   #17
Gil_T2's Avatar
Re: Clutch
There are no adjustments other that shimming the T.Bearing or buying an aftermarket adjustable T.Bearing
Old 03-21-2012, 02:22 PM   #18
RedGT's Avatar
That's what I mean. I think the ram TB is adjustable. I know the OEM one isn't.
Old 03-21-2012, 08:53 PM   #19
nathannp's Avatar
The factory one obviously isn't adjustable.. The factory is shimmed to .044? And ram said they want there's clutch shimmed at .055? So they gave me a part # and it's 399.00. I haven't always had this problem this is why I am so confused. It doesn't make since to me that this problem just occurred I should have just bought the McLeod rxt.. There is so many problems with that ram it is bull ****
Old 03-27-2012, 11:03 AM   #20
Gil_T2's Avatar
Re: Clutch
Did you get the clutch fixed???
Old 03-27-2012, 11:26 AM   #21
nathannp's Avatar
Yeah actually I did I bought a new lol. Nothin wrong with the ram. They just said I need there adjustable slave/tb bearing and its 399.00 and I said screw that and bought a McLeod rxt 26 spline twin disk. It will be here tomorrow
Old 03-27-2012, 01:00 PM   #22
Dion11197's Avatar
I hate it when things like that happen! You'll have to update us on the McLeod, I'm in the market for an aftermarket clutch, so I think the ram might be out for me!
Dion11197 is offline   Reply With Quote
Old 03-27-2012, 01:28 PM   #23
nathannp's Avatar
Do not buy ram.. I have a friend with the McLeod and he has a Shelby making 620hp to the wheels and that what he bought he loves it pedal feels like stock and his will hold 1200hp. I on the other hand just bought mine I spent over a grand and I think I will be happy. I will give y'all a update. And I bought mine from lethal performance
Old 03-27-2012, 03:40 PM   #24
Dion11197's Avatar
Nice, good info and thanks!
Your Favorite Clutch and Why K Twisted 1996-2004 Mustang GT 22 04-10-2012 07:02 PM
any recommendations fro a new clutch? memo232 Roush Mustang 11 04-04-2012 04:47 PM
just installed new clutch ram hdx drove about 5 miles and clutch got really hard? Cobra209 SVT Mustang 11 04-01-2012 04:44 PM
Fixing the spring behind the clutch pedal. 1995boss 1979-1995 Mustang GT 13 03-30-2012 02:51 PM
Need some help on wat clutch to get Cri5 1996-2004 Mustang GT 2 03-17-2012 06:32 AM
10:55 AM
