fuel problem - Mustang Evolution
Old 03-20-2012, 06:48 PM   #1
kcaito23's Avatar
fuel problem
Having problems with my 06 gt I when I fill up my gas fudge is saying I'm full but when it gets down to half a tank it goes to empty and then after about 20 miles I run out I'm only getting around 140 miles per tank and its only taking about 10 gallons from bone dry but it says its full. Anyone help would be appreciated so I can cut down on the troubleshooting cost.
kcaito23 is offline   Reply With Quote
Old 03-20-2012, 07:37 PM   #2
RedGT's Avatar
It seems to me that you have two separate issues here. A bad sensor and a tank that won't fill properly. I would check the fuel level sensor first, make sure it's working properly, and then I would try to figure out why you can fill more than 10 gal.
RedGT is offline   Reply With Quote
Old 03-20-2012, 08:39 PM   #3
kcaito23's Avatar
Re: fuel problem
Thanks ill give that a try
Old 03-20-2012, 10:20 PM   #4
Charles.young10's Avatar
Gauge itself could be messing up, there are known gauge issues with our cars. When you say you "run out" car will shut off? Act like it runs out of gas? Or the gauge just says your out of gas?
As far as the full up goes, turn the gas nozzle upside down and see if it will fill up all the way.
Charles.young10 is offline   Reply With Quote
Old 03-21-2012, 12:14 AM   #5
tc x 4's Avatar
There is a tbs on the subject
---------- Post added at 02:14 AM ---------- Previous post was at 02:13 AM ----------
I think is called tbs, I've Ben a dranken.
Old 03-21-2012, 12:15 AM   #6
TSB.. But close enough.. Lol
I posted a DIY for the gauge cluster fix a while back.. Should be easy to find
Old 03-21-2012, 12:24 AM   #7
tc x 4's Avatar
Brain fart
Old 03-21-2012, 05:45 PM   #8
Davey4.0's Avatar
Region: Nevada
Try to reset the computer to.could be something in the brain box.
Davey4.0 is offline   Reply With Quote
Old 03-22-2012, 10:40 PM   #9
kcaito23's Avatar
Thanks for the answers, to answer the question on itturning off, the car bogs out like then wont start when its empty I'm going to try the fuel pump and. Fuel modual hoefylly that fixes it
Rev from idle problem CoyoteXII 2011-2014 Mustang GT 11 03-27-2012 07:50 PM
Fuel cell 19foxbodylx93 2.3 Mustang 0 03-20-2012 10:33 AM
Starting problem- I'm baffled jhagan1980 1979-1995 Mustang GT 21 03-18-2012 09:03 PM
Fuel economy GrabberBlue5.0 2011-2014 Mustang GT 37 03-18-2012 07:21 PM
CD player problem StackeStang 1996-2004 Mustang GT 7 03-17-2012 08:48 PM
10:37 AM
