Suspension question - Mustang Evolution
Old 03-22-2012, 12:50 PM   #1
RVAStang05's Avatar
Suspension question
What's the difference between HD strut mounts and caster camber plates? I was told I should probably get HD strut mounts when I do my suspension (upgrading shocks and struts, lowering springs and panhard bar) but would caster camber plates work as well or better?
Pype Bomb Axle-Backs, JLT CAI, SCT Tuner w/Bama tuning, BMR Strut Tower Brace, CDC Classic Chin Spoiler, Black Hood Pins, Black Shorty antenna, Tru-Billet Black Anodized GT engraved Fuel Door, Black Lemans Stripes, Black Rocker Stripes, Brushed Aluminum finish dash and vents, Stack Racing pedals, Charcoal Black Leather Interior, Gloss Black Bullitt Motorsport Wheels, Nitto 555 tires, staggered set up (9/10), 35% tint, Shaker 1000 Stereo with Kicker Upgrades, Ultra Violet footwell, license plate and dome lighting
RVAStang05 is offline   Reply With Quote
Old 03-24-2012, 09:04 AM   #2
GTRob504's Avatar
Strut mounts are what come from the factory. The have an internal bearing and rubber isolator to dampen the feel of the road to the body of the car.
Camber plates are essentially the same but can be adjusted for camber once you lower the car.
2008 Metallic Alloy GT Convertible Premium
Show : black top| 18" bullitt polished wheels| CDC light bar and black billet replacement grilles | black/amber corner lights | GT500 rear spoiler| AH chin spoiler Go: FRPP CAI with StangHi tunes | Kooks LT's | FR500 axle back | Steeda Sport springs | Koni STR.t struts/shocks | J&M camber plates | UMI adj. panhard bar | LCA relocation brackets | GT500 LCA's | Hurst Billet shifter | 3.73 gear | FRPP axle girdle | Baer Rotors and Pads
GTRob504 is offline   Reply With Quote
Old 03-27-2012, 01:00 PM   #3
RVAStang05's Avatar
Thanks
Old 03-27-2012, 02:50 PM   #4
Re: Suspension question
Caster/Camber Plates (or C/C Plates) just allow the strut shaft to be shifted foward/back or side to side for caster/camber adjustment instead of just bolting down and having no adjustment as stock units tend to do.
If you lower the car the tip of the tire pulls in ward (same thing happens when you go over a bump as the shock/spring compresses)
The plate can be pulled outward to offset the difference in a lower spring has so normal driving you are back in a good area for tire wear or handling.
Question about tuner Venomouz831 AmericanMuscle 3 03-28-2012 03:52 PM
Suspension StangRebel 2005-2010 V6 Mustang 11 03-23-2012 01:28 PM
sct tunner question tc x 4 2005-2010 Mustang GT 4 03-22-2012 03:47 PM
Heads question jhagan1980 1979-1995 Mustang GT 15 03-21-2012 10:58 PM
this is probably a dumb question medicespo 2011-2014 Mustang GT 7 03-20-2012 02:01 AM
04:14 PM
