Break fluid level low - Mustang Evolution
Old 03-19-2012, 06:58 PM   #1
Mr.Saleen005's Avatar
Hey guys first off great place for us mustang lovers keep up the good work. I have a small issue with my 2007 Saleen. My break fluid light comes on saying its low but it's at the right level. Sometimes it stays on for few minutes and sometimes for a day or two. Any advice? Does any one had a same thing happened to them?
Mr.Saleen005 is offline   Reply With Quote
Old 03-19-2012, 07:37 PM   #2
RedGT's Avatar
If its intermittent then it's probably a bad wire. Try jiggling the wire at different areas and seeing if the light comes on. That's the easiest way to find out. Could be the sensor itself too. That's where I would look first. Beyond that, maybe your fluid level is low and you didn't look at it properly.
RedGT is offline   Reply With Quote
Old 03-19-2012, 09:32 PM   #3
Thanks for the advice RedGt. I'll start with the wires first tomorrow and If that doesn't work I guess ill be going to my mechanic. The fluid level is good , I've checked it more then ones and I was on a level ground as well. I'll keep you posted what happens.
Old 03-20-2012, 04:55 AM   #4
tc x 4's Avatar
I wouldn't take it to a mech unless he's a buddy of yours. As redgt said, check wires, then replace the sensors. Most , not all tho, mechanics are nothing more than parts changers, they change everything til they fix the prob at ur expense.
Old 03-20-2012, 06:21 AM   #5
BaSohol's Avatar
Does it come on over bumps and turns only? My old ford brake light would come on when I turn or hit a bump, turns out the fluid level was low even tho it was still at or above the mark, put alittle in and never happened again
2007 Ford Mustang GT 5spd
Old 03-20-2012, 07:53 AM   #6
RedGT's Avatar
Keep in mind if it's a broken wire you might have to search a little. Also, most sensors work within a limit. So you could have a corroded wire as well. Don't throw a sensor at it just cuz you can't find a bad spot in the wires.
Old 03-20-2012, 08:33 PM   #7
SSC182's Avatar
Just unplug the sensor and if the light comes on and stays on the sensors good your problem is elsewhere. Or just take a voltmeter and check your voltage at the sensor. Also the red brake light is also for the parking brake so make sure those wires arnt loose or corroded either
SSC182 is offline   Reply With Quote
Old 04-02-2012, 08:18 AM   #8
Thanks to all you guys for great advice. It was a lose wire n so far it's all good.
Old 04-02-2012, 09:49 AM   #9
Re: Break fluid level low
you sure your fluid is not a bit low? If so you may have a little leak (probably where the line meets the caliper~)
2011+ 5.0 Mustang Low Oil Thread 04TRV6 2011-2014 Mustang GT 113 05-05-2014 07:25 PM
spring break svo The Bar 0 03-19-2012 09:21 AM
Low break fluid warning light Mr.Saleen005 Saleen & SMS Mustang 0 03-17-2012 05:44 PM
302 break in fordracing63857 1979-1995 Mustang GT 3 03-17-2012 08:47 AM
Are low riders making a comeback? Project Pony The Bar 9 03-15-2012 09:37 PM
02:24 PM
