Engine noise - Mustang Evolution
Old 03-21-2012, 05:18 PM   #1
Redman4034's Avatar
Engine noise
I'm having a little engine noise on top. It has 40k so I really shouldn't be having any. Should I switch to a heavier weight oil? I'm using 5 20. It's not really a knocking. Idk if it could have blockage or bad oil pump. Has anyone else had this problem?
Redman4034 is offline   Reply With Quote
Old 03-21-2012, 05:36 PM   #2
Davey4.0's Avatar
Region: Nevada
Is it a thumping or squeaking?could be one of your belts.
Davey4.0 is offline   Reply With Quote
Old 03-21-2012, 06:03 PM   #3
Redman4034's Avatar
It's a thumping towards the back side on passenger side
Old 03-21-2012, 07:18 PM   #4
Aggiesrok's Avatar
Don't change your oil weight. It can screw up your variable cam timing VCT and possibly cause some more serious issues.
Old 03-22-2012, 06:48 AM   #5
RedGT's Avatar
5w20 works just fine in these cars. Just make sure you've got a good oil level. As for the thumping, when does it happen? At idle, hard acceleration? Also what octane of fuel are you using? You could try a higher grade.
RedGT is offline   Reply With Quote
Old 03-22-2012, 10:32 AM   #6
Redman4034's Avatar
Oil level is good just changed it bout 500 miles ago and double checked it. It's at an idle. And I run premium gas and only BP gas. But with all this bad gas we have now I might need to clean it out with something. What's everybody think about sea foam or a good fuel injector cleaner?
Old 03-22-2012, 10:54 AM   #7
BaSohol's Avatar
Gas already contains detergents, and you only have 40,000 miles right, so I wouldn't use any additive
2007 Ford Mustang GT 5spd
Old 03-22-2012, 11:20 AM   #8
Redman4034's Avatar
I think I'm just gonna drain and add a half quart of Lucas oil.
Old 03-22-2012, 11:31 AM   #9
BaSohol's Avatar
These motors are just loud, I wouldn't worry about it
Old 03-22-2012, 11:38 AM   #10
Charles.young10's Avatar
Had the same issue when I bought mine.. Sounds like a small tick on the passengers side back of motor..
NOTHING is wrong.. Don't worry about it.. It's actually the cam phasers.. 3v are known for this.. It's will eventually go out.. Needing to be replaced.. But it's probably a LONG ways from that..
When they needs to be replaced you will know it.. It will be a very loud tick.. And it will get louder when you rev past 1200 rpm.. Until then.. It's fine..
Wanna fix for it now.. buy louder exhaust!! Lol
Charles.young10 is offline   Reply With Quote
Old 03-22-2012, 12:06 PM   #11
Redman4034's Avatar
Lol yeah i put a system in yesterday and getting an o/r x pipe. I put the Flowmaster on but not any real change. But it's not really a loud noise just didn't thank it should be making it. But thanks for yalls input. I just bought the car couple weeks ago and was getting nervous bout that noise.
Old 03-22-2012, 12:23 PM   #12
Flowmasters are kinda garbage for our cars.. For some reason they don't sound very good IMO..
But yeah man.. Don't worry about.. Congrats on the new car!
Old 03-22-2012, 12:27 PM   #13
RedGT's Avatar
I've got flowmasters on mine, and it's okay. I would prefer Roush though.
Old 03-22-2012, 12:52 PM   #14
Redman4034's Avatar
Thanks and yeah I'm used to Flowmaster having the best sound for me. Thats what I've put on all my vehicles, but I'm def not getting the sound I want on this car. So gonna have to change it up. I really want to keeps my cats on but at this rate it looks like they gotta go.
Old 03-22-2012, 02:07 PM   #15
BaSohol's Avatar
I have flows with an off road xpipe sounds like shlt
Old 03-22-2012, 03:29 PM   #16
Check out JBA, or just search YouTube for desired sound.. American muscle has tons of videos to listen to
Old 03-22-2012, 04:51 PM   #17
Redman4034's Avatar
Follow the "best exhaust" thread
check engine light 2002Gt 1996-2004 Mustang GT 48 03-31-2012 07:11 PM
Cleaning engine? DaYanks4Ev Pre-2005 V6 Mustang 33 03-27-2012 12:05 AM
Check Engine Light DeceptiStang Saleen & SMS Mustang 2 03-20-2012 01:28 PM
Engine Miss Taxman 1979-1995 Mustang GT 16 03-19-2012 02:33 PM
Engine swap Ajsjstang 1979-1995 Mustang GT 12 03-19-2012 10:00 AM
09:16 AM
