results - lowered and updated gears - Mustang Evolution
Old 03-23-2012, 04:33 AM   #1
I just got my 07 back...2 days to have 4.10 gears and complete Eibach pro system plus suspension kit installed..
It look awesome! While I forgot to.measure the 'before' it looks like it went down about 2".
Ride is fine.
So onto the new gears. Perhaps my expectations were incorrectly set on this change. I was expecting a major change in launches bit dont really see it. By moving from stock 3.27s to 4.10s I only see a slight difference, of course my speedo was off which got adjusted later by my sct tuner.
Maybe time will prove different, but I question the $500 I dropped on gears.
So 2 thumbs up on the lowering kit...
But the gears...I wouldn't bother next time.
redfire is offline   Reply With Quote
Old 03-23-2012, 05:37 AM   #2
Ok I need to modify my view on the gears...
I drove into work today and I was blown away at the difference.
Perhaps my initial experience was because I hadnt modified my tune to reflect the gear change...I have an auto and so I realize the shift points needed adjustments in addition to the speedo calibration.
Also my work commute is more city than my drive home yesterday from.my mechanic.
I would recommend the gear change now...they are awesome.
Old 03-23-2012, 06:58 AM   #3
2Greeny7's Avatar
Send a message via Skype™ to 2Greeny7
Hahaha I bet! I can't wait to get my gears, I need to find a mechanic to cheaply put mine in!
2001 V6
CAI, SF3/X3 Tuner, 4.10 Gears, Auburn lim-slip
GT4 Rims (Summer), Stock Rims (Winter)
2 Subs, New speakers all around
1 Great Car 1 Happy Kid
July '12 Mustang of the Month
2Greeny7 is offline   Reply With Quote
Old 03-23-2012, 10:20 PM   #4
Turtlestang39's Avatar
How much did you pay for the whole suspension kit
Turtlestang39 is offline   Reply With Quote
Old 03-24-2012, 06:31 AM   #5
Re: results - lowered and updated gears
$899 from AM + Strut Mounts - $300
install $500
bringing total to about $1500
Well worth it
Old 03-24-2012, 07:17 AM   #6
tc x 4's Avatar
Go to ur local short track an ask around. $200-$300 is the norm for someone that knows what ther doing. If they want more, go somewhere else.
Old 03-24-2012, 07:37 AM   #7
just caution...don't go too cheap and risk a bad install....
Old 03-24-2012, 01:41 PM   #8
tc x 4's Avatar
It's a 3hr job, if u know what your doing. Don't get robed.
Old 03-25-2012, 09:43 PM   #9
Mr. SoloDolo's Avatar
Take it easy though man on the first 500 miles don't want to ruin your rear end!
Mr. SoloDolo is offline   Reply With Quote
Old 03-26-2012, 08:18 AM   #10
BaSohol's Avatar
I only could wait 100 miles :/
But I never lunched it till about 400-500 miles
2007 Ford Mustang GT 5spd
Old 03-26-2012, 02:56 PM   #11
tc x 4's Avatar
Not if It's set up right. NASCAR runs what they brung. Butttttttttttt on the other hand, if it makes any more noise than stock It's not right. Don't settle for that's the way 4.10s sound. If it is louder, don't get on it, take it back.
Old 03-26-2012, 03:30 PM   #12
BaSohol's Avatar
True, mine don't make any noise
Old 03-26-2012, 06:22 PM   #13
So i am just noticing an odd noise since upgrading to 4.10..
Only hear it when moving from say 20-30 mph..from a stop..in the rear sounds like dry metal on metal maybe?...hard to describe.. No problem in the higher bands...
Before I take it back...any ideas?
Thanks
Old 03-26-2012, 06:33 PM   #14
BaSohol's Avatar
Ok that is very vague, makes a noise when your coasting? is it a drone? Or whine
Old 03-26-2012, 06:44 PM   #15
Not coasting..from a stop going from maybe 1st to 2nd or so...
Beyond 40 mph cant hear it occur..
I have an auto but it really sounds like low gear changes
---------- Post added at 08:44 PM ---------- Previous post was at 08:42 PM ----------
Not a drone or whine... My wife said it sounds like metal scraping on the ground..but there isnt anything i can see
Old 03-26-2012, 07:23 PM   #16
BaSohol's Avatar
Ya that's sounds bad best to get the car on the lift ASAP, could be something simple or bad and only will get worse if you keep driving, something could just be loose from getting car lowered and it's scraping something and when you go faster the frequencies change so you can't hear it cause I never heard the noise your describing from gears even on really bad install jobs
Old 03-26-2012, 07:38 PM   #17
tc x 4's Avatar
+1 faster you go, worse it gets
Old 03-26-2012, 08:07 PM   #18
Reading posts from others with similiar 'scraping' sounds from 1st to 2nd...identified as gears...since that was the most recent change I am putting my bets on an install gone bad
---------- Post added at 10:07 PM ---------- Previous post was at 10:07 PM ----------
Will get it in tomorrow
Old 03-26-2012, 08:27 PM   #19
BaSohol's Avatar
Maybe a ring bolt came loose? That happened to me before, first it binded up then made a clunk and growl
Old 03-26-2012, 09:00 PM   #20
Was that a big job to fix?
I am just hoping nothing is damaged.
Old 03-26-2012, 09:06 PM   #21
tc x 4's Avatar
Easy fix if no damage . If that's wat it is, if it comes alway out it could really mess something up. Possibly break teeth off gears.
Old 03-26-2012, 10:15 PM   #22
BaSohol's Avatar
Not to scare you but it trashed my whole rearend, I replaced everything
---------- Post added at 11:10 PM ---------- Previous post was at 11:08 PM ----------
But if that's what it is you should pay anything
---------- Post added at 11:15 PM ---------- Previous post was at 11:10 PM ----------
I did mine myself when I was 17 and forgot the red loctite, oh well haha it was a mess when I dropped the pan, the bolt was bent and rubbing on the carrier looked like glitter pouring out haha
Old 03-27-2012, 12:46 AM   #23
Ok so can anyone tell me exactly what I have to do to change my gear oil in the rear end my car had 80000 miles on it and this service has never been performed!?!
Old 03-27-2012, 01:09 AM   #24
tc x 4's Avatar
Remove cover to drain. Clean cover w putty knife,wire wheel,or scotch brite pad. Clean inside housing well. There is a grove on the bottom that will hold grit and shavings. Use a spray cleaner ( brake or contact ) that evaporates. Put a small bead of sealant on both sides of paper gasket and reinstall cover. The fill plug in on the front drivers side of housing. Pump full till fluid runs out, about 2 1/4-2 1/2 qts. U can get a pump that will screw on to oil jug at parts store for bout $10.
Old 03-27-2012, 02:28 AM   #25
ColeJohnson's Avatar
Hey. With lowering kits you need to remove dust shields on the front or it will scrape. A lot of shops don't do it and will make a metal-scraping-metal sound that is sorta quiet and drowns out when you start moving faster. Check that out too
2016 Comp Orange GT (current)
Old 03-27-2012, 04:08 PM   #26
So I grabbed my mechanic and took him on a ride to identify the sound... Prior to arriving at his shop I listened carefully myself and could only reproduce it once or twice.. But not as loud as before.
With him on the seat beside me it was more evident.
He ruled out gears as being the problem and we believe it is now a drone or something similiar.
He checked underneath and didnt see any visible signs of rubbing so believes it is a drone sound from the exhaust that is different sounding now that the car has been lowered.
I will monitor but have scheduled a more exhaustive diagnosis next week.
Old 03-27-2012, 05:03 PM   #27
tc x 4's Avatar
Ya, I wouldn't by that either . If It's in the exaust its because It's vibrating off somthing.
Old 03-27-2012, 05:23 PM   #28
BaSohol's Avatar
One way to tell is what rpm it happens at, hold it in first and drive at 2400-3000 or hold 2nd doing the same if it only happens in certain rpm range I'd say it's the exhaust but if it's speed related I'd start checking around for a second opinion
Old 03-27-2012, 05:49 PM   #29
Thanks for the suggestions.
Really weird that it is hard to repro when by myself...but easy when someone beside me.
It also seems to happen during the initial pull...so stress on the frame or suspension???
I also think suspension stress related noise because on a couple of occasions i heard it when I bounced during a dip in the road and I was just coasting.
Old 03-27-2012, 05:57 PM   #30
BaSohol's Avatar
Do u have flowmasters?
Old 03-27-2012, 06:00 PM   #31
Nope.
Pypes -pype bombs
Freshly washed, clayed and waxed!! 08MustanGT Pictures and Videos 27 03-27-2012 08:01 PM
fab torque reinforcments and subframe connectors dreamstang 1979-1995 Mustang GT 46 03-25-2012 09:03 PM
lowered 06 GT makes hissing or rubbing sound when getting on the accelerator Ballard281 2005-2010 Mustang GT 6 03-23-2012 05:21 PM
New TB and Plenum question imhooked 1996-2004 Mustang GT 5 03-22-2012 09:38 PM
Pictures of my intake and gaskets. Mustang_Madness 1996-2004 Mustang GT 26 03-22-2012 09:21 PM
12:02 AM
