Whos running Nitrous - Mustang Evolution
Old 03-22-2012, 08:58 AM   #1
BaSohol's Avatar
I looking at the Edlebrock Dry kit, anybody running that one? I want a dry kit for a few reasons, 1 its easy to hide and 2 i dont have to worry about it puddling in the intake. also how would you hook it up with the micro switch? my car it stick so i dont have an extra hand to be holding onto a button. also I would only run a 100 shot for now
2007 Ford Mustang GT 5spd
Old 03-22-2012, 12:31 PM   #2
RedGT's Avatar
Look up Speeddawg shift knobs. You can get one with a built in button. They are pretty sweet.
RedGT is offline   Reply With Quote
Old 03-22-2012, 02:09 PM   #3
BaSohol's Avatar
I can make that myself but I don't I'd want one on the shifter, what if it's armed and I bump the switch while driving
Old 03-22-2012, 02:18 PM   #4
Watchawow07SGT's Avatar
Try one of those steering wheels wit the built in buttons. Kinda ricey but wutever floats ur boat.
Watchawow07SGT is offline   Reply With Quote
Old 03-22-2012, 02:30 PM   #5
BaSohol's Avatar
Ya I can mount one on the factory wheel
Old 03-22-2012, 04:50 PM   #6
BaSohol's Avatar
Thanks for the input, I was hoping someone had a setup but I think this is the wrong forum, if I had a question about LEDs, halo lights or plasti dip I'd have a million answers here haha
Old 03-22-2012, 10:14 PM   #7
tc x 4's Avatar
No dout,I was hoping someone would chime in.
---------- Post added at 12:14 AM ---------- Previous post was at 12:12 AM ----------
Did u get thos drs mounted an tested.
Old 03-22-2012, 10:46 PM   #8
BaSohol's Avatar
Ya won a few races with them bad boys, here's a pic of my car with 17 Micky Thompson, look at that hook haha
ID:	44682   Click image for larger version
Old 03-22-2012, 10:48 PM   #9
BaSohol's Avatar
Here's the new setup
Old 03-22-2012, 10:55 PM   #10
It's not me, it's you.
primer2tone's Avatar
Lmao. Sad but true and still pretty funny.
Old 03-23-2012, 03:43 AM   #11
tc x 4's Avatar
Now that's getting a bite. Your gonna need whille bars soon.LOL
---------- Post added at 05:43 AM ---------- Previous post was at 05:38 AM ----------
I had some used dunlops bought, the ******* sold them out from under me. What he didn't realization tho ,was I was also interested in a bunch of fox body parts he had. F*** him.
Old 03-23-2012, 09:14 AM   #12
frank07stanggt's Avatar
I have the zex wet kit. It uses wot trigger with a window switch to control what rpm and what gear to start the spray. Does the edlebrock kit have any accessories like that? That would solve your button problem.
---------- Post added at 11:14 AM ---------- Previous post was at 11:13 AM ----------
Also filling the bottle for the first time tomorrow so wish me luck.
frank07stanggt is offline   Reply With Quote
Old 03-23-2012, 09:28 AM   #13
BaSohol's Avatar
What intake do you have????? I have a JLT 3 idk if the intake is think enough to tap for the nozzle
Old 03-23-2012, 09:46 AM   #14
Dion11197's Avatar
I doubt the JLT 3 is thick enough to tap. Personally I'd feel better with a retaining nut on the inside to keep the jet in place. Plus with it mounted on the bottom side of the intake for discreetness the retaining but will ensure it doesn't vibrate loose. Just my opinion. Lol
Dion11197 is offline   Reply With Quote
Old 03-23-2012, 09:52 AM   #15
BaSohol's Avatar
Ya that's what I was thinking, edlebrock kit has a throttle body adapter plate, which I could retro for to the zex kit
Old 03-23-2012, 11:08 AM   #16
I tapped my jlt series 3 just fine. Right in front of the tb.
---------- Post added at 01:08 PM ---------- Previous post was at 01:06 PM ----------
Btw the zex kit came with a piece that you can screw inside the hole you drilled. Then you screw the jet in to that.
Old 03-23-2012, 11:34 AM   #17
BaSohol's Avatar
Sweet, I'll have to order that kit some time this week, did you get your car straightened out yet?
---------- Post added at 12:34 PM ---------- Previous post was at 12:26 PM ----------
Also post some pics if ya can of where and how the whole kits mounted
Old 03-23-2012, 11:42 AM   #18
I "hid" mine. Mounted everything under the filter inside the air box. Then put wire loom over all the lines and wires. Sleeeeepeeeer. Lol. I'll take pictures when I get home.
Old 03-23-2012, 11:47 AM   #19
RedGT's Avatar
A window switch or an activation switch will be my safety. You can mount an aircraft switch next to the shifter or even a small button toggle between the two reading lights. That way you don't accidentally arm the system, and neither does someone else.
Old 03-23-2012, 01:50 PM   #20
Dion11197's Avatar
Nice! Good info!
---------- Post added at 12:50 PM ---------- Previous post was at 12:49 PM ----------
I like it!
Old 03-23-2012, 05:24 PM   #21
Here's my setup. Hid it as much as possible. Hope this helps.
ID:	44735   Click image for larger version
ID:	44737   Click image for larger version
ID:	44739   Click image for larger version
ID:	44741   Click image for larger version
Old 03-23-2012, 06:21 PM   #22
BaSohol's Avatar
Thanks man that helps a lot
Old 03-23-2012, 06:31 PM   #23
That is a clean setup man! I would paint all the solenoids black too. What shot are you spraying? Do you have any pics of where you mounted the bottle?
Old 03-23-2012, 07:38 PM   #24
BaSohol's Avatar
Alot of guys mount it right behind the rear seats
Old 03-23-2012, 08:00 PM   #25
Well my bottle is out now cause I'm taking it to get filled tomorrow. But it's behind the drivers seat. There is already a big grommet to put the blowdown tune and nitrous lines out. After I get the bottle back I'll put it in and take a picture.
Old 03-23-2012, 08:03 PM   #26
This isn't mine but this is where I have mine.
nitrous
car wont stay running 87blackonblack 1979-1995 Mustang GT 6 03-21-2012 09:51 PM
94 gt running very hot Cstyle1 1979-1995 Mustang GT 10 03-17-2012 02:09 AM
96 running bad need a solution Hdavis013 Pre-2005 V6 Mustang 0 03-14-2012 07:52 PM
Why not nitrous? Mathew r Wright 1996-2004 Mustang GT 14 03-10-2012 08:24 AM
Still running lean. l2plagears Pre-2005 V6 Mustang 6 03-09-2012 02:37 PM
04:33 PM
