Cams - Mustang Evolution
Old 03-19-2012, 09:09 AM   #1
GunMetalBullet's Avatar
Cams
Is it possible to run supercharger cams, or supercharged grinded cams on a naturally aspirated motor? The motor will have a sc on it just yet. Is this possible??
GunMetalBullet is offline   Reply With Quote
Old 03-19-2012, 09:18 AM   #2
S197Miller's Avatar
From what I've read. Yes it is possible
S197Miller is offline   Reply With Quote
Old 03-19-2012, 09:24 AM   #3
Does it run ****ty? Or just a different
Grind?
Old 03-19-2012, 09:28 AM   #4
S197Miller's Avatar
I've heard of a company who sells a blower cam and it makes more power than their NA cam. On a non-boosted application
Old 03-19-2012, 09:36 AM   #5
I was looking at detroit rocker superchared cam. What company are you referring to?
Old 03-19-2012, 09:43 AM   #6
S197Miller's Avatar
Ya I can't remember man. It was a long time ago
Old 03-19-2012, 09:50 AM   #7
Thank you!
Old 03-19-2012, 10:07 AM   #8
stampde's Avatar
Re: Cams
IT WILL RUN FINE WITH A SC Cam, just not as good as it would with an NA Cam
SC Cams ,have different intake centerlines and lobe profile's than na CAMS , I THINK THE VALVE'S STAY CLOSED A HAIR LONGER to build cylinder pressure for more HP And Torque on SC Cams .......... so if you plan on installing a SC down the road that's fine .... you'll be ok
2011 GT Auto
Old 03-19-2012, 10:15 AM   #9
Hey thanks for the info. Not to knowledgeable on cam, timing, etc... Its an MMR 4.75 stroker that will have a kenne belle
Supercharger on it but i am purchasing the motor first and want to install the cams while i have the motor out.
Old 03-19-2012, 11:33 AM   #10
Stang.racr's Avatar
That's a good stroker motor from everything I've read
having a fine car that is slow is like having a hot girlfriend that won't put out!
Stang.racr is offline   Reply With Quote
Old 03-19-2012, 11:44 AM   #11
Yes i believe it is too! I cant wait to get it!
Trickflow Heads & Cams FORDGT14 1996-2004 Mustang GT 29 04-18-2012 11:37 AM
Cams ?? Horseplay Pre-2005 V6 Mustang 8 03-19-2012 12:57 AM
Cams AmericanMetal 1996-2004 Mustang GT 58 03-14-2012 07:43 PM
Need cams 1lowGT 1996-2004 Mustang GT 4 03-12-2012 06:09 PM
Thumper cams? Cm644rodrigues 1979-1995 Mustang GT 2 03-11-2012 04:25 PM
10:19 AM
