lowered 06 GT makes hissing or rubbing sound when getting on the accelerator - Mustang Evolution
Old 03-22-2012, 10:59 PM   #1
Ballard281's Avatar
Hey I recently lowered my mustang and ever since then it's had a hissing sound when I get on the gas going down the road at about 3500rpms but stops making the noise at a steady crusing speed 1500rpms can any tell me what it could be?
Ballard281 is offline   Reply With Quote
Old 03-23-2012, 09:15 AM   #2
RedGT's Avatar
Check your tires for unusual wear. Same as the plastic wheel well covers.
RedGT is offline   Reply With Quote
Old 03-23-2012, 09:18 AM   #3
Whitestang93's Avatar
^thats what I would say too cause I had mine lowered and every time I turned it would rub the wheel well bad and made squeaking noises so I just put it back up and problem solved for me.
Whitestang93 is offline   Reply With Quote
Old 03-23-2012, 09:28 AM   #4
RedGT's Avatar
Probably what is going on is the car is squatting in the back on harder throttle and its chewing up your tires, or something else. I would find out what it is fast because worst case scenario could be a tire blowout. Which isn't pretty if you have a beater car, let alone a Stang.
Old 03-23-2012, 10:35 AM   #5
Ballard281's Avatar
The tires arent rubbing anything the sound is coming from around my back speakers if that makes any since but it kinda sounds like my exhaust is loose and rubbing something
Old 03-23-2012, 11:43 AM   #6
RedGT's Avatar
The best thing to do is put the car up on blocks and have a good look under. Also this may sound weird, but if there's a bad engine ground, you could potentially be getting feedback through the speakers. I've seen it before, so if you've done anything else at the same time you might want to check that out too.
Old 03-23-2012, 05:21 PM   #7
When I bought my car it had aftermarket dual exhaust on it and it wasn't done well cause when I drove hard or hit bumps the pipes were swinging and hitting the driveshaft making weird squeaks and noises. We had to get it re bent out of the way. That might be what's going on
Xmission issue or clutch adjustment needed Nicks86GT 1979-1995 Mustang GT 10 04-06-2012 10:40 AM
Procharger or vortec sc for 11'5.0 MT 3.73? JG5.0 2011-2014 Mustang GT 20 03-27-2012 06:24 PM
dr's or slicks mystang50 1979-1995 Mustang GT 24 03-26-2012 01:21 PM
To be staggered or not staggered!? Gobabygo67 1996-2004 Mustang GT 50 03-25-2012 01:10 PM
Anyone ever had a weird whistling sound GE3G 2011-2014 Mustang GT 7 03-23-2012 11:57 AM
05:21 AM
